Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-17-2013, 10:03 AM   #51
JJH Jimmy
JJH Jimmy's Avatar
Re: Project "It's a Jimmy Thing"
I got a tilt column from a fellow board member the other day.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 06-18-2013, 02:18 AM   #52
Russell
Professional Grade
Russell's Avatar
I am guessing you must be an industrial instrumentation mechanic? My truck is filled with swagelok stuff too, haha!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-21-2013, 01:30 PM   #53
JJH Jimmy
JJH Jimmy's Avatar
A little bit of progress. After 2 rolls of masking tape i got the body all masked off for the Raptor Liner. Then the hard part started when i had to scuff up the epoxy primer. My arms felt like jelly after that. I sprayed 2 and a half kits of the liner on outside and i think i pissed my neighbor off because they were having a graduation party when i was spraying with a breeze in their direction. Oh well, i wasn't invited so how was i to know. Haha. I think that it turned pretty good. I just hope it holds up good and doesn't start flaking off in time.
1985 Chevy K20
1994 GMC Yukon
Old 06-21-2013, 01:36 PM   #54
JJH Jimmy
JJH Jimmy's Avatar
More pictures.
1985 Chevy K20
1994 GMC Yukon
Old 06-21-2013, 01:41 PM   #55
JJH Jimmy
JJH Jimmy's Avatar
More pictures.
1985 Chevy K20
1994 GMC Yukon
Old 06-21-2013, 08:52 PM   #56
my90k5
72 K/5 Junkie
my90k5's Avatar
You give classes? Lol, excellent work!
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 06-23-2013, 11:14 AM   #57
Thealien
Thealien's Avatar
Nice work, patiently waiting for updates.
Old 06-24-2013, 09:55 AM   #58
Hart_Rod
Hart_Rod's Avatar
Nice build!
Hart_Rod is offline   Reply With Quote
Old 06-26-2013, 10:24 AM   #59
JJH Jimmy
JJH Jimmy's Avatar
Haha. Thanks, but i am the one that is going to need lessons soon when i get to the wiring.
Thanks, I am sorry you have to sell your Jimmy. Hopefully you can find a way to keep it.
Originally Posted by Hart_Rod View Post
Nice build!
Thanks.
1985 Chevy K20
1994 GMC Yukon
Old 06-26-2013, 10:35 AM   #60
JJH Jimmy
JJH Jimmy's Avatar
I got the body back on the frame exactly a year from the day i brought it home. Only one small problem. The upper tranny line was rubbing on the tunnel so a $25.00 AN 45 took care of that. I put the doors on to shim the body to get the correct gaps and then locked it all down. I think i got it close to where it needs to be and i can final adjust in the hinges during final assembly.
1985 Chevy K20
1994 GMC Yukon
Old 06-26-2013, 10:52 AM   #61
JJH Jimmy
JJH Jimmy's Avatar
Here are a couple of pictures of the rotisserie that i cobbled together from some scrap steel i had laying around. It worked out better than expected. I hauled it on my trailer to the place i blasted it and to my painters shop without any issues.
1985 Chevy K20
1994 GMC Yukon
Old 06-26-2013, 10:59 AM   #62
JJH Jimmy
JJH Jimmy's Avatar
Door alignment pictures. As you can see i still have the doors and fenders to work on. Luckily they are in great shape except for the the drivers side fender which has a nice large dent in the center of it that i am going to try to save.
1985 Chevy K20
1994 GMC Yukon
Old 06-26-2013, 12:22 PM   #63
jaros44sr
jaros44sr's Avatar
Nice work!! Those LS engines look so right in the K5s, well done. Following your lead on the fuel lines, thanks for the help
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-30-2013, 08:54 PM   #64
JJH Jimmy
JJH Jimmy's Avatar
I agree! It looks like ls engines were made for these. No problem. Glad i could help.
I got a little bit done. I installed some sound deadner, the center section of the insulation pad, computer, harness and the TAC module. The TAC module mount looks a little ghetto but i don't think you will be able to see it very well.
1985 Chevy K20
1994 GMC Yukon
Old 06-30-2013, 08:58 PM   #65
JJH Jimmy
JJH Jimmy's Avatar
A couple pictures of the harness.
1985 Chevy K20
1994 GMC Yukon
Old 06-30-2013, 09:09 PM   #66
JJH Jimmy
JJH Jimmy's Avatar
I also bought a radio and a dash bezel. I got the dash bezel from a guy on ebay for $59.00. I know there is a guy on the board that sells these as well but i think it takes him a while to get them built and shipped, although i am sure the quality of his is better than this one. It was shipped raw finish so i just used some aluminum polish and a cotton wheel on my die grinder to polish it up a bit.
1985 Chevy K20
1994 GMC Yukon
Old 06-30-2013, 09:46 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
Everything looks fantastic so far!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-15-2013, 08:18 AM   #68
JJH Jimmy
JJH Jimmy's Avatar
I got my steering column torn apart, painted and installed with one of ls1nova71's cruise levers.
1985 Chevy K20
1994 GMC Yukon
Old 07-15-2013, 08:24 AM   #69
JJH Jimmy
JJH Jimmy's Avatar
I also got a whole pile of misc. parts blasted and painted.
1985 Chevy K20
1994 GMC Yukon
Old 07-15-2013, 08:31 AM   #70
JJH Jimmy
JJH Jimmy's Avatar
I got the radio, parking brake assembly, ash tray and the drivers side sound deadner and insulation pad installed.
1985 Chevy K20
1994 GMC Yukon
Old 07-15-2013, 09:52 AM   #71
youngrodder
youngrodder's Avatar
Nice project. I'm in your same neck of the woods, just off Spinkle Rd. South of Centre .
Looking good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-15-2013, 10:26 AM   #72
JJH Jimmy
JJH Jimmy's Avatar
Looking good.
Marc
Thanks. I saw your truck going down 9th street on Saturday! What year is it? I would like to check it out sometime. I have a 51 5 window that will be my next project.
1985 Chevy K20
1994 GMC Yukon
Old 07-15-2013, 12:57 PM   #73
jaros44sr
jaros44sr's Avatar
Nicely done...that radio looks great in there
Howd you like puttin that tilt back together. Thanks for the pics
SAFETY FIRST
AS usual, off topic
Jim
Old 07-15-2013, 01:35 PM   #74
youngrodder
Mine is a 48 Chevy. I have a friend in Schoolcraft with a 50 5-window.
I'm ussually not in that neck of the woods but my wife and I took a truck ride over to South Haven for dinner. It turned out to be a great night for a drive.
Your welcome to check the truck out anytime.
Marc
Old 07-15-2013, 02:40 PM   #75
JJH Jimmy
JJH Jimmy's Avatar
Thanks, The tilt was kind of a pain in the butt. After i tore it apart i put it back together before i painted it just to make sure i could do it. I still scratched it during final assembly though.
1985 Chevy K20
1994 GMC Yukon
