Old 04-14-2014, 05:32 PM   #326
swamp rat
swamp rat's Avatar
Re: Knomadd '71 SWB C-10
Probably from the drip rail and down the A pillar, from there it drips onto the top of the glove box liner and gets inside..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-15-2014, 12:46 PM   #327
knomadd
knomadd's Avatar
Originally Posted by TexasLS1 View Post
I noticed the same thing in mine the other day after washing it last week (I just got the liner put in the glove box) - I opened the glove box and it had a small amount inside the liner but the top was dry. The only thing I've figured so far is that maybe the PO didn't seal the windshield well, and it's dripping onto the top/side of the liner, running down the side, then seeping inside the liner in the bottom corner where the bottom piece and right side of the liner overlap and are stapled together (the reason I believe this is bc i could tell where the water was seeping in between the two).
I hadn't thought of my antenna possibly leaking? At some point I'll pull the liner back out, put a small bucket in its place, and slowly pour water on the antenna and windshield to try to pinpoint....
Thanks for the suggested areas to look at guys. I know the windshield leaks under heavy rains while driving (so I'm told), just never experienced it myself. And I didn't see water anywhere else inside the cab, just the glove box. Strange.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-05-2014, 09:31 PM   #328
knomadd
knomadd's Avatar
Wow, it's been a while since I've updated this thread. Been busy with work and life lately. Plus ordering new wheels for the GTO has put a big damper on truck spending.
I've done a little over the last few weeks, like install the precision window felts and sweeps...
Painted the vent trim rings and installed one on the passenger side...
And I just installed some van side markers...
That's it for now. Caught a virus last weekend when I was doing the A/C vents, so I haven't been up to working on it lately. I'll probably get back out there this weekend though. Hoping to get the vents installed and maybe the hose routing figured out.
-Duane
Old 06-05-2014, 10:56 PM   #329
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looking good Duane!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 06-26-2014, 04:59 PM   #330
knomadd
knomadd's Avatar
Thanks Kyle!
It's been a while since I updated. I finished the vents a few weekends ago, here are a couple pics of them.
Please ignore the hack job on the radio hole. Whoever cut it must have had a few too many to drink by then. I've got a billet plate to help with that. That's one of the items on my list to get mounted. Since the stereo is out, it will happen before I put it back in.
I used a dremel tool for the rectangular vent hole. It didn't take long, but it made the dremel so hot that it stopped working for a while. OOPS! It's good now though.
I also figured out where I was going to mount the bulkhead on the firewall on Monday evening. I drilled the holes and didn't have time for pics that night, and haven't been out there since. I'll try to get the bulkhead mounted tonight and take a couple pics of it.
-Duane
Old 06-26-2014, 09:47 PM   #331
knomadd
knomadd's Avatar
Got the vintage air bulkhead installed...
-Duane
Old 06-26-2014, 11:05 PM   #332
mcbassin
Still Learning
mcbassin's Avatar
Looking good Duane. Keep up the hard work you'll be chilling soon.
mcbassin is offline   Reply With Quote
Old 06-28-2014, 01:46 PM   #333
knomadd
knomadd's Avatar
Thanks Mike! Still need some parts, but should have it done by winter
Got my 3-point seat belts installed today. Thanks Sarah (laidbackrecreations)!
-Duane
Old 06-28-2014, 01:50 PM   #334
screaminchevypickup
Laid Back
Trucks looking great!!
Kyle
72 chevy swb
Kyle
Old 06-30-2014, 03:57 PM   #335
knomadd
knomadd's Avatar
Thanks Kyle!
I'm getting the A/C installed.... slowly. Here's my plan for the engine side of the bulkhead.
I got the main component installed for the Vintage Air Gen IV unit. This took some time since I decided not to use the hard lines from the kit. Hopefully it doesn't leak, or it will be heck trying to get it back out and fixed. Here's a pic of it installed.
-Duane
Old 07-02-2014, 10:13 AM   #336
knomadd
knomadd's Avatar
In an attempt to recurve my hood (it's too low in the middle, making it drag when opened, and the sides are too far out) here's what I did...
It sat like this for 3 days. It helped a little. The sides look to line up a bit better, but I'm now seeing that my hinges are worn out. I have to push on the back corners to get it to sit flush with the cowl. I need to shove the hood toward the drivers side to get it to line up with the body lines, but that won't be difficult.
I may need to do it again for a longer period of time to get the hood to remember where it should be
-Duane
Old 07-21-2014, 12:15 PM   #337
knomadd
knomadd's Avatar
Haven't done much since I got back from vacation. I did just placed an order for a PBFab fully adjustable trac bar. I don't know if the rear moves much with the shorter CPP double adjustable bar that I have on there now, but the more I've read, the more it looks like I really should have the longer bar to make the rear stay close to the center during suspension travel. Plus, I really like the PB stuff.
-Duane
Old 07-21-2014, 02:42 PM   #338
BigDaddyV
BigDaddyV's Avatar
Sweet truck bud.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 07-22-2014, 09:45 AM   #339
knomadd
knomadd's Avatar
Originally Posted by BigDaddyV View Post
Sweet truck bud.
