Old 03-02-2015, 08:18 PM   #301
oldman3
oldman3's Avatar
Re: Dutch '59 Fleetside Longbed
Kees, nice job. Inside the carrier looks great...Jim
oldman3 is offline   Reply With Quote
Old 03-02-2015, 10:46 PM   #302
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Frame looks good!
ChuckDriver is offline   Reply With Quote
Old 03-03-2015, 11:01 AM   #303
reaper71
reaper71's Avatar
Nice and clean looking on the frame.
The Diff. looks in perfect shape
reaper71 is offline   Reply With Quote
Old 03-04-2015, 04:25 PM   #304
RockinKees
RockinKees's Avatar
Rear frame is painted, two coats primer and two coats black.
Thats ready to take the IRS
But paint has to dry...so on with drilling out broken bolts of that same IRS.
Bolt is out, but I have to make new thread.
It was 7/16 and it will be M12 metric, because I have enough of that
I made a bolt just like the original on the lathe, except it's an M12.
No pics yet, sorry.
I also did consult NoClassic, because he also has Jag IFS, and is "two" steps ahead of me...I belief he's in driving state
I asked him about the shockmount measurement, and what I came up with is almost the same as what NoClassic has. So took the Grinder and made some mounts:
I made them of 5mm thick angled steel.
This is what it looks like:
Sorry about the hand and the bad quality of the pics, made with my cellphone....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-04-2015, 05:27 PM   #305
Kim57
Kim57's Avatar
That looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-04-2015, 06:43 PM   #306
Advanced Design
Advanced Design's Avatar
Nice shock mount Kees. You are moving right along!
Advanced Design is offline   Reply With Quote
Old 03-04-2015, 07:04 PM   #307
ChuckDriver
Nice work!
Have you seen this build, they are also using the Jag suspensions front and rear.
http://67-72chevytrucks.com/vboard/s...d.php?t=653170
Old 03-04-2015, 08:33 PM   #308
oldman3
oldman3's Avatar
Kees,pic looks find, nice bracket...Jim
Old 03-05-2015, 05:51 PM   #309
RockinKees
RockinKees's Avatar
Thanks guys!!
No, I had not seen it ChuckDriver. Just read it, they have a bit more work than me
Great to see a family involved in a build
Yesterday I talked about a broken bolt in the carrier, this is my solution to get it repaired. I drilled the broken bolt out, made new thread just milimeter thicker, from 7/16" (11 mm) to M12 metric
The bracket is hold by the two (!!) bolts, that at his turn holds the lower control arm. The bolt on the right I've made, the bolt on the left is from Jag.
Here you can clearly see the difference in size:
When you bolt everything together it looks like this:
Put some new paint on it, just because I can
While I was at it, I could, at the same time, move the diff permanently to his new home, so I did:
Tonight I cleaned the lower control arms and mounted them on the diff. Also gave them some shiny black paint. Unfortunately no pics of them, because I forgot to take all my digital stuff....
That's for next time!!
Cheers!! Kees.
Kool Guyz CC
Old 03-05-2015, 06:07 PM   #310
Advanced Design
Always a good thing when painted parts are going back on!
Old 03-05-2015, 06:15 PM   #311
Katrina/10
Katrina/10's Avatar
Nice safety wire job.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-05-2015, 07:13 PM   #312
Steve-W
Steve-W's Avatar
Damn Kees, I keep repeating myself, but it's a fantastic build!
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 03-05-2015, 09:47 PM   #313
oldman3
oldman3's Avatar
Nice work as usual...Jim
Old 03-06-2015, 12:02 AM   #314
Kim57
Kim57's Avatar
Nice fix on the bolt.
Looks real good.
Kim
My build thread
Old 03-07-2015, 11:50 AM   #315
reaper71
reaper71's Avatar
1 more check off the list!!!
Old 03-09-2015, 11:00 AM   #316
RockinKees
RockinKees's Avatar
Thanks again guys!!
