#51 |
my short bus
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
http://www.classicperform.com/Store/...ruck/CP4R5.htm
here is one way
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
#52 |
Is this spindels the 73-80 style or 81-87 style?
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=55 Looks like great stuff this! |
#53 |
do they make an aftermarket disc with the 4.75 bolt pattern for the C10
78 C-10 5.3 LSX -4L60E |
#54 |
i couldnt find them on that site is do they suit a 78 model ?
#55 | |
i have the 1.25 hd disc with 3" DJM DROPPED spindles and i wanna runn my weld pro star rims on the front!!
#56 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#57 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Sorry for giving out wrong info.
They should spell that out on their website. I apologize.
#58 |
I search POL and CPP's website.
It appears the 5x4.75" rotor are for the 11" 69-74 chevelle rotors (thanks crazy longhorn) that use a custom bracket that attaches to a 63-70 "drum brake" front spindle. These require a 69-72 Camaro caliper. CPP's complete kit, (part# 6370WBK-5) is $375.00. Or just the bracket kit for $119.00. Part#6370DBK Again sorry for the confusion I caused.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-21-2011 at 11:25 PM. |
#59 | |
Happy to be here
![]() Join Date: Mar 2000
#60 |
What the hey.....we are all just working together to find the better way to our "Madness"
#61 |
like crazy longhorn i dont wanna change my spindles how hard would it be to redrill the spindles , and done correctly how safe???
#62 |
Hola gents!
I've read over this thread a few times before joining this forum and am still somewhat confused on this topic. I have a 1984 1/2 ton Silverado. Will the 91 Camaro 1LE performance rotors fit my set up? It's currently a 5x5 and I am really trying to get it to a 5x4.75. Thanks. Posted via Mobile Device |
#63 |
Also wanted to know if I could use these drop spindles with the 91 Camaro rotors.
http://www.ebay.com/itm/400140456280...84.m1423.l2649 The end result I am looking for is to safely get my 84 Silverado to a 4.5 inch pattern with about a 2" drop and that I can use with a 15" wheel. HELP! Posted via Mobile Device |
#64 |
A guy with a truck
Yes, those spindles, designed for 1" thick rotors, will allow installation of the 5x4.75 camaro 1LE rotors. Post some pics here when you get them on!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#65 |
Thanks for the response gringoloco. I really appreciate it and I will definately repost before and after pics. Gonna rebuild the entire front end while I'm replacing the spindles and installing the new rotors!
#66 |
Happy to be here
I dont think those brakes will work with 15" wheels. Talk to way2low2 for advice on what will work.
#67 | |
A guy with a truck
All of that to say this: He should only have the same possibility of lower control arm clearance issues that all lowered 63-87 trucks have when using drop spindles with 15" wheels, depending on wheel backspacing.
#68 |
Happy to be here
Its been a while since I played with Camaro stuff, but I remember when there was a big interest in converting to 1LE brakes. Now that I think about it there was one guy that managed to massage them to fit in the stock 15" Camaro wheel. Most everyone else upgraded to the 16"+ IROC wheels and solved the issues.
#69 | |
A guy with a truck
#70 | |
A guy with a truck
#71 |
A guy with a truck
Got some parts today-early measurements say it's gonna work
#72 |
Gringoloco-
My backspacing on my 15" Centerlines is 1.5 inches at best. They are the 15x3 Convo Pros. So I shouldn't have any issues with the 91LE rotor and those drop spindles I linked right? Thanks again. Posted via Mobile Device |
#73 |
A guy with a truck
I wouldn't think so, but convos are drag wheels which aren't generally known for having great brake clearance. Maybe check around the F-body forums to see if anyone is running that combo...
#74 |
Gents,
Instead of ordering drop spindles could I just replace the front springs instead or cut the ones I have now to lower it a couple of inches? I know it will probably change the geometry a little bit and make the ride a little different but I have seen front spring lowering kits and just wanted to get your opinions. Thanks. Posted via Mobile Device |
#75 |
Guess I can do both do achieve a drop of greater than 2.5 inches. Will post pics soon.