Thanks! It's coming along... slowly.
-Duane
Old 07-22-2014, 09:49 AM   #340
BigDaddyV
BigDaddyV's Avatar
Much farther along than I am. Bout to get rocking on mine again once I get all my ducks in a row and break the bank on my new frame....
Old 07-22-2014, 10:08 AM   #341
knomadd
knomadd's Avatar
Good luck with your build. You're probably closer to your end goal for your truck than I am. I've got grand plans to tear it all down and build a drop member frame, raise the bed, repaint, etc. Since it's currently driving, and I don't have the space or funds to tackle a complete tear down and rebuild, I'm doing it while she's running. I probably won't modify the frame during this round of building her.
I guess I'll be spending more in the long run to do this truck twice!
-Duane
Old 07-22-2014, 10:17 AM   #342
BigDaddyV
BigDaddyV's Avatar
lol I hear ya. Mine is already tore all the way down, and I'm about to go get a frame with PB extreme front and rear dropmembers and mmw front arms. That will put me well into the game.
Old 07-26-2014, 10:21 AM   #343
Hart_Rod
Hart_Rod's Avatar
looks good. How hard was it to get the bulkhead fitting to attach to the sure fit lines? Do you have some pictures? Thanks,
Rob
Hart_Rod is offline   Reply With Quote
Old 07-26-2014, 04:25 PM   #344
knomadd
knomadd's Avatar
Rob, I didn't use the sure fit lines. I used eaton/Aeroquip EZ clip fittings to connect to the bulkhead inside and out. I only used a portion of the sure fit line for the heater hoses under the dash. I wound up running a bead in the line and clamping the EZ clip hose with a worm gear. I don't have pics of it, unfortunately. Seems like every time I work on it, I forget about pics until it's too late.
I'm currently trying to get the wiring and engine side done. Ran the duct work last night and the interior electrical this morning. I'll see if I can squeeze a camera in there for you.
-Duane
Old 07-27-2014, 05:03 PM   #345
knomadd
knomadd's Avatar
Rob,
Here are a couple of pictures for you. This is the best I can do with it all installed.
This is what the rest of the sure-fit line looks like with the EZ Clip hose attached.
And the bulkhead fitting.
-Duane
Old 07-27-2014, 05:10 PM   #346
knomadd
knomadd's Avatar
Here's the duct work...
I had to pull the grille off so I could get the hard lines from the condenser and drier installed. That was a disaster! More on that later.
Here's how the lines looked after I got it all installed. I still need to do the heater hoses.
-Duane
Old 07-27-2014, 05:25 PM   #347
knomadd
knomadd's Avatar
On to the disaster that was the grille removal...
So taking the grille out wasn't a problem. That was pretty easy. The problem came later when I had to make a trip to the hardware store for longer bolts to install the fittings on the compressor.
As I'm pulling out of my driveway (I bet you can see where this is going) I feel something weird under the car, so I stop and get out to find the grille UNDER MY FRONT TIRE!!!! I get back in the car and finish driving over the grille and get out to assess the damage...
It doesn't look too horible in this picture, but the emblem is cracked and the two lower bars have broken away from the rest of the grille
Here's the ugly shot..
The sad part is that when I leaned the grille against the car I told myself I'd better move it before I leave so I don't run over it. An hour later and I ran over it!
So, now I've got the excuse to replace the entire grille with a chrome outer and a new billet inner... $625+ later... Oh, and truck freight is another way to rape you out of some of your hard earned money. Classic Industries was cheaper with their 15% discount, but freight was $200!!!
I wound up cancelling that order and just ordering through Classic Parts.. I hope their shipping isn't that high. I saw $70 added to the overall cost (included in the price listed above) but the fine print said shipping charges may not be exact.
Just goes to show that it's best to listen to yourself when you think something might happen and just MOVE IT BEFORE IT DOES HAPPEN!!!
-Duane
Old 07-27-2014, 05:47 PM   #348
mcbassin
Still Learning
mcbassin's Avatar
Man Duane sorry to hear about the grill. That sounds exactly like stuff I do all the time. The VA install is looking good. I sure liked mine today in the 100* weather.
Old 07-27-2014, 08:41 PM   #349
knomadd
knomadd's Avatar
Thanks Mike. I couldn't believe it at first, but when I finally left for the hardware store, I thought to myself "Go figure! You're overdue for something stupid like that." Things happen... I guess I can look at the bright side... I get to replace the poor fitting grille sooner than I expected.
The VA stuff is pretty cool. I love it in my GTO, so I knew I wanted it in the C10. I did the same thing with the EZ clip stuff too.
-Duane
Old 07-28-2014, 02:20 AM   #350
swamp rat
swamp rat's Avatar
Just wondering if you ever found the source of that leak that found its way into the glove box?
Also I'd really like to know what brand of headers you have and if you can use standard length spark plug body's and not stubby plugs.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
