Old 08-20-2019, 11:44 AM   #251
HSRACER
HSRACER's Avatar
Re: LT1 GenV swap
Originally Posted by 87chevy.com View Post
Tried out e85 in the l83 swap.. man, definatly got some more pep to its step! Definatly worth the extra maybe 100$ to plumb it in. Squeaks the tires up to about 40mph on concrete on full throttle. Still want to get a performance tune, still rocking stock ecu flash.
Clint
Wow good to know. I am glad I plumbed mine in as well!
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 08-20-2019, 11:42 PM   #252
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: LT1 GenV swap
Definatly recommend putting some shakedown miles on it on regular fuel so you work out any tune issue and have fun and then when your content with it as is, e85 it!
Clint
If anyone needs an e85 sensor connector and ecu terminals to build your own e85 setup, I have one or 2 extra connectors AMD plenty of terminals and seals leftover.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-27-2019, 08:15 PM   #253
SCOTI
SCOTI's Avatar
Re: LT1 GenV swap
Just read through this entire thread (after work yesterday/today). Very impressive stuff!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-28-2019, 01:48 PM   #254
87chevy.com
Re: LT1 GenV swap
Almost done with the last retrofit for a while..
One more "pod" to go
Clint
Old 02-15-2020, 10:29 PM   #255
87chevy.com
Re: LT1 GenV swap
made another batch of these adapters, have 2 left
Includes plate, bulkhead connector, 2 screws to hold down bulkhead connector, all mating electrical connectors, terminals and seals for plus one extra of each terminal in case of mis-crimp. metri-pack 150 terminals max out at 14a, the 280 goes up to 30a - which is the purpose of doing these. So just offering the remaining up.
would be the end result. works great for using the flexible correlated fuel line in e-85 situations where you cant / shouldn't run rubber line
80$ plus shipping
an another note, finally got around to installing the Jeep Wrangler, not the Cherokee steering shaft
One page said they are the same but longer. Whats strange is they are cheaper by about 40$. Decided to give it a try. picked one up on ebay. The shaft is about 2x as long as stock.
Used a cut off wheel to cut off the peened edge so the shaft can separate. and it was that easy to separate. There is a machined flat spot on one of the flat spot on the shaft towards the end and a flat spring and spacer to take up any slack? I didn't reuse it, but plan to. I'll get a picture of that tomorrow
tapped it onto the steering gear box, about as much force as it took to get the old one off lol. On the column, the forums say you need to grind in a notch to allow the bolt to pass through. mine didnt, it also fit right on, tightened up and fits like it should. now it can vibrate off possibly, so I will be drilling a hole (similar to the stock shaft) and either tapping the hole and use 2 button head screws or just run a bolt and nut through it like stock.
overall, it fits great, updated look, no slop in this unit, not sure if the stock shaft was wore out, but it was original and inexpensive. Just sharing
clint
Old 02-25-2020, 09:48 PM   #256
87chevy.com
Re: LT1 GenV swap
Stock looking pedal for the L83 swap I'm working on for a customer. Not a bolt in stock swap, but no welding, just 2 adapter brackets.
And the fuel hat assembled with a 90* rollover valve
Old 03-06-2020, 12:39 AM   #257
87chevy.com
Re: LT1 GenV swap
Originally Posted by stevenbear72 View Post
That pcv setup look pretty badass man! Definitely like the way you routed the wiring to battery and battery location bud. I have an L83 swapped 68 GMC.
Probably going to upgrade my pvc setup to the one I just built for my latest build.
Old 07-07-2020, 09:08 PM   #258
87chevy.com
Re: LT1 GenV swap
Projects are never done, but nee projects always pops up...
Ran just fine.. could have just flipped it for a quick buck and then...
2019 tahoe 4wd drivetrain (to 2wd) with 2015 Camaro extension housing
Working on mounts this weekend
Old 01-05-2023, 05:06 PM   #259
Hart_Rod
Hart_Rod's Avatar
Re: LT1 GenV swap
Satisfied with the upper radiator hose choice. Coukdnt find a one liece solution. This one required 2 different hoses with the single adapter. If the adapter was maybe 2 inches longer the stock Fbody hose would work without a 2nd hose.
Still need to sort out the e-fans.. among other things.. also got the ac lines braze together. Pleased with the outcome. Both ends will get 90 degree fittings and it will match / run along side the heater core lines.
Clint
Clint I used a Dayco E72377 for the upper hose. It's pretty long, so maybe it would work for you.
Rob
Hart_Rod is offline   Reply With Quote
Old 12-30-2023, 10:23 PM   #260
87chevy.com
Re: LT1 GenV swap
I'm digging up my own thread lol... Ive been working on several projects and havn't really finished any of them.... the c-10 pulse wiper delay module is pretty much done except a nice case.
I started messing with the canbus... originally I planned on using adapters to connect a sending unit but I didnt like the options out there and plus everything is on the can bus anyway.. plus plus I didn't want to fork out 1000+ on gauges that wont tell me anything else other than how much I spent on them... but its turn key..
fast forward many many .. many hours
first it started out as ordering the stepper motor.
then trying to get it to read a potentometer
then trying to get it to read a sensor... harder...
side tracked into can bus and many many more hours later combined the 2 programs:
videos are hosted on my site
success!!! video shows throttle pedal controlling the stepper motor!!!
http://www.87chevy.com/video/canbus/can_tps_gauge.mp4
link to the gauge project/progress:
http://67-72chevytrucks.com/vboard/s...d.php?t=848692
link to the wiper module project:
https://67-72chevytrucks.com/vboard/...d.php?t=841963
clint
