10-07-2022, 02:13 AM | #451 |
Re: slammed 57
Holy cow I’ve been missing out….wow! Looks great!
10-08-2022, 08:46 AM | #452 |
Re: slammed 57
Question… when you’re sanding are you cutting to 1500 or 2000 grit before buffing and are you doing your final polish with foam or wool?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
10-08-2022, 07:36 PM | #453 |
Re: slammed 57
Thanks fellas I appreciate it
10-08-2022, 07:41 PM | #454 |
Re: slammed 57
800,1000,1500,2000,2500,3000 grits all by hand with ridged and soft blocks. I use a lambs wool pad from 3D ( highly recommend) little pricey for that pad $40 but sooo worth it and then a lake county white foam pad for polish.... I been using 3d compound and 3d polish ( i really their compounds) 2500 grit is not a must but does help a little more
10-08-2022, 10:26 PM | #455 |
Re: slammed 57
Thanks for the info.
Can’t wait to see the whole body complete. I agree… lots of work, but SOOO worth it!
10-09-2022, 06:22 PM | #456 |
Re: slammed 57
using a ton of guide coat between each grit except when doing the final step of 3000 grit. Also Iam really happy where the patched in of the cowl vent, came out pretty slick. all that left with the cab is the cut and polish of the door jambs....
10-10-2022, 11:01 AM | #457 |
Re: slammed 57
Looks beautiful...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
10-10-2022, 08:43 PM | #458 |
Re: slammed 57
slamed 57 you said you guide coat when colour sanding. Never thought of that , dose that give good indication of when you have removed all the marks from previous grit. Doesn't the water from sanding just wash the guide coat off?? Very nice looking truck and paint is awesome.
10-10-2022, 10:20 PM | #459 |
Re: slammed 57
Yes, it tells you exactly when all scratches are gone and move on to the next grit. you can not use the guide coat on the first cut ( there are no scratches for the powder to fill) only after 600-800 or what ever grit you prefer start with.The key is to use a lot of light. a flood lamp on a stand works great, a led that straps to your head (like what the mechanics) use works decent to. when first applied and sprayed with water only a slight amount comes off but plenty stays on for the sanding process. As your are sanding you will see the scratches slowly disappearing, when they are gone I will sand 2-3 more swipes after just to be sure. it produces a consistent and even result. 3000 grit does not need guide coat applied. I also only buff and polish at 1000 rpm with a high quality pad,almost impossible to burn the clear or burn through.
10-11-2022, 09:35 AM | #460 | |
Re: slammed 57
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
10-11-2022, 09:41 PM | #461 |
Re: slammed 57
slammed 57 thanks for the reply. Will have to try that, alsohow do you prevent getting deeper scratches when sanding. For some reason i get scratches fromdirt or whatever in the paint when sanding. I try to use a lot of soapy water when sanding but still get them don't know what I'm doing wrong. Also soak paper in bucket often
10-11-2022, 09:47 PM | #462 |
Re: slammed 57
Use clean water
Wash the part to be sanded first before sanding Change water between grits Dont stir up the water when dipping sander into bucket Use a large bucket Use a bucket to rinse of the sander before dipping into the "good" bucket Use a soaking wet rag to wipe the surface often and especially between grits Use a pump sprayer |
10-11-2022, 09:49 PM | #463 |
Re: slammed 57
I have used a garden hose with a slow stream to flood the surface when wet sanding.
10-11-2022, 10:11 PM | #464 |
Re: slammed 57
What guide coat are you using?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
10-12-2022, 11:33 AM | #465 | |
Re: slammed 57
10-12-2022, 11:36 AM | #466 |
Re: slammed 57
I use mirka dry coat with the 3m guide coat pad only, the mirka pad works , but the 3m has a little more spongy and softer feel to it. I wouldnt run out and buy 3m just for the pad, I just had it laying around from prior use
12-21-2022, 10:27 AM | #467 |
Re: slammed 57
still chugging along, got a few more parts painted and assembled
12-21-2022, 10:28 AM | #468 |
Re: slammed 57
Hope y'all have a Merry Christmas
12-21-2022, 10:50 AM | #469 |
Re: slammed 57
That looks great!!!
12-21-2022, 02:16 PM | #470 |
Re: slammed 57
Fantastic looking build!! Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
12-21-2022, 07:30 PM | #471 |
Re: slammed 57
Wow! Beautiful! MerryChristmas!
12-23-2022, 12:24 AM | #472 |
Re: slammed 57
nice build! that meat on the back gonna look
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 |
12-23-2022, 11:23 AM | #473 |
Re: slammed 57
you do great work Mike. What size gas tank are you using?? Merry Christmas my friend.
12-31-2022, 11:44 AM | #474 |
Re: slammed 57
I like it!
01-09-2023, 07:23 PM | #475 |
Re: slammed 57
Little progress here!
