Old 11-09-2012, 01:12 PM   #126
flashed
Re: '55 International Metal/Body/Paint Work
One of your posts above you say you are not very good at painting but I completely Disagree with you on that as it looks great to me .I cant wait to see this beauty finished ,what craftsmanship you have put into this truck .I wish I had your talents .
flashed is offline   Reply With Quote
Old 11-09-2012, 01:45 PM   #127
theastronaut
theastronaut's Avatar
Thanks flashed! But go back and look at that first pic of the wet sanding pics, it really shows how bad the surface of the paint was before sanding and buffing. There's a big difference between being able to spray paint and being able to cut and buff!
theastronaut is offline   Reply With Quote
Old 11-09-2012, 05:27 PM   #128
plainred65
plainred65's Avatar
Great progress, really enjoy reading about your in depth tips. I did collision at one point, but never got into this type of detail. Thanks for the lessons. Fantastic!
plainred65 is offline   Reply With Quote
Old 11-10-2012, 12:43 PM   #129
chevyrestoguy
chevyrestoguy's Avatar
John, I'm speechless. It looks amazing!!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 11-10-2012, 11:31 PM   #130
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Amazing work and attention to detail.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-23-2012, 08:42 PM   #131
cAlvis165
cAlvis165's Avatar
Wow! You've done a beautiful job on this truck. Thanks for taking the time to explain all your steps and capture them with pictures.
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 11-30-2012, 12:26 PM   #132
theastronaut
Thanks dudes! I appreciate yall following the progress and commenting!
To finish the cab I undercoated it and stuck the dash back in before the owner brought the frame over. We mounted the cab and he hauled it back to a shop at his friends place.
I masked the top of the dash and shot gloss clear over it, then wetsanded and buffed it before installing the dash panel with new stainless screws. I also installed the glove box and radio delete plate. The delete plate was originally held in with spring loaded clips and I was able to find new clips and paint them to match.
With the doors painted I bought new stainless hardware to bolt up the door components.
Sound deadener was applied to the inside of the door skin and the bolt on panel.
Old 11-30-2012, 12:37 PM   #133
theastronaut
Before sending the cab home I mixed up a batch of cavity wax and soaked the cab corners and front kick panel pockets a couple times to seal the metal and seams from the inside out.
I used a gallon of mineral spirits, two pounds of paraffin wax, and a quart of thin sewing machine oil. I grated the wax so it would dissolve faster.
I tested this stuff on a piece of bare metal and it held up pretty good out in the weather so it should do great in a cavity.
Water beading up on the treated side.
To apply it I used a cheap $10 buck weed sprayer which had a decent wide/fan pattern, and soaked each area a couple times until I felt like I had completely coated the inner panels. I kept a bucket under the drains since it was running out the bottom.
Old 01-18-2013, 08:23 PM   #134
theastronaut
Didn't realize it had been so long since I updated this thread. Photobucket it uploading (well, supposed to be...) about 175 pictures of metalwork on the bed. I'll start posting them once they're up.
Here's a few straight from facebook until photobucket finishes the import.
Old 01-18-2013, 09:53 PM   #135
duallyjams
duallyjams's Avatar
oooooooh that's ruff
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-18-2013, 10:22 PM   #136
flashed
Cant wait to see more impressive improvements .
Old 01-18-2013, 11:25 PM   #137
67ChevyRedneck
67ChevyRedneck's Avatar
I NEVER noticed your location before... your right down the road from me!
The cab and clip came out incredible!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-19-2013, 01:57 PM   #138
plainred65
plainred65's Avatar
Glad to see you're back at it, looks like that bed led a hard life. Any idea of the history of the truck?
Old 01-19-2013, 04:02 PM   #139
theastronaut
Not the best of shape, that's for sure. I call it job security.
Thanks!
Not far away at all, and thanks!
They used it on their farm, I do know they hauled gravel in it at times.
