Old 02-20-2014, 12:59 PM   #76
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: kyb shocks/ part numbers
After re-reading thru this whole thread, I compliled the following spread sheet to get all this discussion into one post:
Hope this helps everyone....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-11-2014, 12:27 PM   #77
Steve Cole
Thanks aggie91,
I'm confused now more than ever.
Steve Cole is offline   Reply With Quote
Old 09-21-2014, 12:57 AM   #78
NEWFISHER
NEWFISHER's Avatar
Looking for some rear shocks for my build and stumbled onto this great thread.
Bump
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 09-21-2014, 09:15 PM   #79
POPO1984
POPO1984's Avatar
Good info
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 02-08-2015, 07:40 PM   #80
Jferrante
Jferrante's Avatar
After reading all the shock threads I went with the 344068 (front) and 344067 for the rear Both sets bought on Amazon for $74 shipped and free returns; cant beat that- I have a 64 c10 with bags no cnotch and my ride is terrible - I will report back when they arrive and I get them installed (if they fit)
Jferrante is offline   Reply With Quote
Old 02-12-2015, 12:24 AM   #81
Jferrante
Jferrante's Avatar
got the fronts on tonight only had to file down the socket housing slightly to get it to fit. The rears im going to need to do the same thing but they will need filing to fit. will report back this weekend.
Old 02-12-2015, 01:12 PM   #82
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you using the rear shock relocators?
Without them the shock angle is way too flat to make the shocks work.
Keith
Convert to disc brakes.
Old 02-12-2015, 01:46 PM   #83
Jferrante
Jferrante's Avatar
I believe I do - here is the picture I took after I soaked the Rears with Penetrating oil - From what I have seen those are shock relocation brackets. Also when I mocked up the new shocks they seemed to fit right in place, just needed to grind the eyes down to slide in.
Old 02-12-2015, 04:16 PM   #84
lolife99
lolife99's Avatar
Those are the stock shock mounts.
Still riveted in from the factory.
Keith
Old 02-12-2015, 04:26 PM   #85
Jferrante
Jferrante's Avatar
Thanks for the clarification; the shocks I purchased (344067) - that I think you mentioned seemed to fit right it. I will try and get under tonight and report back - if not by end of the weekend.
Old 02-13-2015, 10:25 AM   #86
SCOTI
SCOTI's Avatar
They might fit but the angle keeps them from working correctly (even if they're better vs the current units). If you drop a truck arm equipped truck, you need to relocate the shock to a more 'upright' position.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2015, 12:08 PM   #87
Jferrante
Jferrante's Avatar
Good information - Since I haven't put them in I will order some relocators.
Old 02-13-2015, 01:06 PM   #88
SCOTI
SCOTI's Avatar
For your 64, the budget approach would work.....
http://67-72chevytrucks.com/vboard/s...d.php?t=451200
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-25-2015, 09:26 PM   #89
Jferrante
Jferrante's Avatar
New issue I have run into - the front right shock seems to bottom out before the front left when dropping my bags.....any idea on why this would be? Just bought front shock relocators so will be under there this weekend. Part number 344068 btw.
Old 02-25-2015, 11:47 PM   #90
SCOTI
SCOTI's Avatar
One shock has slightly more resistance vs the other?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-28-2015, 04:50 PM   #91
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
What about if your running porterbuilt. Front and rear shocks?
Sick5 is offline   Reply With Quote
Old 01-06-2016, 05:06 AM   #92
GMCPaul
I'm surprised none of our customers have responded as we've told all that ask.
ANY, I REPEAT AMY, shock that is made for your stock 1967-72 truck at normal ride height is ALSO the correct shock for those trucks with front & rear drop kits of ANY DROP Height. So if you use 1-5 1/2" drop in the front you still use the same shock. If you use 1-6" drop in the rear you still use the same shock. ECE, No limit, Classic, Brothers, everyone is selling shocks that are made to stick travel specifications. Now your asking why this is true. The reason is with any of the drops I listed above the stock shocks minimum & maximum travel distances are not exceeded. Since the shocks travel limits are still within spec, the stock shock length is still used.
