Old 01-07-2014, 10:13 PM   #101
chakah
chakah's Avatar
Re: How To Restore and Detail an Original Gauge Cluster
I know what's next on my "to do" list now. Thank you astronaut, this is a great write up. Very well in detail man.
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 01-07-2014, 10:36 PM   #102
speedy_steve
Looking forward to this exercise!
speedy_steve is offline   Reply With Quote
Old 01-07-2014, 10:54 PM   #103
theastronaut
theastronaut's Avatar
Originally Posted by 64shortc10 View Post
How much you charge for a 64-66 cluster with tach, and clock installed? The tachs work with hei distributor don't they? You do such nice work!Thanks
Tony from Norcal
Thanks Tony, I'll send you a PM about your cluster. I'm not sure about the factory or aftermarket tachs working with an HEI. I searched and found a topic about that, stated that you may have to use a tach filter in the wiring. For a clock, Jason at Greenback has the most factory-appearing clocks I've seen. I haven't tried a clock yet myself.
Here's that thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=376080
Originally Posted by VonDog View Post
Hey astronaut, thanks soooo much for this thread!!! I rebuilt mine in my 60 K-20 about a month ago and it's Awesome! Now the speedo and odometer work and the fluorescent red is spot on! This site is so fricken cool!!! Thanks again!
Glad the thread was a help, and your cluster turned out great!
Thanks dudes!!
theastronaut is offline   Reply With Quote
Old 10-24-2014, 04:14 PM   #104
OldSchool66
Your previous post are great. However, I am hoping that you can shine a light on how to remove the bezel and cluster from the opening. All of my switches and screws are removed, and the dang thing will not come out. The cab and steering column are already painted, so I am trying my best not to scratch the crap out of the column. Any advice would be greatly appreciated.
OldSchool66 is offline   Reply With Quote
Old 10-24-2014, 04:54 PM   #105
Budman56
Budman56's Avatar
the process is as follows remove or loosen the 4 bolts the hold up the steering column, most likely you will need to remove then lower the column. remove all 5 screws from the face of the bezel, then remove the speed od cable, disconnect the wiring harness from the two connectors. take out all the switches, this is where it get difficult, you will have to get under the dash with a screw driver and slightly bend down the tabs to make clearance so that the cluster will come out. this is where the cluster always hangs up take your time and you will get it out with out scratching your column.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 10-24-2014, 05:17 PM   #106
ol_skool_chevy
ol_skool_chevy's Avatar
Anyone know where to find a decal for a 64-66 clock?........Green ______, something made one but says he does not make one "for sale"..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-11-2014, 06:06 PM   #107
theastronaut
Finally received the lens and background decal so I could assemble the cluster.
Old 12-11-2014, 08:09 PM   #108
duallyjams
duallyjams's Avatar
Dang it now I want one.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-11-2014, 08:47 PM   #109
Hardrockz28
Just finished mine
Great info thru out his subject made it easy
Hardrockz28 is offline   Reply With Quote
Old 08-20-2015, 12:38 AM   #110
Ghernandez66
Ghernandez66's Avatar
Can you pm me a price to rebuilt mine with gauges ?
Ghernandez66 is offline   Reply With Quote
Old 08-20-2015, 09:15 AM   #111
tigerburns
Active Member
tigerburns's Avatar
Hey theastronaut, I am new to C10 ownership and new to this forum. The gauge cluster on my '65 is in pretty rough shape, so I clicked your thread out of curiosity. Then, I see that you are also in SC...I am in Greenville.
What would you charge to recondition a cluster for me? Feel free to PM me.
tigerburns is offline   Reply With Quote
Old 08-21-2015, 03:20 PM   #112
theastronaut
At this time I'm not taking in any clusters to restore. I have the engines out of two of my daily drivers, trying to get those back together. Appreciate the interest though!
Old 08-21-2015, 03:37 PM   #113
Boedean1981
Boedean1981's Avatar
After seeing this thread I took it upon myself to do ours. With the help of the colors listed I was able to put out a nice product from what I had.
Boedean1981 is offline   Reply With Quote
Old 02-22-2016, 01:31 AM   #114
Slambone
Slambone's Avatar
Where did the get the factory air gauge? How many bulbs are there? I got a harness that has 7 bulbs. Is that correct?
Slambone is offline   Reply With Quote
Old 03-27-2016, 05:53 PM   #115
jetboat 4
i got this gauge cluster with my truck, i see every one has a 5000 rpm tach this has 8000 looks factory, hopr to us this in my "66"
jetboat 4 is offline   Reply With Quote
Old 05-27-2016, 12:28 PM   #116
Vortech
Vortech's Avatar
Planning to use the overspeed and tandem lock on my instrument cluster. Where can i source 2 bulb holders?
Vortech is offline   Reply With Quote
Old 10-25-2016, 05:15 PM   #117
MikeN
MikeN's Avatar
I'd like to buy the gauge face deals from Jason Wilson at Green Back decals, linked on page 1 here, but there is a problem with his website. It's blocked from my work PC, and when I go there on my iPad it tries to force me to download an Adobe flash player. I'm simply not interested in playing any click bait games. Does anyone have a phone number or email for the guy?
MikeN is offline   Reply With Quote
Old 10-25-2016, 06:06 PM   #118
theastronaut
I'm pretty sure Adobe Flash and Apple/Safari are incompatible so that's why it won't pull up on your iPad. I had no problem viewing his website on my PC but it never has worked on my iPhone. The email listed on his website is parklane410@hotmail.com. If I remember correctly he sometimes works out of the US so he may be hard to reach at times. LMC sells his decals if you can't contact him directly.
Old 10-25-2016, 06:07 PM   #119
Slambone
Slambone's Avatar
I have a couple of them. PM me and I'll give them to you.
Old 10-25-2016, 09:39 PM   #120
MikeN
MikeN's Avatar
Thanks man!
Old 11-06-2016, 11:57 PM   #121
theastronaut
**Update on foil lining the tubes**
I pulled the cluster out of my '66 yesterday to clean it up and lube the speedometer that was chirping. I put in new bulbs and foil taped the light tubes while I was in there which really helped brighten them up... Just drove it home and the red plastic high beam indicator lens melted after driving with the high beams on for awhile. I pulled the bulb out and it looked fine, so I think the foil insulates the tube and heat builds up more- enough to melt the red plastic lens. I'll pull it apart to check into it further tomorrow. So it might not be a good idea to line the tubes that will be continually lit long enough to build up any heat. It works great in the turn signal tubes though. I'll post my findings once I get it apart.
Old 11-08-2016, 09:44 AM   #122
Lugnutz65
Lugnutz65's Avatar
Rats! I thought I had a good idea but what you say makes sense too. Are you using standard bulbs? Well, at least it can be used with the turn signals. Thanks for the feedback.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 11-09-2016, 11:33 PM   #123
theastronaut
I was using standard 1895 (going from memory) bulbs. Still a great idea for the turn signals, makes them much easier to see in the daytime.
Old 11-10-2016, 11:03 AM   #124
MikeN
MikeN's Avatar
For those of us without a blasting cabinet, is there any other good way to clean the housing and the bezel before re-painting?
Old 08-10-2018, 10:55 AM   #125
lonestar308
lonestar308's Avatar
I'm interesting in seeing Jason's work as well, but the link to his website as posted is a dead link....anyone have a good link to his website?
lonestar308 is offline   Reply With Quote
