Old 05-09-2017, 03:50 PM   #1426
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Originally Posted by 99 to Life View Post
nice overflow. weird the bag did that. airlift? is that why you swapped them?
Thanks. Ya airlift bags. Ya didn't like the crack, probably due to the fact I run at 110psi? but they have been in there for just over 2 years, so I figure I'll change them out to prevent problems.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-09-2017, 04:09 PM   #1427
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I finished up my jack mount. The wheels are on a piece of angle iron and the front slides under some flat bar held up with 2x 3/8" nuts. Then I just use some tie wraps to keep it from bouncing. Now I can bring my jack with me
1951 MG TD
Old 05-09-2017, 04:23 PM   #1428
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
killer
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-09-2017, 05:11 PM   #1429
RockinKees
RockinKees's Avatar
Re: My 52 GMC Build
Window tint looks great!
I like your jack mount, I Maybe steal this idea from you if you don't mind.
Your full of great ideas!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-09-2017, 08:48 PM   #1430
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Great idea on the jack mount!
Advanced Design is offline   Reply With Quote
Old 05-10-2017, 03:47 PM   #1431
lower50's
lower50's's Avatar
Re: My 52 GMC Build
killer
I feel more prepared now.
Thanks. For sure you can steal the idea if you want. I don't have a patent on it yet LOL
I got sick of it kicking around in my shop then throwing it in the trailer when we go somewhere. I also wanted it easy to put in and out.
1951 MG TD
Old 05-10-2017, 04:24 PM   #1432
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So today I tackled the cab door wind lance or cab weather strip. I heard it's a real pain in the donkey's rear, but found a cool idea. I made a little tool that was similar to the rubber profile that I could slide down the channel. It will open up the channel and make sure it is clear. Then I started at the back top and worked sliding the rubber forward using WD40 as lube. Then I trimmed the back part to length and slid it straight down. All in it took 3 hrs (tool and both doors)
1951 MG TD
Old 05-10-2017, 08:33 PM   #1433
65sub
65sub's Avatar
Re: My 52 GMC Build
Good work on the jack mount. I think I'll have to consider something similar for my truck.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 05-10-2017, 08:58 PM   #1434
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks it's good so far. I have to use this kind of jack because nothing else is low enough or strong enough to lift my truck when it is on the ground.
1951 MG TD
Old 05-10-2017, 09:11 PM   #1435
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Small update Just ordered my cruise control
http://www.rostra.com/universal-afte...-by-rostra.php
1951 MG TD
Old 05-10-2017, 09:14 PM   #1436
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Maybe you could try the low profile harbor freight floor jack? I have a snapon one and it is awesome. It's the only jack I can fit under my 40 and Corvette without driving on blocks of wood. Back to the HF jack, they claim it is better than the snapon jack. I doubt it but it may be something to consider if you need a jack for the garage or at home.
https://www.harborfreight.com/3-Ton-...uty-63183.html
Apparently snap-on is suing HF over this jack right now. They sure look similar......
I used a rostra cc kit on a diesel conversion once. It was a really nice unit.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-11-2017, 05:52 PM   #1437
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Ryan I have a regular 3T floor jack for at home work's great on all my vehicles. This little one is just to carry with the truck.
As for the Rostra cc, thanks for the feed back I have heard lots of good things. It will make it nice being we have 2 trips planed in the US this year. Columbus OH in July (340mi) one way and going back to Charolett NC in October (760mi) one way. Plus all the other trips in Ontario.
1951 MG TD
Old 05-11-2017, 07:05 PM   #1438
rusty76
rusty76's Avatar
Re: My 52 GMC Build
I was thinking about your little jack and it made me think of my mom. My mom carries a small floor jack in the back of her car. Smart cookie.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-18-2017, 12:14 PM   #1439
OutlawDrifter
Re: My 52 GMC Build
I've been creeping around this thread for quite some time. I really like how the bed wood turned out! Great build.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 05-25-2017, 12:45 AM   #1440
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Guys
1951 MG TD
Old 05-25-2017, 01:49 AM   #1441
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well my cruse control unit came in I'm hoping to install that next week. This weekend I'm taking the truck to my pinstriper to get some lettering done on the doors, he is about 2.5 hrs away. And And we have a new family member..... Our french bulldog named CJ (after my 50 year old Jeep CJ5) he is 11 weeks old. Just got him Monday afternoon.
1951 MG TD
Old 05-25-2017, 08:25 AM   #1442
oldman3
oldman3's Avatar
Re: My 52 GMC Build
lower, can't wait to see the doors done, CJ is a nice looking pup...Jim
oldman3 is offline   Reply With Quote
Old 05-25-2017, 10:42 AM   #1443
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
congrats on the pup. with all your driving I can see cruise coming in handy.
Old 05-25-2017, 06:52 PM   #1444
Dieselwrencher
Re: My 52 GMC Build
CJ is a cutie!
Ryan
Old 05-25-2017, 11:18 PM   #1445
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks Jim I'm excited to see them myself. CJ has been following me around like a shadow.
Thanks Going to Columbus in July and Charlotte again in October it will be great.
CJ is a cutie!
He has been doing great too.
1951 MG TD
Old 05-25-2017, 11:32 PM   #1446
lower50's
lower50's's Avatar
Re: My 52 GMC Build
First car show this year will be Unfinished Nationals June 4th in Paris Ont. then taking the fam to Vanfest for the weekend in Aylmer Ont. June 9-11. That will be our first camping of the year too. Maybe I'll see some of you there.
1951 MG TD
Old 05-29-2017, 05:56 PM   #1447
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Had a great drive up and back from my friend Adams place "Petts pinstriping"
CJ our new puppy was a super star, he fell asleep about 5 min into the drives.
The truck turned out amazing I'm so happy with how it turned out. He even was able to uncover the original lettering on the passenger side of the hood, 65 year old paint is amazing. 1st pic is my truck when it was in service
1951 MG TD
Old 05-29-2017, 06:00 PM   #1448
lower50's
lower50's's Avatar
Re: My 52 GMC Build
In our travels we came across this little nugget of heaven. They are all for sale and don't seem to bad of price. We stopped in and talked to the guy over a beer for about 45 min on our way home.
1951 MG TD
Old 05-29-2017, 07:20 PM   #1449
MIKESAD50
Re: My 52 GMC Build
The signage came out awesome, cool to uncover the original.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 05-29-2017, 07:23 PM   #1450
oldman3
oldman3's Avatar
Re: My 52 GMC Build
Lower, looks great. Nice pics of the surviors...Jim
bagged, build, diesel, gmc, hot rod
