08-25-2013, 08:54 PM | #26 |
I have a radical idea!
Re: "1968 C-10 SWB build - Project Keeper
Thanks! That's probably going to be the combo I go with. The truck below has 8's on the rear and 6's on the front with the same caps I have, and it looks great. I am probably going with a very similiar stance to this truck. It just looks right to me.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-25-2013, 09:01 PM | #27 |
I did get a little something done today - I stripped the passenger door to the metal and primed it. The paint had some bubbling from the heat, so I went ahead and took all of it off down to the body line where the molding mounts.
08-26-2013, 01:32 PM | #28 |
Tot Roddin'
Nice work! Keep those updates coming.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-28-2013, 09:24 PM | #29 | |
Thanks Nate!
Here's some pics of it. I still have to mount the FM converter in a new glove box liner.
09-06-2013, 11:03 PM | #30 | |
Just gotta paint it now!
09-07-2013, 06:30 AM | #31 |
I like the ashtray mod, very slick!
09-07-2013, 10:32 PM | #32 |
Thanks - it should look good when I get it painted.
09-07-2013, 10:52 PM | #33 |
Nice! What type of hinge did you use?
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
09-08-2013, 12:18 AM | #34 |
I used stainless piano hinges from McMaster-Carr. I used the 3/4" leaf hinges with 3/32" pin diameter.
http://www.mcmaster.com/#stainless-s...hinges/=oeuqbq
09-08-2013, 10:00 PM | #35 |
Just some little stuff today. I got some really nice visors (Thanks Uncle!), Installed a new dome light, and a installed a new wiper motor. I also picked up some more vintage Alabama license plates and I now have a plate for each year of these trucks with my correct County code (12) except '69.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 09-10-2013 at 11:39 PM. |
09-10-2013, 11:37 PM | #36 |
Got the ashtray door finished. I didn't want to cut up the original ashtray, so I decided to paint the ashtray to match the silver/textured finish on the gauge cluster and glove box door. I like the way it looks. I have an amp on the way to boost the speakers a little, and I'm going to wire it up and reinstall the radio and fm converter.
09-10-2013, 11:47 PM | #37 |
I have never seen an ashtray theme painted like that it looks like it could have been that way from the factory, I like it.
09-11-2013, 12:47 AM | #38 |
Thanks - I wasn't sure if I would like it, but I do. I think the dash will look great with the radio back in and new heater controls.
09-14-2013, 09:02 PM | #39 |
Always been one of my favorite trucks on here! Excited to see a build on it. Glad your bed side fit well I have a complet new bed to assemble and hope I have similar luck. I vote white under the trim. I think c10kings gumby looks awesome two toned that way
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
09-16-2013, 01:16 AM | #40 | |
As far as the truck goes, I didn't get a whole bunch done, but I did put a new vacuum advance canister on it, reset the points, and put a set of plugs in it, and it really runs smooth now. I also fixed tag light.
10-05-2013, 01:49 AM | #41 |
Since this is going to be a keeper, I decided to rebuild the New Process 833overdrive tranny. It was working fine, and everything inside looks great, but I'm going to freshen it up with new bearings, rollers, synchros, gaskets, and seals for a nice smooth leak-free operation.
These transmissions came factory with a Hurst shifter, so I ordered a shim kit for it and new linkage bushings. It should be fun rowing through the gears with a good, tight shifter.
02-09-2014, 09:18 PM | #42 |
Nice truck! Any updates?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-11-2014, 02:22 PM | #43 |
Tot Roddin'
Nice work!
02-11-2014, 05:11 PM | #44 |
Rusty Nuts
Good looking truck,
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
02-17-2014, 11:01 PM | #45 |
I've just been collecting parts and driving the wheels off of it. It recently rolled over 90,000 miles, and it had 88-something when I got it a few months ago. I gave it a little workout with 20 #60 bags of concrete this weekend. She squatted a little bit, but I didn't have to go far.
03-05-2014, 12:28 AM | #46 |
I put a "Building a Better Way To See the USA" plate on the truck. These plates are little newer than '68, but the colors go well with the truck.
03-11-2014, 09:09 PM | #47 |
Sneak preview!
03-16-2014, 12:04 AM | #48 |
I can't decide if I like the '67 caps or the '68 caps better. What say you?
03-16-2014, 06:42 PM | #49 |
With the blue truck i like the red ones.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-16-2014, 09:08 PM | #50 |
I vote the ones with the black ring and the solid red bowtie to match the emblem on the grille and front fenders.
