Old 01-31-2016, 01:58 AM   #376
randomco
Re: "Old Olive" 1970 C10 porterbuilt build
She's alive! Got her started up and I'm stoked. Sounds awesome! Youtube link here https://youtu.be/RamcAOyFzKc
Josh, what did you do for bracing from the bottom of the bedside back to the bottom of the bed floor since you raised it? In front and behind the wheel opening. Sorry if I missed it
Thanks, Wade
Here's the new support rods
I apologize if I missed it, but what drive system did you use on the engine? Alternator, PS, AC, ETC?? Looks great man!! I love this truck
I'm using corvette accessory drive setup from pace performance, it came with the alternator, p/s pump, and AC comp/bracket. I couldn't use the AC compressor or bracket with the kit though, I ended up buying a kwik AC bracket for the corvette drive and a sanden AC compressor to work with my vintage air.
Josh
1970 Chevy C10 SWB build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=639787
1976 Chevy k10 Silverado Bought new in '75 by my Grandfather
1965 Lincoln Continental Convertible - SOLD
1965 Lincoln Continental Sedan - SOLD
randomco is offline   Reply With Quote
Old 01-31-2016, 09:26 AM   #377
Gainsb
The engine sounds great!!
Gainsb is offline   Reply With Quote
Old 01-31-2016, 02:05 PM   #378
rwade
rwade's Avatar
Thanks Josh. Whole truck looks awesome
Wade
rwade is offline   Reply With Quote
Old 01-31-2016, 02:12 PM   #379
'68 Newtricks
'68 Newtricks's Avatar
damn that looks sweet
wish I had more patience for my own build
question, is that a crossover pipe (H pipe) on the exhaust? Won't do ya any good after the mufflers. If it's not, what the heck is it lol. I can only stare at something so long before haha
note to self: ditch rusty CPP master cylinder, get new aluminum MC
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-31-2016, 03:33 PM   #380
Advanced Design
Advanced Design's Avatar
Start sounds very good! Love it...
Advanced Design is offline   Reply With Quote
Old 01-31-2016, 03:33 PM   #381
randomco
Actually ditched the proportioning valve and got a wilwood adjustable prop valve. Looks better and will allow me to better dial the bias.
I would've liked to put in an H or X pipe before the mufflers but there simply isn't enough room with the porterbuilt frame stiffener assembly. We opted to put a crossover pipe after the mufflers, not for performance, but to even out the tone and mellow down the dreaded freeway drone.
Josh
Old 02-01-2016, 01:38 AM   #382
ajgriffin
ajgriffin's Avatar
Whatever you did...sounds awesome!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 02-01-2016, 10:12 AM   #383
randomco
Engine is basically finished! Engine covers had to be cut up quite a bit to fit, but look nice now. Hydroboost and power rack is plumbed. Aeromotive fuel pressure regulator is mounted and plumbed.
Had trouble with my factory column so went ahead and bought an Ididit tilt column and billet specialties steering wheel, just waiting on a new unisteer
U joint to put in tbe column, bleed the brakes and it'll be ready for a spin...hopefully.
Josh
Old 02-02-2016, 09:23 AM   #384
bodydropped68
bodydropped68's Avatar
What issue were you having with your stock column binding at the joint or an issue with the column itself. Mine seems close but not sure if there is going to be an issue I'm running an extreme DM and a stock column on my 68. Thanks Paul
bodydropped68 is offline   Reply With Quote
Old 02-03-2016, 01:59 AM   #385
randomco
The shifter section was loose and I couldn't get it any better. It physically fit with the extreme drop member no problem, I just was tired of dicking with the sloppy shift lever.
Josh
Old 02-03-2016, 08:57 AM   #386
mcbassin
Still Learning
mcbassin's Avatar
Your engine sounds and looks great! Congrats on firing it up!
mcbassin is offline   Reply With Quote
Old 02-03-2016, 09:43 AM   #387
bodydropped68
Totally understand. Your truck looks great sounds even better thanks for the imput.
