Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-24-2018, 12:18 AM   #151
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Soon
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-24-2018, 08:28 AM   #152
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: NJ Suburban
Nice looking work so far Paul.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 02-24-2018, 11:03 PM   #153
zicc1835
zicc1835's Avatar
Re: NJ Suburban
X2
zicc1835 is offline   Reply With Quote
Old 03-30-2018, 07:35 AM   #154
Dave
DND Trucks
Re: NJ Suburban
Great work! Any updates
Dave is offline   Reply With Quote
Old 03-30-2018, 09:08 AM   #155
Burb
Coordinator of Synchronicity
Burb's Avatar
Re: NJ Suburban
You're making great progress. Great job
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 04-04-2018, 09:04 PM   #156
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Almost all done with the left side. Not completely happy with the bead in the wheel lip but I'll work on that later. The entire side is painted with Omni primer then coated with Nasco 2K. Tomorrow I'll spin her around and start working on the right side!
Paul
Old 04-05-2018, 06:49 AM   #157
richard2717
Re: NJ Suburban
Looking good Paul.
Members I have met.
Old 04-11-2018, 09:50 AM   #158
Hart_Rod
Hart_Rod's Avatar
Re: NJ Suburban
Nice progress
Hart_Rod is offline   Reply With Quote
Old 05-18-2018, 09:58 PM   #159
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Been making some progress. The drivers rocker is removed and I'm trying to sandblast the rusty inner front door jamb area before paint. Kind of a pain to do inside in the garage. I've set up plastic all around the area and sealed it off with masking tape. Dust is still flying all over the place! The replacement patch panel for in front of the rear wheel opening is in and primed!
Paul
Old 05-19-2018, 02:46 PM   #160
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
I hate sandblasting! With all the plastic taped in place and two exhaust fans (one with a furnace filter on it) and there is very little fine dust in the garage.
Paul
Old 05-19-2018, 03:55 PM   #161
zicc1835
zicc1835's Avatar
Re: NJ Suburban
Paul
nice to see it facing the opposite way .....ive made no progress ....open shore house
jz
Old 06-03-2018, 08:44 AM   #162
Dave
DND Trucks
Re: NJ Suburban
Looking good man! Did you have any rust in the rear wheel arches? From what I know that area seems like it would be hard to repair. I thought someone took a truck 8' bed side and made it work.
Old 06-18-2018, 07:20 PM   #163
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
They make a patch panel. Only problem is that the bead doesn't quite match the original.
Paul
Old 06-20-2018, 10:37 AM   #164
Dave
DND Trucks
Re: NJ Suburban
Was thinking of starting a build thread with my burban. However both 1/4s are junk and trying to decide if it's worth the effort to repair it or change out the body.
Old 08-01-2018, 08:52 PM   #165
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
And I'm back in the saddle again! Great to be back at welding!
Paul
Old 08-04-2018, 05:45 AM   #166
jaros44sr
jaros44sr's Avatar
Re: NJ Suburban
Great read! Nice work and progress Looking forward to future updates
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 09-09-2018, 09:23 PM   #167
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
I'm trying to fit the left lower panel and having trouble. Anyone else done this?
It fits fine in the wheel arch and along the bottom but the long part along the top is bowed way out!
Paul
Old 09-09-2018, 10:02 PM   #168
Dave
DND Trucks
Re: NJ Suburban
Man, your really doing great considering what's involved with replacing 1/4s on a burban! Keep up the great work.
Old 09-10-2018, 09:33 AM   #169
richard2717
Re: NJ Suburban
What happens when you unclamp the lower pinch weld clamps? Does it pull back where it should be?
Members I have met.
Old 09-10-2018, 12:11 PM   #170
pwdcougar
pwdcougar's Avatar
I’m going to give that a try this afternoon after work. I’m afraid of what it’s going to do if I weld the top team and then bring it down in the correct location on the bottom edge. I got this patch panel when they first came out. I wonder if mine is from a bad batch.
Paul
Old 09-10-2018, 12:37 PM   #171
richard2717
Re: NJ Suburban
Paul
Just from the pics it appears the bottom pinch may be over bent which would cause it to bow out like that. If it straightens back up when you take the clamps back off I would see about manually pulling some of the bend out of the bottom bend before welding it up. You don't want it stressed while trying to weld or it will pull it even harder
Richard
Members I have met.
Old 09-10-2018, 03:31 PM   #172
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Richard
Where do you mean Richard? Which bend?
Old 09-10-2018, 03:46 PM   #173
Killer Bee
Killer Bee's Avatar
Re: NJ Suburban
Paul is my hero!
Old 09-10-2018, 04:23 PM   #174
richard2717
Re: NJ Suburban
Paul
This is the bend I am talking about. If it is over bent and you clamp it, it will bow the top out. If you unclamp it and the top comes back in to where it should be, I would try gently massaging the lower bend, but it needs to be done before you start welding. It may take numerous tries.
Richard
Members I have met.
Old 09-10-2018, 07:25 PM   #175
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Paul
Richard
Thanks Richard I'll try that.
Paul
