Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-22-2015, 01:15 PM   #151
DLTruck1973
Re: Parting 1986 Suburban K20 4x4
Originally Posted by 1985-GMC View Post
The one I'm talking about is definitely off a suburban with rear A/C. It's in the top picture on the far left with the high pressure port. It has a Y for the liquid line to split off and go to the rear and suburbans are the only ones that had that.
This is the one you need, correct? I need $25.00 plus shipping which will be $17.00 so $42.00 total.
I stand corrected, the truck is a 1991 Suburban with rear air.
Let me know and I can PM you payment information.
Thank you for the interest,
Thomas
DLTruck1973 is offline   Reply With Quote
Old 06-22-2015, 02:12 PM   #152
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
If you can get that other line off of it I'll take it. A propane torch and some penetrating oil should do the trick if it's being stubborn. If it won't come off it won't do me much good. Thanks Thomas!
Tony
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 06-22-2015, 03:47 PM   #153
DLTruck1973
Tony
Hi Tony,
I have you covered. The other line came out just fine. No special tools or heat needed.
I will send you a PM with payment information.
Thank you,
Thomas
Old 06-22-2015, 05:05 PM   #154
billlopez
I'm looking for the wiper delay bracket that bolts to the underside of the steering column under the dash. Thank you.
billlopez is offline   Reply With Quote
Old 06-22-2015, 06:23 PM   #155
DLTruck1973
This one?
I can get it to you for $15.00 shipped if interested. I can give it a quick glass bead also.
Let me know,
Thank you,
Thomas
Old 06-22-2015, 11:54 PM   #156
whytry85
whytry85's Avatar
Good fender to cab seals?
whytry85 is offline   Reply With Quote
Old 06-23-2015, 06:17 PM   #157
billlopez
Originally Posted by DLTruck1973 View Post
This one?
Let me know,
Thank you,
Thomas
Yes, that is it. I would like to get it. You take money orders? Thank you.
Old 06-23-2015, 11:54 PM   #158
DLTruck1973
Yes we take money orders. I will send you a PM with the address.
Thank you,
Thomas
Old 06-26-2015, 09:19 AM   #159
72ChevySS
72ChevySS's Avatar
Do you have the air distribution duct/vent that is located under the center of the dash directly in front of the hump? if so please send pics and ship quote to 87124. Thanks in advance!
Jonathan
72ChevySS is offline   Reply With Quote
Old 06-26-2015, 12:18 PM   #160
LuvNLife
LuvNLife's Avatar
I've got an 87 GMC R1500 2WD short bed, with 350 and 700R. I need these parts:
Double-hump transmission crossmember for true dual exhaust, and,
Set of 4 front bumper brackets.
If you could let me know price and availability, I'd appreciate it. Shipping would be to zip 20169, Haymarket, VA.
Jerry
LuvNLife is offline   Reply With Quote
Old 06-26-2015, 12:36 PM   #161
DLTruck1973
This one? I can sell for $15.00 plus $13.00 to ship so $28.00 total.
Let me know and I will send you payment information.
Thank you,
Thomas
Old 06-26-2015, 01:07 PM   #162
DLTruck1973
Double-hump transmission cross member for true dual exhaust, and,
Jerry
Here you go,
I have the complete set of front bumper brackets for $50.00 plus shipping.
For the cross member, the only 81 and up version of that "double hump" is for a 4x4. I do not believe it to work on a 2wd truck. I do have it for the 4x4 and it is $65.00 plus shipping if you are interested but you would need to do some research to see if it would work.
Let me know,
Thank you,
Thomas
Old 06-26-2015, 05:17 PM   #163
Wgesnerjr
Wgesnerjr's Avatar
Wanted to know if the Suburban was a Fuel Injected unit. I am looking for all the wiring (bulkhead connector to tank) and the plugs (both sides) for the fuel sending unit. I am putting fuel injection into a carb chassis and need to add this plug to my unit as I am putting a pump in the tank.
Please let me know if you have these and how much with shipping to Atlanta 30044.
Thanks,
Jay
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 06-26-2015, 05:58 PM   #164
72ChevySS
72ChevySS's Avatar
Thank you,
Thomas
Old 06-27-2015, 09:55 PM   #165
whytry85
whytry85's Avatar
Originally Posted by whytry85 View Post
any good fender to cab seals?
Old 06-27-2015, 11:22 PM   #166
DLTruck1973
I will have to check for you on Monday.
I will let you know, thank you,
Thomas
Old 06-28-2015, 05:10 PM   #167
Krex
I am looking for all brake parts knuckles out from a front Dana 44 what do you have shipped to 75023
Krex is offline   Reply With Quote
Old 06-28-2015, 09:54 PM   #168
aotte1
Need
1). two Silverado Kick panels for 1986 C10, prefer black but will consider other colors too.
2). 1984 to 87 dash bezel non A/C preferred, will consider A/C one also.
Would like in very good to excellent condition please.
Got a bunch of stuff a while back, did I deal with John then?
Thanks,
Les
aotte1 is offline   Reply With Quote
Old 06-29-2015, 10:51 AM   #169
aotte1
Follow-up on dash bezel will send you photo of needed one later today.
Also need outer seat belt bolt escussion cover where it bolts to floor.
Photo attached. Mine has attaching tab broken.
Les
Old 06-29-2015, 04:39 PM   #170
DLTruck1973
The only set I have readily available are on an 85 pick up cab which should be the same.
I will need $20.00 for the pair plus the shipping which I could do for $13.00 so $33.00 total.
Let me know.
Thank you,
Thomas
Old 06-29-2015, 05:01 PM   #171
DLTruck1973
Originally Posted by aotte1 View Post
Need
Thanks,
Les
Hi Les,
That would have been Thomas (myself) or Tom that helped you before but probably me.
No on the kick panels . I have nothing in any color that is in great condition at this time.
I do have a 84-87 non AC bezel but it does have some chrome wear off around the gauge holes. I would need $50.00 but it is not perfect.
Let me know,
Thank you,
Thomas
Old 06-29-2015, 06:48 PM   #172
aotte1
Thomas,
Dash bezel- Is it easy to post a photo please. Is it in good condition except for the missing chrome? Looking for a nice one to match the other dash insert piece I received from you.
Also need the two sway bar brackets that are riveted to the frame for my 86' truck, they are kind of odd/ angle shaped, non semetrical.
Anything on the outer floor seat belt cover- photo above?
Les
Old 06-29-2015, 11:46 PM   #173
whytry85
whytry85's Avatar
Let me know.
Thank you,
Thomas
I'll take em. Let know how you want payment sent. Thanks!
Old 06-30-2015, 09:01 AM   #174
Hart_Rod
Hart_Rod's Avatar
Do you have a good used chrome sport bumper and brackets for 86 SWB?
Hart_Rod is offline   Reply With Quote
Old 06-30-2015, 02:35 PM   #175
DLTruck1973
Thank you,
Thomas
