Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-15-2010, 09:39 PM   #51
Wild83C10
Wild83C10's Avatar
Re: Need some engine advice and suggestions...
That fuel pump P/N doesn't show up, do you mean 11101?
Everything else looks good. I would recommend SS covered teflon hose. I had a problem with the SS rubber hoses pushing/outleaking fumes/vapor and my garage stunk from fuel.
What size fitting do you have out of the tank? Do you have a return fitting?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-15-2010, 09:50 PM   #52
Hart_Rod
Hart_Rod's Avatar
P/N corrected, . I have 10AN fittings in all ports. I was going to plumb the return line to my fuel filler neck. Does the teflon hose bend very easily?
r/
Hart_Rod is offline   Reply With Quote
Old 02-15-2010, 11:22 PM   #53
1FAST68
Looks like you are taking the right advice hartrod. It is going to be a fun ride when you are done with it.
68 chevy truck
ls3, 418ci, pump gas 10.81@121.8 all motor. 1.47 60ft
70 suburban
350 tbi swap, 700r4, work in progress
1FAST68 is offline   Reply With Quote
Old 02-16-2010, 07:17 AM   #54
Wild83C10
Wild83C10's Avatar
r/
No, the teflon line has a large bend radius.
turbo=
Old 02-16-2010, 10:40 AM   #55
nomrlz
nomrlz's Avatar
great build! i love those blow thru vortech and prochargers. that thing will be a beast
nomrlz is offline   Reply With Quote
Old 02-23-2010, 11:43 AM   #56
Hart_Rod
Hart_Rod's Avatar
Thanks guys. Well I pulled the trigger on the fuel system and should have that taken care of in the next week. I have the following things that need to be connected to receive vaccuum/boost signal. My question is where exactly to pull it from, above (A) the butterflys or below (B)?
PCV - B
transmission - A (ported?)
Blowoff valve - B?
MSD BTM - B?
Boost/Vacuum gauge - A
FPR signal - A (according to Aeromotive tech)
Thoughts or suggestions?
Old 02-23-2010, 05:57 PM   #57
1FAST68
PCV - B
Blowoff valve - B?
MSD BTM - B?
trans- Below butterflys
boost gauge-B to see what is actually inside engine
everything else looks good.
68 chevy truck
70 suburban
Old 02-25-2010, 09:29 PM   #58
djracer
djracer's Avatar
Look what I found on my porch.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-06-2010, 06:30 PM   #59
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Man thats a very nice setup you have.
Any more updates?
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-15-2010, 10:33 AM   #60
Hart_Rod
Hart_Rod's Avatar
Any more updates?
I apologize for being slow with my updates, but I have made progress!!
The new fuel system is installed, 10AN supply/8AN return. I cleaned up the engine compartment, including a new radiator and fan setup (with custom radiator holder). I also had a new tank built with a sump and the proper fuel fittings. Everything seems to be working fairly well, although I'm still trying to get the carb, FPR and BOV dialed in. It's running to rich. I've lowered the pressure on the regulator to 5-5.5 psi, but I think the problem is with the BOV not opening enough at low idle. Any suggestions? I know I need a wideband to help with the tuning, but I want to replace the headers first before installing one. Here's some pictures to catch me/you up, .
Old 06-15-2010, 10:41 AM   #61
ripdog28
ripdog28's Avatar
Looking good.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-15-2010, 09:43 PM   #62
Wild83C10
Wild83C10's Avatar
Where do you have the reference line for the BOV running to?
Is the pump sitting higher then the tank?
Looking good.
turbo=
Old 06-15-2010, 10:25 PM   #63
Hart_Rod
Hart_Rod's Avatar
Looking good.
It's connected to the back of the carb, same place as the tranny modulator valve. Pump is below the tank. I think my problems is the adjustment on the BOV. Any ideas where to start?
Old 04-16-2011, 10:07 PM   #64
Hart_Rod
Hart_Rod's Avatar
Can't believe it's been almost a year since I've updated this thread!!!! Enjoy.
Old 04-21-2011, 11:53 AM   #65
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Still looks great, any updated videos?
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-21-2011, 10:36 PM   #66
Hart_Rod
Hart_Rod's Avatar
Not yet. I'm going to get it dyno tuned in a couple of weeks and then I'll play.....
Old 04-28-2011, 10:30 PM   #67
Hart_Rod
Hart_Rod's Avatar
New headers, new exhaust, and electric cutouts, !
Old 04-29-2011, 12:24 AM   #68
Captainfab
60-66 Nut
Sounds great!
Tell me about those stainless headers. What brand? Do they hang below the frame?
Old 04-29-2011, 07:38 AM   #69
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Captainfab View Post
Sounds great!
Here's a thread that tells all about them:
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
Old 04-29-2011, 10:54 PM   #70
Captainfab
60-66 Nut
Thanks for the reply. I've been keeping an eye on that thread for a while now.
Old 04-30-2011, 09:25 PM   #71
Wild83C10
Wild83C10's Avatar
Sounds good and I like the SS headers. I like the muffled exhaust better, just sounds cleaner.
Two things I noticed, your track bar is way off, should be parallel with the ground at ride height. Is your driveshaft too short? I see a lot of the slip yoke in the one picture.
turbo=
Old 05-01-2011, 11:32 AM   #72
Hart_Rod
Hart_Rod's Avatar
The 50 series flowmasters quieted everything down but it still has a good rumble. The cut outs are just to mess with 5.0's and rice burners, .
I had to move the mounting point down on the track bar (more pics in my build thread) because it was interferring with the aluminum rearend cover. It seems to work well at this location. I'm replacing the 4" drop springs with 6" drop springs so that should help level it out some.
As far as the driveshaft, it has approximately 2" that go into the transmission, I assume that is enough? I've got a couple more things that I'm going to do to the suspension that could affect that measurement, when I'm done with that I'll verify that everything is still good.
Old 05-01-2011, 09:44 PM   #73
Wild83C10
Wild83C10's Avatar
You should have about an inch left out of the trans, so that could be around 3" in the transmission.
turbo=
Old 05-01-2011, 10:19 PM   #74
kpeztruck
kpeztruck's Avatar
Rob,
Did you ever do methanol injection? I believe Steve at NewEra Racing engines does this in lieu of an intercooler to reduce detonation. And in turn, run more boost to make huge power. Sorry if it is in the thread somewhere and I missed it, kinda just skimmed through, instead of reading.
Paul Baxter
kpeztruck is offline   Reply With Quote
Old 06-01-2011, 12:17 AM   #75
The Reca
The Reca's Avatar
Gorgeous build. Ever take it down the track? (sorry if you posted it and i missed it)
Any1 from NoVa area?
The Reca is offline   Reply With Quote
