#51 |
Re: How To Restore and Detail an Original Gauge Cluster
Thank you for doing this write up, I am definitely going to use this!!!
#52 |
Just took mine all apart today to see what all I need.
I have some bad overspray black pain on my lens. Does the replacement Lens from someone like LMC come with the speedo numbers and warning light areas already painted on the glass? |
#53 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#54 |
Great write up. Thanks for sharing.
#55 | |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#56 | |
What font style and size did you use for the over speed and tand'm lock? I am looking at century gothic 7 point (size) bold it looks close.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#57 | |
#58 |
![]() Join Date: Aug 2010
great detailed write-up!
Have you had any issues with grounding of the bulbs with the clear coat? Mine has been painted with silver, and occasionally, I'll get a blinker issue, and it goes away after re-seating the bulb socket assy into the cluster... I don't know if the original clusters were painted?
1965 Suburban Waiting on Time and Money |
#59 | |
![]() Posted via Mobile Device
#60 |
I am in the middle of restoring mine and was following this pretty closely.
Now it seems all the pictures are gone. Is this just on my end or did you remove the photobucket pics. |
#61 |
It's not you. Notice that some pics from other folks (mine for instance) are still there. Astronaut must have accidently moved his pics or messed up his account. Don't worry, he'll fix it.
#62 |
Moderator
![]() Join Date: Dec 2012
I think he's just over on bandwidth. They'll come back.
#63 | |
Just making sure it was not me. I was able to complete my project for this. I did not do a full out restoration but rather just touched mine up a bunch. When I get my new motor complete I will start my miles back to zero and actually put the new sticker numbers and letters on. For this go around I did the following; Took apart and cleaned. Wiped down the speedo and gas gauge. Daughter took the model paint and repainted the speedo and gas needle. Painted the bezel Painted the interior and exterior of the encasement Painted the black/green door/window piece. (not sure what its called....the piece that the glass sits on top of). Redone all of the red/green light parts Cleaned up the lens the best I could. It was pretty rough with overspray and scratches. I think it done okay for now. Again, when I get my new motor ready I will replace the lens, bezel, and actual speedo and gas gauge faces. Thank you very much for this thread to help a newbie like myself have the confidence to tackle this. Here are a few pictures. When I first took it apart ![]() ![]() ![]() ![]() ![]() ![]() Some of the process ![]() ![]() ![]() ![]() ![]() Put back together ![]() ![]() ![]() ![]() Again, thank you for your how to thread. It was a big help. |
#64 |
Hey, WOW! That looks great! You did a nice job. There are many great contributors on this website. TheAstronaut is one of them! Did you line the carboard tubes with foil tape?
#65 | |
I didn't do that. I used two 3 layers of the colored transparent stuff and was afraid of it was any brighter when lit up that it would shine through too much. When I hook it up I will know for sure. If its dim I may do that. This transparent stuff is much more thin than the original. Posted via Mobile Device |
#66 | |
#67 |
I'm over the bandwidth allowance for the month... they'll come back once it resets for the month. Your cluster looks great!!
#68 | ||
Thanks. There is more that could have been done for this one but I am happy with the way it turned out. |
#69 | |
I did bench test my gauge lights (all stock bulbs) after my resto and I think the 3 or 4 layers will look just right.
#70 | |
I put a flashlight with about the same brightness in the back and checked them out. I think it will shine nicely when in the truck. |
#71 |
Thank you for your (How to) I have now completed my cluster too.....
#72 |
#73 |
You're welcome, glad to be a help! And great job on the cluster!
#74 |
Pics are back up!
#75 |
This is a great guide. I have been following it step by step. There was only a couple of places I changed things.
On the intermediate plate I was able to soda blast and came out without any warping or pitting. Did a nice job. Also on the back of the intermediate plate I used Krylon Glowz to see if that will help with a brighter cluster. Here is the Glowz http://www.krylon.com/products/glowz/ Still waiting on a few parts to finish, but will post some pics once I'm done. |