NOW in the rear once you hit about a 5" rear drop the shock has become to horizontal to absorb vertical travel effectively. So you then install rear shock relocators in the rear to make the shocks more vertical again so that they can then absorb the vertical travel of the truck. ( It's also my understanding though I have not tried it yet, that if you move the rear lower shock bracket from left side to the right, and the right side to the left this will also correct the shock angle back to a more vertical position eliminating the need for rear shock relocators. ) But again I've not checked this myself on just swapping the lower mounts from 1 side to the other. I'm just reporting what I've heard from several low budget builders.
So everyone out determine the type of ride that you want based on you and your driving habits then look up the shocks and look for comfort, sport, off road etc.... based on your driving style & preference's and then purchase the stock shock for your truck in that type of shock. KYB GR-2 soft comfortable ride, KYB gas a just shocks give a firmer ride , etc.....
Then buy from who you choose. If your already buying parts from 1 location and the shocks they have only cost a little more than the cheapest place you've found get the shocks from where your buying your other parts unless your getting free shipping.
Hope everyone is Healthy, Happy, & Prosperous in 2016 and beyond.
Paul @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 01-19-2016, 05:44 PM   #93
Coursey
Coursey's Avatar
Originally Posted by Loenuf74 View Post
Will the KYB 344055 and 344068 shocks work with a bagged 64 with 2.5" drop spindles and a bolt in notch in the back? Thanks
Wondering What you found out? I have a similar setup with a 66 burb
Coursey is offline   Reply With Quote
Old 03-09-2016, 01:45 PM   #94
indianpride77
indianpride77's Avatar
just curious if anyone knows what numbers i should look for for a 76 with a 3/4 drop??
indianpride77 is offline   Reply With Quote
Old 03-29-2018, 09:43 AM   #95
mcbassin
Still Learning
mcbassin's Avatar
This is an old thread, but I'm wondering how everyone likes their KYB shocks that they have installed over the years for lowered trucks?
mcbassin is offline   Reply With Quote
Old 03-29-2018, 10:06 AM   #96
KY_GMC
KY_GMC's Avatar
I installed the standard KYB Excel -G shocks (black) from the ECE lowering kit and wish I had upgraded to the Gas-Adjust (gray). The ride could be stiffer for a more sporty ride.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 04-01-2021, 08:21 PM   #97
weq92f
weq92f's Avatar
Bumping this great thread...
Needing new front shocks and wanting to go back with KYB which is already installed, I was getting no traction until I found this thread.
ECE, right now anyway, is gone. Just ordered a set of 344068's from Summit.
EDIT: next day: got an email this morning stating that my new shocks are on the delivery vehicle. Guess it helps to live within an hour's drive of the SummitRacing warehouse! i would have burned more than the 10 dollars shipping cost worth of fuel to drive my BBC truck to pick them up! Happy Camper here.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 04-25-2021, 03:03 AM   #98
C10_ForDad
I hate to add onto a old thread. But it's perfectly timed. I was wondering does anyone know the part number for the kyb's for a level 3 rear dropmember? I can find them with a eyelet/stud. But not an eyelet/eyelet.
Thanks!!
C10_ForDad is offline   Reply With Quote
Old 04-25-2021, 06:35 AM   #99
jjzepplin
jjzepplin's Avatar
Paul @ GMCPauls
This is good info!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-25-2021, 12:01 PM   #100
weq92f
weq92f's Avatar
-klb
Got my 344068's installed up front. This mostly cured the issue I was trying to fix: bouncy front end hitting the stops when driving over just the right frequency of rises and falls in the roadway at the right speed ( too fast ).
However, it's still a bit soft for my liking so...I now realize I should have got the gas adjust version of these KYBs. Guess I'm going to order those now. Hopefully I can use these 344068s in the rear!
-klb
