07-21-2014, 05:44 PM | #351 |
Re: My daily driver/beater : How I turned lemons in lemonade
Really??
Guys, guys, guys.... It's 132nd's of an inch w/one eye closed & the other squintin' through the magnifying glass. Gotta get it right. It's all in the details!
07-21-2014, 07:42 PM | #352 | |
I have installed Dropmembers in 73-87 trucks while maintaining the factory floor... no large hump required (all SBC/TH350 combos). Depending on which transmission you are running it might or might not fit without modification OR the need of the large hump conversion. However, from a business standpoint, knowing that there are a couple transmission combos that WILL require a large hump, it is standard protocol for us to tell people when they call or email that we "recommend" a large hump trans tunnel. We would much rather hear the feedback "I have plenty of room and didn't need the large hump" rather than "you told me it would fit and it doesn't". I hope you understand the reasoning. We have been making this recommendation for several years now. It is in our instructions (which will be posted on our website for all to see here shortly). They are and have been available by request through an email.... or as you found, even a phone call will yield the information... albeit it wasn't the information you wanted to hear. With that said, there is a good chance that you will be just fine without cutting up and tossing out your "virgin" goods. I would proceed as the others recommend and move forward with a test fit of the cab to see if yours will yield adequate clearance. Since you "won't call back for sure" because the information I made standard protocol for Dave to give wasn't what you wanted to hear.... I understand. In that case you can always shoot me an email tech@pbfab.com as I personally respond to them. Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
07-21-2014, 08:03 PM | #353 |
Watch out for your cornhole !
Nate, try not to be offended by my words. I'm not a good communicator. I'd have felt a lot better if he'd have said "maybe yes, maybe no depending on your specific combo". When he didn't ask what engine or trans I'm running, I just had the perception that he threw out his answer to expedite the conversation without getting into it any further. I can easily grasp a "maybe" answer since there so many different variables.
I'm sure the new website will go a long way towards clearing up some questions folks have.
07-21-2014, 08:14 PM | #354 | |
At times we all lack on the communication end.... it happens, we are human. One guy takes a "maybe" as "you told me so" another guy takes it as a "you said it would never work". Since at times there is ambiguity when it comes to this custom stuff, we have learned that it's best to error on the side of caution when making recommendations. With that said, we are always looking for ways to make communication more clear on all ends. Our new site will be a huge help as we are in the process of revising all our install guides where than can be accessed on the site, along with a FAQ section. It's in the works.... just taking a bit of time. Do me a favor and follow up with me as progress continues and I will do all I can to help provide you with all the information you need. Even if it means giving a sliver of hope with the word "maybe" attached. Nate
07-22-2014, 03:46 PM | #355 |
Hot Rods For Life
Cheese and rice this truck is straight up ill'n.
07-23-2014, 09:48 AM | #356 |
Not sure how I missed this build, but I like it.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
07-26-2014, 11:14 PM | #357 |
I've been putting in the hours lately. The rear suspension is basically complete. All I have left to do is build lower shock mounts and set pinion angle and burn the saddles in place. I'll wait to do the pinion angle and saddle deal until after I get my dropmember in place since the engine, trans relocation will come into play there. At that time I'll set the angle then remove the entire rearend for welding and clean and paint it also.
Today I built a rear crossmember for my air supply stuff. The tank mounts to the front of it and the compressors sit on shelves on the rear of it. I did throw the cheesy Viair rubber grommet vibration mounts away and ordered some proper bolt in vibration absorbing feet from McMaster Carr. I got my panhard bar parts from Speedway Motors. Good pricing there. I built a stud into the left side link bar and welded brackets to the right frame rail. My goal was to have the bar be close to horizontal at ride height and as long as possible. I think both goals were pretty much met within reason.
07-27-2014, 04:06 AM | #358 |
That is super clean!
'68 SWB Fleetside '98 K1500 Silverado |
07-27-2014, 06:29 AM | #359 |
Very nice work, as always Kevin. You are really moving on this truck!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
07-27-2014, 09:14 AM | #360 |
67-72 parts collector,…
Looks great!
I'm pretty sure you could sell that air tank/compressor crossmember. Here's a few pics of a slammed stepside and the mods they did to tuck a BIG wheel. The bed was raised and the fenders were stretched. I seen a few other builds like this. That's why I had concerns for your stepside bed. Obviously your total tire height will be less than this one.
07-27-2014, 09:16 AM | #361 |
Another pic,...