Old 01-19-2013, 04:08 PM   #140
theastronaut
So here's how it looked when it was delivered to me. It originally had a steel floor that was spot welded in. They had welded another floor on top of that one. When they started the restoration they cut the old floors out, leaving the flange from the original floor and the welds from the new floor. They also cut through the bed sides, leaving huge gashes. Rust had eaten through a few spots around the flange area. You can also see just how much the fenderwells were bulged out above the bed floor flange- it's had a very hard life!
Old 01-19-2013, 04:16 PM   #141
theastronaut
The first thing I started on was separating the old bed floor flange from the bed sides by drilling the spot welds. Also had to grind down the old welds from the replacement bed floor. The left rear corner was just about the only spot that I didn't have to completely cut out and remake, more on that later. The rust that was under the flange was sandblasted.
Easier to see the old bed floor flange, and the welds and edges of the replacement floor here. It's an 8' bed so there was 16 feet of this to fix. This was the easiest spot, the rest had to be completely cut out and replaced.
Cleaned up the body line on the outside of the panel.
Old 01-19-2013, 04:19 PM   #142
theastronaut
The top rail of the left bedside was badly kinked. I had to cut the area out and use a porta-power to straighten it.
Damage cut out to relieve the tension.
I over-straightened the rail, knowing the metal has "memory" and spring back some once I removed pressure from the porta-power.
Old 01-19-2013, 06:28 PM   #143
duallyjams
duallyjams's Avatar
You got skills but you already know that.
James
IG duallyjams
Old 01-22-2013, 11:21 AM   #144
theastronaut
Thanks James!
Here's more of the deconstruction. I drilled out the spot welds and removed the rear cross brace, then welded 1"x1" tubing with turnbuckles welded in the middle to adjust the width.
Drilled out the welds and removed the front header panel. I didn't have to do anything to the bottom, the rust had separated it already!
It has a side mount spare tire and the reinforcing plate had rusted through.
Old 01-22-2013, 11:26 AM   #145
theastronaut
The lower edges of the fenderwells were trashed so I cut them out and made new pieces to weld in. On the driver side, I cut the whole fenderwell out since it needed alot of straightening and welding a whole new piece in wouldn't be that much more welding.
Cut a new piece of metal and bent the bottom edge 90 degrees like the original.
Clamped it in place then scribed the cut line. I like to scribe the line instead of using a marker since the scribe is more accurate.
Trimmed and fitted, ready for welding.
Welds ground down inside and out.
Old 01-22-2013, 11:43 AM   #146
theastronaut
The other side wasn't as bad so I just replaced the bottom.
Same process- new piece cut, edge scribed, trimmed and fitted.
There were alot of dents in the fenderwells too so I straightened those out.
After straightening.
Old 01-22-2013, 12:08 PM   #147
cayoterun
Junior Member
cayoterun's Avatar
Great work!!!
Are you a body man, or metal worker by trade? Maybe a tech. school teacher?
Cayoterun
Cayoterun
Okla. Panhandle
I think I'll do it myself and pay the extra $500.
cayoterun is offline   Reply With Quote
Old 01-29-2013, 11:39 AM   #148
theastronaut
Originally Posted by cayoterun View Post
Great work!!!
Cayoterun
Thanks cayoterun, I went to Greenville Tech and took Autobody Repair my first year and Street Rod Fab my second. I work and my dad's shop, working on the International on my own, and other jobs he takes in as well. I'm currently helping them with an underhood restoration of a '70 El Camino SS 396/325hp. We have it torn down, the firewall and frame repainted, and are starting to detail and reassemble everything.
Old 01-29-2013, 11:48 AM   #149
theastronaut
Both rear corners were mangled and the welded in nuts for the tailgate hinges were rusted and cross threaded.
Blasted and straightened, and new stainless nuts welded in place.
Inside channel blasted and sprayed with weld-thru primer, ready to weld back in.
Welded in and welds ground down.
