Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-11-2015, 09:17 PM   #526
wcstory
wcstory's Avatar
Plates came in the other day. Nicely vacuum packed
wcstory is offline   Reply With Quote
Old 05-12-2015, 02:12 AM   #527
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
I'll send you a PM with ordering info.
Originally Posted by Limb hanger View Post
Captain fab,
Would like to purchase one of your power steering adapter plates for my 66.
Thanks!
Old 05-12-2015, 08:17 PM   #528
bowtied4life
bowtied4life's Avatar
Originally Posted by Captainfab View Post
The '68-'86 C series and '87-'91 R series steering boxes all have the same bolt pattern.
Hello Captain, i have a 65 GMC 1500 series 3/4 ton with a 350 conversion engine installed. Would like to purchase the complete powersteering conversion kit for it. Could you send me the cost of this, so i can get the coins together. Thanks
Bowtied4life
1965 GMC LWB 383/700R4
1947 Fleetmaster Coupe Supercharged
1955 Chevy Bel Air LS3/6l90e
2012 GMC Denali 2500HD
bowtied4life is offline   Reply With Quote
Old 05-12-2015, 11:08 PM   #529
Captainfab
60-66 Nut
I will send you a PM with pricing and ordering info.
Bowtied4life
Old 06-06-2015, 11:50 PM   #530
60POR
G'day mates,
1964 C20 from the land down under. My first post on the forum. U blokes have no idea how big a help this forum is to us here on the other side of the world, so a big Thanks to you all. Captain Fab please PM me an invoice for the PS plate including shipping to Sydney Australia post code 2077. via USPS international priority. Thanks again.
60POR is offline   Reply With Quote
Old 06-07-2015, 09:36 PM   #531
bosephus
bosephus's Avatar
Have you done a 60-62 plate yet Captain?
bosephus is offline   Reply With Quote
Old 06-07-2015, 11:51 PM   #532
Captainfab
60-66 Nut
Sorry but no I have not had the time yet. I'm still working 80 hrs a week every week. I keep hoping for a break.
I have sold several of these plates to '60-'62 owners that have done the extra work involved to make them work. There is a thread where one member detailed what he did on his '62 C20. I will have to see if I can find the thread.
Old 07-02-2015, 03:52 PM   #533
The Rocknrod
Moderator
The Rocknrod's Avatar
I found and purchased a Saginaw steering box 7802644 from a 1980-85 full size GM pickup I believe. Also I have made the steering (pitman) arm the same length as the original steering arm (cut and weld) to work with the original steering gear (64 C10) geometry. Did I mess up? Or should I have just kept the original pitman arm length?
Old 07-02-2015, 11:35 PM   #534
Captainfab
60-66 Nut
There is absolutely no reason to shorten the pitman arm for the power steering box. A pitman arm is a critical component. If it fails, people could die.
Old 07-03-2015, 05:50 AM   #535
The Rocknrod
Moderator
Okay. So I use the power steering pitman arm? The one that came on the power steering box?
Old 07-03-2015, 10:31 PM   #536
Captainfab
60-66 Nut
Yes, you must use the pitman arm that is designed for the steering box you chose.
Old 07-08-2015, 11:34 PM   #537
Uptown83
Looking to buy a bracket from you. I have a 66 c10 and got a 77 power steering box with all the steering linkage. I assume I just need the bracket only?
Uptown83 is offline   Reply With Quote
Old 07-08-2015, 11:48 PM   #538
Captainfab
60-66 Nut
If you are using the original steering column, you might find the tube and flange useful if you don't have a drill press and a welder.
Old 07-08-2015, 11:52 PM   #539
Uptown83
I actually am going to use a different column. Either a aftermarket one or if I can find one to use. I kept the flanged tube piece. I have a welder.
Old 07-08-2015, 11:57 PM   #540
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Old 07-11-2015, 03:58 PM   #541
YOLO
Custom Truck Lover!
YOLO's Avatar
I am installing a tilt column. I dont know what year it is yet but I will find out. The engine is a 350 out of a '70 Camaro with power steering. Can I use the gear box and pitman arm from the Camaro or do I need to use truck parts? Will your plate work if I do use the Camaro parts? Thank you
Squarebody guy
YOLO is offline   Reply With Quote
Old 07-12-2015, 01:19 AM   #542
Captainfab
60-66 Nut
No you can not use a car steering box on a truck. The Camaro box mounts on the inside of the frame and a truck needs a box on the outside.
You must use a '68-'86 C series or '87-'91 R series steering box. Since you are using a 1970 power steering pump, you will want a '68-79 C series steering box and pitman arm
Old 07-12-2015, 09:11 AM   #543
jlsanborn
jlsanborn's Avatar
Interesting bit of info here. How do you tell the boxes apart? What's the difference in pumps? Is there an advantage over either the C or R series?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-13-2015, 12:46 AM   #544
Captainfab
60-66 Nut
If you are referring to a car steering box versus a truck steering box, once you look at them you will see what side of the frame they mount on. Of course the '88 + truck steering boxes mount on the inside of the frame as the earlier care do.
The '68-'79 C (and K) series steering boxes have SAE style hose fittings. The '80-'86 C (and K) series and '87-'91 R (and V) series steering boxes have Metric with an O-ring style hose fittings. I have never paid attention if the casting number of the boxes are any different. There was also an option of a variable ration steering box. But I do not know how to ID those aside from pulling one from a truck that has that option listed on the SPID
With the pumps, aside from the early versus late reservoir, I do not know of any way to ID any internal differences. I do know that sometimes when you buy a rebuilt pump, it may put out more pressure than one out of another box. I think that may just be a difference on who and how they installed the pressure relief spring in the pressure port.
Old 07-15-2015, 07:18 PM   #545
speedracer38
Hey Captain. Send me a pm with your paypal info. I would like to order a PS bracket, tube and flange and Brake booster bracket for 66C10 two wheel drive auto trans. Thanks in advance. Joel
speedracer38 is offline   Reply With Quote
Old 07-15-2015, 11:52 PM   #546
Captainfab
60-66 Nut
PM coming your way.
Old 07-24-2015, 10:49 PM   #547
Ghernandez66
Ghernandez66's Avatar
Hey Captainfab can you pm me a quote for a PS kit (braket, tube and flange ) for a 66 c10
Ghernandez66 is offline   Reply With Quote
Old 07-24-2015, 11:23 PM   #548
Captainfab
60-66 Nut
PM coming your way.
Old 08-04-2015, 11:28 PM   #549
Ghernandez66
received my package last Friday as promised, everything was packaged great and instructions are nice and clear I installed the steering box today and it worked great the only thing i did noticed was that in my frame 2 of the holes were next to existing holes and I ended up with 2 elongated holes will this be an issue?
Old 08-04-2015, 11:57 PM   #550
Captainfab
60-66 Nut
You should have had only 1 elongated hole, but you should be fine as long as you used the supplied washers and torqued the bolts to 65-70ftlbs.