07-27-2014, 09:25 AM | #362 |
Ive already bought the paint and the wheels and tires. I can promise, no one is gonna see the end product coming. It's going to be different than any other truck I've seen built out there.
I've got another month minimum waiting on the drop member so I'll start body work this week. Much work to do before February.
07-27-2014, 10:12 AM | #363 |
Cant wait to see how this one turns out .
07-27-2014, 11:51 AM | #364 |
One reflection I can make as I've worked on this project.
A lot of guys throw out very unrealistic prices as to what it costs to do an air suspension. Frankly, some are so unrealistic as to be completely full of sh1t. Its expensive and just wears you out with nickel and dime stuff. Fittings are expensive. You could spend 75 dollars just in wiring for your compressors if you do it right. 4ga wiring ain't cheap. And, the more sanitary you want the end result to be, the more expensive it gets.
07-27-2014, 06:19 PM | #365 |
That's always been my consensus with pricing of doing airbags and doing them right. It looks like you've got a pretty good handle on this bad boy. I like the mount for the tank and compressors. Kool.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-28-2014, 11:18 AM | #366 |
Did you post any pics of the lower bars that you made?
I have been thinking of build a 4 link for the rear of my dually.
07-28-2014, 11:37 AM | #367 |
I'm just glad to be here!
Tank/Compressor mount looks great!
What size tank did you use? Where did you get it from?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-28-2014, 12:28 PM | #368 | |
07-28-2014, 07:15 PM | #369 |
Did you post the picture of the link bars in here? I was looking for it to show a friend....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
08-02-2014, 11:34 AM | #370 |
Farm Truck
Nice Work.
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
08-03-2014, 06:33 AM | #371 |
Not much updating recently. I'm working on it all day every day though.
I'm one month in since I ordered the dropmember. I have all steering rack stuff, air bags, etc here just waiting. I'm not really expecting anything in that area until nearly September though, per my conversation with Travis when I placed the order initially. First, the rear suspension. I tried several different ways, but I just couldn't be happy with the 2 link setup. I could set it up to where I was satisfied with the pinion angle range, but the side to side was what killed it for me. I set it up with a 36 inch long panhard bar mounted from the bottom of the frame to the opposite side lower link. Much like a typical ECE Super Track Bar. Then I tacked my shock mounts in place and cycled the suspension. When I did that, it smartly ripped all of the shock mounts off. From dump to lift, the rearend shifted 2 inches side to side. Hell no. There's a reason that Ekstensive mounts their shocks sideways rather than up and down like they ideally should be. I had wondered why, until I saw it with my own two eyes, then it became clear. Facepalm moment. So I took all of that off and thinned my spring pack down to two leafs and built a lowering block and set up an AOL system. Much better. At least the suspension stays lined up during cycle from bottom to top. After testing to see if I'd be happy with AOL, I went ahead and ordered two sleeve Firestone bags and am mounting them from the side of the step notch down to the old leaf spring pad on top of the axle. So, for all keeping score out there and preparing with the "I told you so's".....yes, I went down a dead end street with that whole 2 link idea. Lesson learned. I paid for it financially and labor wise. I got proper mounts for the compressors instead of that cheesy grommet crap Viair supplies with them stock. Built a bracket for my electrical stuff back there. And I have all paint supplies here on hand. I had to place an order this weekend for some Rage filler, Evercoat Glazing Putty, Epoxy primer, and 2k primer. So, from here forth, if you don't see me posting much, it's because I'm doing paint and body work. Color pictures will be forthcoming when I'm ready to debut the truck in color.
08-03-2014, 07:10 PM | #372 |
Did you entertain the idea of a watts link to locate the rear axle before ya scrapped the two link? Looking forward to seeing progress on this thing.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
08-03-2014, 11:35 PM | #373 |
Looks like its coming together. Can't wait to see it laid out.
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
08-03-2014, 11:59 PM | #374 | |
TX.... Personally..... Even w/a 4-bar, you would have needed the shocks mounted so they could pivot side to side. Not that big of a deal IMO & the shocks still function @ less than the OE engineered angles (I set them up to be @ less than the OE angle they just pivot differently). Mine have about >3/8" of side shift total over approx ~4" of height change from ride height to fully compressed. I just set them so that @ full drop, they don't interfere w/anything or bind (worst case scenario). Fab on . . .....
08-04-2014, 01:22 PM | #375 |
You know it's all a learning curve. I can't wait to see what you came up with. Either way still digging the build. Keep on keeping!
