Old 06-24-2015, 03:15 PM   #76
RockinKees
RockinKees's Avatar
Re: 1956 Chevy Pro-Street Build
It looks very agressive and fast, even without the cab!
NICE!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-24-2015, 03:19 PM   #77
ptc
ptc's Avatar
My next big endeavor is to get a roll bar into the cab. Just a rear hoop and then door hoops to the front. So it would be a 4 point roll bar with floor plates at the front and rear corners.
So some thinking questions here... What do you guys think I should do?:
1. Re-inforce the undercab and connect the roll-bar foot plates to just the cab itself?
2. Add plates to the frame and bolt the bar foot plates thru the cab floor to the frame?
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 06-24-2015, 07:37 PM   #78
ccreddell
ccreddell's Avatar
2.
And Id run a front hoop too.
ccreddell is offline   Reply With Quote
Old 06-25-2015, 12:10 AM   #79
mud.man.rj
mud.man.rj's Avatar
I agree with #2, Have seen a few rollovers with floor plates not turn out very well.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 06-25-2015, 12:43 PM   #80
ptc
ptc's Avatar
Originally Posted by ccreddell View Post
2.
Yea have planned on connecting the front legs with a tube across behind the dash. Have to fit my air conditioning first!!! LOL
-Air in a drag racer???? yea it gets hot here in SAC!
Old 07-19-2015, 11:08 AM   #81
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Really cool build
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 08-03-2015, 02:07 PM   #82
ptc
ptc's Avatar
Been working and playing with the truck here and there.... Still working on the bed getting things done. Got all the patch work done on the side panels and all the holes welded up. The neighbor took his welder back for a while on some of his own MOPAR projects.... so Im down on the metal work for now.
Got the new tailgate mounted with the hidden latches and the MAR-K hidden hinges. Everything went together pretty easily working with new stuff. Got the rear rail uprights all cleaned up and then mocked up the new LED tail-lights that fit just perfect on there. Was thinking of 'frenching' them in but... this is just an old race truck, not some show queen!
I mounted up the new fenders tight and I am starting work on the new bed framing that will hopefully support it all and make it only a 4 BOLT mounting to the frame. With quick disconnects for the lights and other stuff in there, its going to be the only way to change tires!!! I hope I never get a rear flat on the highway! Thats what AAA is for right?
Also tried some new and different rims on the rear for when Im OFF-track.... These are 18" DIA x 15" wide rims!!! I can get a deal on them but finding tires to fit is the hard part. Even M/T stopped making the 30x15x18" radial tires.... thats a bummer.
Old 08-03-2015, 02:17 PM   #83
ptc
ptc's Avatar
Recently completed the rear Wilwood brake system installation onto the 9" FORD rear housing. This dude is gonna stop as fast as it goes!!!!
I chose to go with the Wilwood Dynalite Series 4-piston Calipers and the 12.19" Dia. x 1.25" rotors on the rear because it is a truck and not much weight back there anyway. I also went with non-drilled rotors because they will last a lot longer with what I am doing with them. I have found from my 'road-racing track experience' that the drilled rotors crack really early with all the heat cycling. These are aluminum hats also and they are universal for 3 lug patterns.
Heres some more pics
Old 08-03-2015, 02:20 PM   #84
ptc
ptc's Avatar
Heres some more pics of the tailgate install and the LED tailights I found and used. These are trailer lights - Brake, Tail, Turn and they are like 15" long and 1.25" wide.
and got my new CALI plates !!!! I am erasing the dmv.com crap on there - why should I advertise for them!!!
Old 08-03-2015, 05:45 PM   #85
Advanced Design
Advanced Design's Avatar
Looks good! Really like the Wilwood brakes. The tail lights will be very noticable.
Advanced Design is offline   Reply With Quote
Old 08-04-2015, 03:12 AM   #86
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-04-2015, 01:32 PM   #87
slammed57
slammed57's Avatar
awesome brake set up...comin along nicely
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 08-05-2015, 02:20 PM   #88
ptc
ptc's Avatar
Thanks guys! - I think the cab is going to be going on this weekend so I can start getting things a bit more mocked up for the roll bar and all the inner workings inside of it....
Ill have to 'entice' a few extra workers to come over with some smoked tri-tip, baked beans, grilled potato salad and some cold beverages! mmmm!
Old 08-18-2015, 02:44 PM   #89
ptc
ptc's Avatar
Ok so we got the cab on this weekend and I finished up some of the little PIA things that needed to be done to move this forward a bit more.
So out with the old Chebby 3600 frame and in with the new custom "PTC frame"!
Hoisted it up and moved it onto the new one.
And a shot of my crew!!! 2nd and 3rd generation hot rodders!
Old 08-18-2015, 03:38 PM   #90
RockinKees
RockinKees's Avatar
Looking good, PTC!!
Smiling crewmembers, always nice to have
Cheers!! Kees.
Kool Guyz CC
Old 08-18-2015, 07:09 PM   #91
mud.man.rj
mud.man.rj's Avatar
You must be getting excites cause I am, very interesting build, always like to see more, nice to have it on the new frame.
5.0 4spd std.
7" lift w 35's.
Old 08-18-2015, 07:55 PM   #92
Advanced Design
Good progress and a great crew you have!
Old 08-18-2015, 08:25 PM   #93
Kim57
Kim57's Avatar
Nice progress.
Looks sweet.
Kim
My build thread
Old 08-18-2015, 08:57 PM   #94
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice!
ChuckDriver is offline   Reply With Quote
Old 08-19-2015, 01:28 PM   #95
ptc
ptc's Avatar
I am way too excited!... already had a milkcrate in there with the grandson on my lap and we were already cruising the boulevard! (in my mind) yea I know thats illegal these days but he'll have a car seat in there!!!! lol
soon enough.
Thanks guys for all the comments, this is really a labor of just loving to do this kinda of stuff..... Im sure Ill change my mind when the sanding and paint prep comes along....
Old 08-19-2015, 06:53 PM   #96
mud.man.rj
mud.man.rj's Avatar
Ahhh, sanding and paint prep is the worst for most people, but sure great when your done it.
5.0 4spd std.
7" lift w 35's.
Old 08-25-2015, 04:31 PM   #97
ptc
ptc's Avatar
Well I guess I gotta get serious now.... the wife told me (after Ive been sluffing off for the past couple weeks waiting on a neighbors welder) "If ya need some proper tools then just go buy them and get back to work"....
OK!!!!!
So I got me some new tools!!!
230V Welder 175 Mig Gas
230V Plasma Cutter
Sand Blasting cabinet
San Blasting Pot
and all the gear to with this stuff
Plus a new creeper, welding cart, helmet, apron, gloves, hammer/dolley set, brake vac and tube bender.... whew.... shopping spree.
Cant wait till next month when the bill comes in!!!!
Old 08-25-2015, 10:57 PM   #98
Kim57
Kim57's Avatar
New tools are always great.
Kim
My build thread
Old 08-25-2015, 11:37 PM   #99
mud.man.rj
mud.man.rj's Avatar
Wow, now that's tools, thought you were buying just a welder, good thing you listened to the wife..
5.0 4spd std.
7" lift w 35's.
Old 08-26-2015, 11:24 AM   #100
ptc
ptc's Avatar
She's the Boss, and the safety steward... so I guess I have to listen to her!
