Old 09-26-2014, 10:07 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: 1970 c20 l9h 6l90e
Originally Posted by boynton View Post
do you have any pictures of the ls3 manifolds in place? I really thought these would fit too.
+1
Hart_Rod is offline   Reply With Quote
Old 09-29-2014, 12:30 PM   #27
1970C20L9H
Do you have any pictures of the LS3 manifolds in place? I really thought these would fit too.
I did not take any photos. I guess I can do that. I was thinking about maybe relocating the engine 2.5" to the rear by bolting the motor mount perch to what I understand to be the 6 cylinder mounting location and see if that makes any more room for the exhaust manifolds. Either that or I may try out the hooker headers cast iron manifolds. Part number 8501HKR or ceramic coated 8501-4HKR
1970C20L9H is offline   Reply With Quote
Old 09-29-2014, 08:10 PM   #28
bigmone
The Hooker swap manifolds will work and fit great
bigmone is offline   Reply With Quote
Old 09-29-2014, 09:50 PM   #29
1970C20L9H
I took a photo and then I removed the heat shield and tested fitment without it and it was closer to fitting but still no luck.
Here are the photos....
This is with the heat shield obviously. I have a loose bolt in the first flange to hold it in place, the rear of the manifold is sitting about 1.5 inches above where it needs to be...
Now here is a photo with no heat shield. It's close, but no cigar. All of the bolts are in, I started to tighten the bolts but the collector flange is binding on the upper frame rail from below.
Old 09-29-2014, 09:56 PM   #30
Hart_Rod
Hart_Rod's Avatar
those don't look different than the Camaro headers I have (2010+), I wonder if they are Corvette ? Here's some pictures of mine.
Old 09-30-2014, 12:43 PM   #31
1970C20L9H
I assume you meant those look different than the camaro headers you have.
You are right, they are different, and from my research I think they are LS2 exhaust manifolds. Those Camaro manifolds you have look like they would work. Are you using the ECE motor mounts?
Old 09-30-2014, 01:11 PM   #32
Hart_Rod
Hart_Rod's Avatar
That's correct. Those picture are of my Son's 68 with a Porterbuilt setup, so the clearance should be similar to yours. I think the 2010+ Camaro manifolds will work.
Old 10-05-2014, 04:36 PM   #33
1970C20L9H
I am still trying to decide between 2010+ camaro exhaust manifolds or just buying the hookers. People are just asking too damn much for a pair of used exhaust manifolds ($150-$200) and I figure the hookers probably flow better.
Old 10-05-2014, 06:04 PM   #34
bigmone
Go with the Hookers they come in different coatings as well
Old 10-05-2014, 10:18 PM   #35
Hart_Rod
Hart_Rod's Avatar
You can usually get them for about a $100 shipped on the Camaro5.com website.
Old 10-06-2014, 02:46 PM   #36
1970C20L9H
So, I spent $141.25 on eBay for the wrong exhaust manifolds (That includes shipping).
I immediately listed them myself when I realized they would not work for me and sold them for $100 + $20 shipping. Paypal took their cut of $3.78, eBay took their cut of $12 the actual ground shipping charge was $44.45 so I recouped $59.77 from my initial $141.25 investment. So I only lost $81.48 on the deal.
Old 10-06-2014, 04:08 PM   #37
mcbassin
Still Learning
mcbassin's Avatar
Feeling defeated tonight. I received the LS3 exhaust manifolds today and they do not fit either. WTF
I used LS1 manifolds on mine and the worked good. I thought I read trailblazer SS manifolds work good too.
I believe the height of you engine is critical for everything to fit right too. I used the clamshell mounts which raise the
engine up. It also made me have to use a high hump.
BTW, have you checked into the LS-1 site or trailblazer ss site? there are guys that will sell manifolds cheap on there
when they upgrade to headers.
Good luck
mcbassin is offline   Reply With Quote
Old 10-06-2014, 05:10 PM   #38
1970C20L9H
Good luck
I am using the clam mounts also, they bolt directly to the perch from performance online. I think if the engine sat a half inch lower the LS2 exhaust manifolds I bought would have fit. I did not look on any forums, only ebay and craigslist. I went ahead and ordered the hookers with ceramic coating.
Old 10-11-2014, 01:10 PM   #39
1970C20L9H
When I got home from work last night the hooker manifolds were waiting for me...
Here are a few photos of them installed. They fit perfect with plenty of room to breath. I think they look pretty damn nice too.
Old 10-11-2014, 01:13 PM   #40
1970C20L9H
I am ready to move onto fuel now. Is anyone running the stock tank behind the seat with an inline pump?
Old 10-11-2014, 01:48 PM   #41
Xeen
Xeen's Avatar
Very nice, those are the exact exhaust manifolds I would have recommended if I would have seen the clearance issue earlier.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-11-2014, 05:10 PM   #42
bigmone
Yes sir told you man they are great for swaps and they flow great! You can get the O-ring gaskets for the collectors from your local parts store I have the part numbers if u can't find them
Old 10-11-2014, 06:27 PM   #43
1970C20L9H
If its not too much trouble I would love the part numbers.
Old 10-12-2014, 05:39 AM   #44
1970C20L9H
I got the part numbers, They were listed on the instructions that came with the manifolds.
Exhaust manifold to cylinder head gasket part # 12617944
Exhaust manifold to cylinder head bolts part # 11518860 or 11547135
Exhaust manifold outlet seal part # 92202326
Exhaust manifold outlet studs 10mmx1.5 part # 11589264
Exhaust manifold stud nuts 10mmx1.5 part # 15032594
All together about $155 from gmpartsdirect but I already have the manifold head bolts so about $120
Old 10-12-2014, 05:54 AM   #45
1970C20L9H
Anyone have experience with Holly billet inline fuel pump? Part number 12-700? I am thinking about using this, gravity fed, by stock in cab tank.
Old 10-12-2014, 08:34 AM   #46
Xeen
Xeen's Avatar
I have seen several guys do this mod, Holley makes durable reliable fuel pumps, they are a bit pricey but worth it though.
If you go this route you are gonna want to mount the pump inside the frame rail, not in the cab because it would be annoying.
I have also seen several guys do the "in tank" pump mod but unfortunately I can't remember specific builds so I can't point you to them directly.
In the LSX swap section is where you will find them usually in the "budget" builds.
Old 10-12-2014, 12:11 PM   #47
bigmone
All you need is the Oring gaskets and the studs and nuts to hook the pipes up should be under 30$ easily
Old 10-12-2014, 12:15 PM   #48
bigmone
The O ring gaskets actually cross over to Pontiac G8 and a few other cars like the Acadia but not a 2010 Camaro.. The studs are in the help section of most part stores
Old 10-12-2014, 09:09 PM   #49
kitsbeach
kitsbeach's Avatar
This is looking pretty cool.! Love the shop truck look. It'll surprise a few people once the LS is up and running.
Thanks for the pics too. I have an LS swap planned in the future.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 10-13-2014, 12:19 PM   #50
1970C20L9H
Thanks, If yours is original paint and I suspect it is I hope you don't paint yours either. It's beautiful just like it is.
6l90e, c20, l92, l9h, swap
