Old 04-01-2015, 10:01 PM   #551
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: My long term 57 project
Originally Posted by Mattyparty View Post
Hey chuck do you know how your doing your steering linkage.
Matt,
I plan to use the joints and shaft that came with the Uni-steer rack.
The pic is from the "Heisenberg" build at Delmo's in Burbank.
Its a tight fit with an LS motor, not sure how it will be with your small block and the Ram-Horns!
Thanks!
ChuckDriver is offline   Reply With Quote
Old 04-05-2015, 11:04 PM   #552
Mattyparty
Originally Posted by ChuckDriver View Post
Matt,
Thanks!
What motor and exaust are you running? All the ones i see im going to have to run three joints and a support bearing. Not looking forward it.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=602142
Mattyparty is offline   Reply With Quote
Old 04-06-2015, 05:20 PM   #553
ChuckDriver
My plan is run an LS3 with a modified set of exhaust manifolds.
Nate says he has a set of headers in the works for the LS, hopefully he will get it done soon! Also, Del in Burbank is currently building two trucks, 1 with an LS and the other is a SBC with Ram-Horns, so hopefully we'll se what he comes up with!
Old 04-06-2015, 06:29 PM   #554
Mattyparty
Ahh. I wish Del still did build threads. I would learn so much from those
Old 04-07-2015, 09:08 AM   #555
jcramsey
jcramsey's Avatar
Didn't realize you were going to run an LS motor....nice!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 04-07-2015, 07:54 PM   #556
Kabwe
Certified Car Nut
Kabwe's Avatar
What did you go and do? I have not been around for a while and you go and change everything? Wow.
Everything is looking great.
Kabwe is offline   Reply With Quote
Old 04-07-2015, 11:08 PM   #557
ChuckDriver
My plan is to run an LS, but the Taxman hit me extra hard this year, so we'll have to wait and see!
Old 04-07-2015, 11:10 PM   #558
ChuckDriver
Yea, kinda jumped off into the deep end! But I'm looking forward to the 2.0 version!
Thanks!
Old 04-12-2015, 08:54 PM   #559
Mattyparty
Chuck how did u do your gas pedel and how did you mount that tac? Any pics would be great
Old 04-12-2015, 11:54 PM   #560
ChuckDriver
I'm out of town this week, will get some pic's for your this weekend!
Old 04-23-2015, 10:28 PM   #561
ChuckDriver
Matt, I mounted the Tach to the column with a cup designed for the purpose. I used a large hose clamp and a strip of clear vinyl.
The pedal is just mounted flat to the floor close to the original location, I plan to move it up onto the angled toe-board to get a little more legroom.
Hope this helps!
Old 04-23-2015, 11:40 PM   #562
Mattyparty
Thanks chuck. I love the look. What kind of tach is it? Did the pod come with it?
Old 04-24-2015, 08:28 AM   #563
Kim57
Kim57's Avatar
Nice tach.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-24-2015, 04:46 PM   #564
ChuckDriver
Matt, Tach came from Classic Instruments and the cup came from summit.
Thanks Kim!
Old 05-18-2015, 10:30 PM   #565
ChuckDriver
Well I was finally able to get some serious garage time over the weekend and made some good progress!
I was anxious about drilling the first hole in the new rails, but after a lot, and I mean a lot of measuring, I jumped to it and got it done.
The new rails look great and complement the PB parts perfectly.
Here are the pics!!
Old 05-18-2015, 10:33 PM   #566
ChuckDriver
And started putting the cab and 4-Bar mounts in place.
Old 05-18-2015, 10:35 PM   #567
Mattyparty
Lookin good. You should sell those rails
Old 05-18-2015, 11:41 PM   #568
ratty 46
If I can ask ... do you intend to weld the front & rear sections where they bolt on or are the bolts & nuts enough?
ratty 46 is offline   Reply With Quote
Old 05-19-2015, 07:40 AM   #569
oldman3
oldman3's Avatar
Wow, that's looking really great...Jim
oldman3 is offline   Reply With Quote
Old 05-19-2015, 07:53 AM   #570
Advanced Design
Advanced Design's Avatar
Nice work Chuckdriver. That is the longest steel rule I've ever seen. Perfect for this application.
Advanced Design is offline   Reply With Quote
Old 05-19-2015, 08:29 AM   #571
Kim57
Kim57's Avatar
Going to be a great looking frame.
Kim
My build thread
Old 05-19-2015, 05:05 PM   #572
RockinKees
RockinKees's Avatar
That is looking great!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-19-2015, 05:48 PM   #573
ChuckDriver
Thanks for the compliments guys!
For now I plan to use Grade 8 hardware to hold it all together, the C-Notch will be welded to the frame.
Would be cool to sell the rails or a complete frame.
Yea, the 6FT rule from Lowes worked perfect!
Need to finish up the mounts and get started on brake and fuel lines.
Old 07-19-2015, 03:00 PM   #574
Fitz57
Fitz57's Avatar
Subscribed, just love this thread.
Question about your frame rails. I need 2- 7' long rails as a sub frame for my 57 body on 05 Silvy 4x4. Hope to have them done at place in Reno Nevada. Do you happen to have the dimensions you gave your shop for the channel dimensions? I'm going to use the original 57 cross members and cab mounts. Thanks
Fitz57 is offline   Reply With Quote
Old 07-22-2015, 08:45 PM   #575
ChuckDriver
The rails are 2.25 X 6.0, used 10ga mild steel.
Hope this helps!
