03-22-2013, 09:44 PM | #376 |
Re: Project "Jezebel"
wow!!! thats a work of art!
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
03-26-2013, 01:18 PM | #377 | |||
Project collector
I received the new cab mounts and the rears in the new kit are about 1/4" taller than the fronts. I installed the new cab mounts and will have to add shims to get the cab inline with the bed. Quote:
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
03-26-2013, 03:42 PM | #378 |
That is correct. However, there are 2 items to note: 1) Instructions were not included with mine and I determined which bushings where the front based on the larger inner diameter thru hole and how they matched the bushings I removed. 2) I had to shim the rear bushings approximately 1/8" in order for the cab to line up with the bed. Now I am questioning if the front and rear bushings should be swapped for one another. Hmmmm.... It will be interesting to see the bushings from Classic Parts work out.
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
03-26-2013, 03:47 PM | #379 |
Project collector
Quite a bit of progress but a lot more still to be done.
Dynamat Willwood master cylinder and proportioning valve Brake lines Rear 95 Impala SS brakes Boyd's Tank and SS fuel line American AutoWire harness Dakota Digital VHX dash, AC Controller, and Gear selector Vintage Air Gen IV Holley Fuel pump and Street Avenger carb Early Classic Drop Spindles and tranny cross-member Anti-sway bar and prothane bushings Third brake light (55 Chevy) Champion Monster 4 core aluminum radiator w/dual fans Upholstery guy says the upholstery will be done tomorrow. We will see. Here are some pics (some show the work in progress). If there are any area's you want more pics on, let me know. Since I didn't want to bolt anything to the firewall I made this bracket to bolt the evap to. It's screwed into the cowl at the top and behind a bracket on the toe board. Dakota Digital boxes Spaghetti anyone? Master and brake lines AC and Heater hoses in progress
03-26-2013, 03:53 PM | #380 |
Looks great! Do you have and rubber bushings under the bed mounts?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-26-2013, 03:57 PM | #381 | |
Project collector
03-26-2013, 08:18 PM | #382 |
Friggin sweet!
04-02-2013, 08:43 AM | #383 |
Project collector
Making some progress, though not as much as I would like.
Wiring almost complete. Flaming river polished stainless steering column installed. Lokar mechanical shifter installed Dakota Digital VHX gauges installed Dakota Digital VA controller installed. Although the display is red and I ordered blue.... The box even listed it as blue. I'll have to call and swap it out. Glass installed Sanderson headers installed Bed and cab bolted down. It took a half inch of shims to level the rear of the cab. I may have to add more shims when I install the front sheet metal. Picked up he interior from the upholstery shop. Let me know what you think. Started the engine. Here are some pics. It will take a few posts to upload them unless if someone can tell me why I can't upload but one pic as a time via this iPad.... Posted via Mobile Device Posted via Mobile Device
04-02-2013, 08:44 AM | #384 |
Project collector
04-02-2013, 08:45 AM | #385 |
Project collector
04-02-2013, 08:46 AM | #386 |
Project collector
04-02-2013, 09:12 AM | #387 |
Really nice Steve.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
04-02-2013, 09:54 AM | #388 | |
04-02-2013, 09:56 AM | #389 | |
04-02-2013, 10:18 AM | #390 |
It's coming together! Everything looks great.
04-02-2013, 11:04 AM | #391 |
Still Learning
Future show WINNER for sure! Awesome work Steve.
04-02-2013, 12:02 PM | #392 |
67cheby
Looking TOP NOTCH !
04-02-2013, 01:16 PM | #393 |
Project collector
Thanks guys for the kind comments. It's great motivation!
Here is a vid of the engine. It's already broke in. http://http://s971.photobucket.com/user/sgaylord/media/IMG_0058.mp4.html Posted via Mobile Device Let me know what you think. Posted via Mobile Device
04-02-2013, 06:58 PM | #394 |
Sounds great!!!!!!
Rob |
04-02-2013, 11:31 PM | #395 |
Show off!
Looking awesome and sounds real snappy! I think I'm going to go invest in Goodyear because I think you'll be burning through the tires on that bad boy. |
04-03-2013, 08:16 AM | #396 |
Still Learning
Engine sounds great!
04-03-2013, 09:59 PM | #397 |
Looks great
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
04-03-2013, 10:33 PM | #398 |
This project reminds me of another c10 project a friend of mine did, no rust left unfixed.
In my opinion the Quality of craftsmanship and attention to detail is top notch A #1 and with this level of restoration the truck will command top dollar when you are done. This one deserves some serious documentation so people can see all the hard work you put into it and the level of professionalism it was treated to. |
04-05-2013, 01:12 PM | #399 |
Project collector
Thanks guys for all the comments. Here are a couple more pics for ya. I installed the front sheetmetal and she is starting to look like a truck again.
I haven't color sanded the hood yet and I still need to buff those panels that I have cut already. Posted via Mobile Device Posted via Mobile Device
04-05-2013, 01:16 PM | #400 |
Project collector
These pics are 105k and 97k respectively so I have no ideal why this iPad will not allow me to post more than one at a time. If anyone knows how to do this please let me know.