And indeed one more check off the list
Just two thousend to go, more or less....
Just got back of a few hours work, nothing much done...
Welded the shockmounts on the subframe:
Also made an extra gusset at the front side of the subframe, 'cause you never know
Took a pic of the rear that I promised you:
Calipers next, then the half shafts and shocks...almost ready!!
Back to the front, I have a broken bolt on the lower control arm, I drilled it out.
Here you see the broken bolt, it's a 3/8" unf, 5 grade. Difficult to come by overhere. Searched on the net what I could use to have the same strenght, looks like your grade 5 is the same as our 8.8 bolts...
That makes it a lot easier to repair the bolt holes.
I think I drill them all to metric M10, also is mounting the springpan a lot easier to do
Then I can use 4 threaded bars to get the spring at his place, instead of one thread through the middle...
We'll see...
Cheers!! Kees.
Kool Guyz CC
Old 03-09-2015, 12:38 PM   #317
m.o.t
Nice job! Can't wait to see this thing on it's wheels..!
m.o.t is offline   Reply With Quote
Old 03-09-2015, 12:43 PM   #318
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
Old 03-09-2015, 01:24 PM   #319
Katrina/10
Katrina/10's Avatar
Just curious, where do the tops of the front shocks mount on the Jaguar car?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 03-09-2015, 02:50 PM   #320
jkeating1
jkeating1's Avatar
It's interesting that a British car has so many non-metric bolts.
JK
jkeating1 is offline   Reply With Quote
Old 03-09-2015, 06:18 PM   #321
RockinKees
RockinKees's Avatar
Me too Steve, me too!
When do we get your buildthread??
It's about time, don't you think
Looks real good.
Kim
Thanks Kim!
At the inner fenders, which is part of the whole construction. These Jags have no apart chassis like our trucks do.
I had a '67 Volvo Amazon once, all bolts were unc and unf...and that's from Sweden
The British don't have the Metric system... yet...they don't have the Euro neither
I also started with the wheelspacers out of airplain aluminium.
Pretty hard stuff, I must say!
This is what I started with:
After some turning and drilling I got to the point thjat I could testfit it on the wheelhub:
Fits pretty good, also in the wheel itself.
Now have to turn the inner holes at the right size, make holes for the countersunk wheelnuts and wheel studs.
I did draw the drill lines on the next one also:
I have to make these, because the tires are just not hitting the inner fender walls at the back, I want some more room to avoid future problems.
So few hours of work left, for me at home
Tomorrow I get a towbar from a Trailblazer I belief. Hope it fits the '59 chassis. I have to unmount it myself and then get it for free, I'm a happy man
Cheers!! Kees.
Kool Guyz CC
Old 03-09-2015, 07:10 PM   #322
oldman3
oldman3's Avatar
Kees, doing some nice work, and it looks great...Jim
Old 03-09-2015, 10:05 PM   #323
Advanced Design
Nice machining work!
Old 03-10-2015, 01:37 PM   #324
m.o.t
No buildthread yet, still working on my convertible bug...
It's going to be more of a winterproject, and just like you i need to get it registered first
Old 03-11-2015, 01:12 PM   #325
RockinKees
RockinKees's Avatar
Today I bolted the rear calipers on, the radius rods the and torque arms.
Looks great and I think it will work as designed
Next I can bolt the halfshafts on, I have them at home, was buzzy turning aluminium things....
Now I have the spacer size right, I can take them to the truck again.
I also drilled the bolt out of the front lower control arm.
I make all the bolts at metric M10, that's easier for me.
But then again I must also drill out the bolts for the lower shockmounts, they too are rusted in the L.C.A. More work, but I'll get there
Get the towbar yesterday, unbolted really easy. It's just a little bit wider as the frame of the TF truck, so I have to make something to get that right.
Will do a search on that little problem.
The towbar came off a 90's Blazer.
Cheers!! Kees.
Kool Guyz CC
