Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-15-2011, 12:58 AM   #101
jmedero
jmedero's Avatar
Re: 68 Burb... here we go!!
thanks...now I just need to find a deal on a front kit or pull out the sawsall!!
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 05-15-2011, 10:02 AM   #102
Hart_Rod
Hart_Rod's Avatar
Progress!!
Hart_Rod is offline   Reply With Quote
Old 05-15-2011, 11:52 AM   #103
kev2809
low n' slo
kev2809's Avatar
looks good man! maybe you could cup your lowers...that would help some. but i think a z will be cheapest solution at getting an even drop.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-15-2011, 01:23 PM   #104
likaroc13
Rollin' Old Skool
looking good Juan!
Old 05-15-2011, 01:34 PM   #105
jmedero
jmedero's Avatar
Clearance on the cupped lowers is a concern to me Kevin. I've heard some horror stories.
Old 05-16-2011, 01:11 AM   #106
Bigblueburban
Bigblueburban's Avatar
Love those wheels always have. Looking good low. Can't wait to see the front down more.
Bigblueburban is offline   Reply With Quote
Old 05-16-2011, 01:31 AM   #107
jmedero
jmedero's Avatar
Bigblueburban you and me both. I already have the sectioned crossmember ready to put in. Thinking about a z as well. Who knows what I'll do. Lol.
Old 06-06-2011, 03:40 PM   #108
kev2809
low n' slo
kev2809's Avatar
hey..any updates?
did you ever figure out if your going to change your rear airbags? i just switched mine to over axle setup this past weekend and im in the same boat. it gets super low but the lift isnt great. i really dont want to ride around with like 90 psi in the rear lol
-_--_--_ _________
Old 06-06-2011, 06:05 PM   #109
jmedero
jmedero's Avatar
Well I have been busy on it but not in picture worthy stuff. Just centering the wheel, making a TON of adjustments and stuff like that. I am going to run a 2 inch spacer under my rear bags. That will be plenty for me. I got my air zenith comp bracket welded up, tank mounting location fabbed up and working on plumbing. Nothing exciting except for each step gets me closer.
Old 06-17-2011, 09:27 PM   #110
jmedero
jmedero's Avatar
well here are some pics of the stuff Ive been working on. I have the comp mounted, tank mounted, and the rear brakes installed.I still have to make some hold down brackets for the rear brake lines. I need to figure out the emergency brake cable hold down tabs...
As I look at what the exhaust is going to look like.... its is going to be TIGHT!!! Now if I dump it before the rear tire should be a lot easier. I also have the rear spacers fabbed up for my bags.
tinking along... SLOWLY lol
Old 06-17-2011, 09:33 PM   #111
jmedero
jmedero's Avatar
Ive also got to figure out my filler neck tube. Looks like the angle wont let me just shorten the factory one down. I was looking into a fule door swap from a newer vehicle so I could also get a fuel door.
Old 07-03-2011, 12:35 AM   #112
jmedero
jmedero's Avatar
well Ive got a small couple of things done. I have been swamped at work this week and helping my wife build a new set for the kids at work. She is a kids pastor at our church and is changing all the sets and props for her program. I have built a replica C130 jet after the Blue Angles. Its wing span is 26 feet, 7.5 feet high, and 6 feet wide.... its has been crazy.
I have my bag spacers made and installed. I also made the harness to wire up my Accuair manifold to an AVS 7 switch box. It took some figuring out to find the correct male plug. After some research found out its a Molex brand plug. Create an account, sign up as a distributor and vioala... Molex male plug and supplies in the mail.
Here are some pics... I like to keep it simple and clean as possible.
Later guys.
Juan
Old 07-03-2011, 02:02 AM   #113
Mulk
Mulk's Avatar
Very clean. Looks like it was made that way from the beginning. Nice job
Eric
'68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Mulk is offline   Reply With Quote
Old 07-03-2011, 09:21 AM   #114
jmedero
jmedero's Avatar
Thanks man. Just trying to get it back on the road. I miss driving it.
Old 09-13-2011, 01:23 AM   #115
jlmattin
Keep up with all the pics, always cool to wach a build come tegether.
jlmattin is offline   Reply With Quote
Old 09-13-2011, 05:57 AM   #116
kev2809
low n' slo
kev2809's Avatar
any updates?
-_--_--_ _________
Old 09-13-2011, 08:40 AM   #117
jmedero
jmedero's Avatar
I have been doing little things. I did get my rear shocks, and have built the rear bridge cover. I'll post up some pics tonight.
Old 09-13-2011, 02:00 PM   #118
Hart_Rod
Hart_Rod's Avatar
Slacker.........
Old 09-30-2011, 08:12 AM   #119
badblu97
Double 6's
badblu97's Avatar
uh....Im embarrassed....I had no idea you had a build thread. jeez I am a slacker.
Street Glidin!
1966 LWB Custom Cab (sold)
1982 Short Fleet (under the knife)
1998 S10 2wd Fleet
2007 Chevy Silverado Crew
2007 Harley Davidson Street Glide
badblu97 is offline   Reply With Quote
Old 10-01-2011, 12:32 AM   #120
jmedero
jmedero's Avatar
Ok here we go. It seems like this summer just flew by. Had a million things come up and I got side tracked on the burb. I needed some motivation to get back on it so this is what I did. I contacted Joseph Durant with Eastside Design Lab and started working on a rendering. Joseph is awesome!! His mind seems to run a million miles a minute. He helped me get some stuff figured out with color and body mods. Had a 30 min conversation with him, he checked out my build and got started. This is what we came up with. I was thinking of a diff shade of blue but when I saw this one I was sold.
some of the mods are
-front roll pan
-one piece windows
-shaved EVERYTHING!! lol.
-rear roll pan
-painted front trim to match silver roof
-painted smothies centers to match silver roof
I am so stoked to get started on her again. Im going to pulll her out of the garage and clean the whole shop up. Once its all clean and tidy im going to hit her hard!! Enjoy guys and let me know what you think.
It was between the blue and the green.
Old 10-01-2011, 12:38 AM   #121
jmedero
jmedero's Avatar
here is the contact info for Joseph Durant if anyone is interested. I would recomend him to anyone. I will be doing some changed on my Nova and he will be doing a rendering for it as well.
josephdurant@att.net
832-597-7912
Old 10-01-2011, 12:59 AM   #122
VA72C10
VA72C10
VA72C10's Avatar
Both of them look really good. The green one is a little more custom looking to me for some reason.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-01-2011, 07:20 AM   #123
jmedero
jmedero's Avatar
I love the green one. I just can't get that shade of blue out of my head from the moment I saw it.
Old 10-01-2011, 10:24 AM   #124
likaroc13
Rollin' Old Skool
i'm a sucker for blue (my favorite color, lol)....the rendering looks awesome!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-01-2011, 10:35 AM   #125
kev2809
low n' slo
kev2809's Avatar
those are some good renderings....
im diggin the blue one...green is always risky to me..
-_--_--_ _________