Old 02-07-2016, 11:20 AM   #388
randomco
Ok guys I need some help. My power steering isn't working. Before I connected the lines to the pump and fired up the truck, I could turn the wheel lock to lock no problem. Now that it's plumbed and with fluid that tbe steering is very lumpy and no power assist. I have the front jacked up. The wheel will turn about 1/4 steering wheel turn easily and then get to a big lump and is really tough to get past, then another easy part followed by a hard lump again. About 3 lumps from center to left lock and from center to right lock. Any one have problems with theirs?
Josh
Old 02-07-2016, 12:18 PM   #389
BossHogg69
motor exploder
BossHogg69's Avatar
I know you have a power rack and probably a type II pump, but I just replaced my power steering pump and steering box with stuff from AGR. I also have hydroboost. It literally took my about 4.5 hours to bleed the air out of the system to get it to act right - it was a frustrating PITA. This involved turning the wheels back and forth with the cap off the reservoir and the engine off to get all the air out, then you have to bleed the hydroboost part of the system too. Something else to check is anything hitting or binding up in the system, maybe you can have someone else come turn the wheel back and forth while you look. Did that steering rack come with a bleeding procedure in the instructions?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-07-2016, 01:21 PM   #390
randomco
Thanks for the tips. Was your steering hard and lumpy at first too? How much fluid did you end up using? How did you bleed your hydroboost?
Josh
Old 02-07-2016, 02:09 PM   #391
BossHogg69
motor exploder
BossHogg69's Avatar
I only started mine for a second after the swap, checked the reservoir and it was all foamed up and bubbling. While bleeding the box & pump with the engine off, yes it was hard to turn it lock to lock and that was with the truck up on my lift and the wheels off the ground. It took WAY more fluid than I expected. Well over 2 quarts, but I'm using a Saginaw pump and a steering box, so yours will probably be different, but it takes quite a bit of fluid to fill up all the lines, the rack (or box) and the pump/reservoir.
Did you just hook it up and fire up the motor and it wouldn't turn properly? I'm surprised your pump wasn't whining and making all kinds of noises. Mined was raising all kinds of hell when I iniatially fired it up after the first time I tried to bleed it and there was still a ton of air in the steering box.
http://www.agrperformance.com/Instal...erformance.htm
http://www.hydratechbraking.com/tech.html
This should help.
Adam
Old 02-10-2016, 11:15 AM   #392
randomco
This should help.
Thanks for the help guys! I found the problem... I had tbe column spline too far into tbe unisteer u joint and it was binding on every turn. I'm a Dumbass! Backed it out and now tbe steering is smooth and effortless. Just need to finish up the brakes and I'll be ready.
Josh
Old 02-10-2016, 11:49 AM   #393
Wasted Income
Boosted Member
Wasted Income's Avatar
Can't believe I haven't run across this build thread before.
I approve of both the powertrain, and the color. Awesome build.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-10-2016, 12:51 PM   #394
junour11
i was going to suggest the binding steering shaft. i ran in to that problem on a 65 shelby cobra steering shaft. good job on the fix truck looks awesome.
junour11 is offline   Reply With Quote
Old 02-11-2016, 03:11 PM   #395
mooseknuckles
mooseknuckles's Avatar
hey Josh we need some updates.....get this thread back on track!
mooseknuckles is offline   Reply With Quote
Old 02-11-2016, 03:15 PM   #396
randomco
need to work on the brakes a bit. Tried to bleed them yesterday and had fluid leaking from every connection! I hate brakes
Josh
Old 02-11-2016, 03:57 PM   #397
BossHogg69
motor exploder
BossHogg69's Avatar
Glad you got her back on track!
Adam
Old 02-11-2016, 05:31 PM   #398
aggie91
I'm just glad to be here!
aggie91's Avatar
Very nice truck and a great build. Love the white frame and suspension!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-14-2016, 12:20 AM   #399
randomco
First time driving Old Olive since she was an original pickup truck
https://youtu.be/pK5sk3kCYCo
Josh
Old 02-14-2016, 12:33 AM   #400
randomco
Josh
