Old 01-04-2014, 06:47 PM   #51
stevenbear72
stevenbear72's Avatar
Re: Project "Black Cherry" 68 c/10
Not sure if I will use Nelson for a tune, I have a good rapport with PatrickG in Victoria for tuning my LS vehicles.
But I'm curious as to how much Nelson charges for their harnesses. I called and left like two messages, still waiting on a response.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 01-08-2014, 02:01 AM   #52
stevenbear72
Question Re: Project "Black Cherry" 68 c/10
Def not going with a Nelson harness, they wanted $1,100 for a simple harness with the fan relays and extending the harness for the computer to fit under the dash.
I'm having a hard time finding the thread where people put what all is done to their build and attach a PDF or Word Doc of the list of all the parts they have installed. Would anyone be able to post a link to that thread please?
Old 01-08-2014, 09:34 AM   #53
solidaxel
solidaxel's Avatar
You may want to take a look at Howell Engine Development and talk to Troy, there base harness has a 4ft tail, and longer for additional cost.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-08-2014, 07:18 PM   #54
not2oldchevy
PSI makes a good harness easy to use.
not2oldchevy is offline   Reply With Quote
Old 01-09-2014, 12:12 AM   #55
stevenbear72
That's what I heard from a fellow co-worker who is here on the boards as well. I believe their base harness is about $550, I'll need to have them add for the fan relays and the 90mm tb that I changed out.
Old 01-09-2014, 12:14 AM   #56
stevenbear72
this was the thread I was referring to in regards to people who add their build sheets, good stuff
http://67-72chevytrucks.com/vboard/s...d.php?t=473560
Old 01-09-2014, 06:55 AM   #57
apachedaddy
apachedaddy's Avatar
I'm having an issue with the bottom of the 90mm tb hitting the neck of the water pump, need some advice as to what you guys would do in this situation?
I havent delt with the bigger TB, but could you mount it up side down and forego the new water pump??
EDIT= Never mind i didnt take in account for the ALT...
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 02-07-2014, 12:41 AM   #58
stevenbear72
I was going to just buy the Dirty Dingo billet adapter plates for the ls2 style water pump to be used with the truck accessories, but it will just be cheaper for me to buy the 6.2 newer style pump.
Old 02-07-2014, 11:41 AM   #59
Hart_Rod
Hart_Rod's Avatar
The 2010+ Camaro water pump works great (no adapters required - its the same offset), or like stated, just flip the TB 180.
Hart_Rod is offline   Reply With Quote
Old 02-07-2014, 06:17 PM   #60
Houston Ben
Houston Ben's Avatar
Steven, For what it's worth I used 150tunes.com to rework my wire harness for $250 and had no problems except for their busy and it takes a while.
Houston Ben is offline   Reply With Quote
Old 02-08-2014, 11:05 PM   #61
stevenbear72
Never heard of that company, but Ill look into it, since I already have a stock harness.
As for flipping the TB, is that possible? Never seen anyone run it like that.
Old 02-08-2014, 11:12 PM   #62
stevenbear72
Btw, I already ordered all my black -6an fuel fittings, nylon braided fuel hose, vette regulator/filter, and decided to buy a TBSS intake with the rails and injectors since it already has the opening for a 90MM tb and also is meant for a 4bolt design tb as well as it having a return-less style fuel rail on it. I'm gonna ditch my stock 5.3 intake and that aluminum tb adapter plate. Just in case anyone might be interested in it.
Old 02-19-2014, 05:02 AM   #63
stevenbear72
Got my intake and fuel fittings and fuel line in.
Old 03-22-2014, 06:49 AM   #64
stevenbear72
Got my pump in.
and doing some work to my bracket and alternator housings
Old 03-22-2014, 07:53 AM   #65
Houston Ben
Looking good man!
Old 09-25-2014, 11:51 AM   #66
stevenbear72
A little update, got some nice billet pulleys, and an underdrive pulley.
Old 09-25-2014, 02:33 PM   #67
stevenbear72
I'm clearly too dumb to figure out how to edit a post, or this message board doesn't allow it, anyway, pics...
Also replaced some bolts with some other bolts
5.3 swap, c10, help me please, ls swap, swb fleet side
