Old 03-30-2015, 02:12 PM   #176
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: ls turbo build
I wouldn't worry about them. I put a set of ebay china stainless longtubes on an LS swap build, and they are holding up really well. Huge bang for the buck.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-30-2015, 04:01 PM   #177
tinsoldier
tinsoldier's Avatar
Re: ls turbo build
How long have you had them. All the ones I ever seen lasted about 6 months and breaks right off at the merge, especially after the heat cycles and the stress of the weight from the turbos. But then those I saw were on Hondas.
tinsoldier is offline   Reply With Quote
Old 03-30-2015, 04:45 PM   #178
Wasted Income
Boosted Member
Re: ls turbo build
LONGTUBES. On an NA setup. I would never hang turbos directly off of a thin tube header. lol.
Turbo diesel
Old 03-30-2015, 09:53 PM   #179
tinsoldier
tinsoldier's Avatar
Re: ls turbo build
Oh ok, I misread the long tubes because all I saw was those shiny turbo headers posted earlier.
Old 04-01-2015, 01:45 PM   #180
69trk
69trk's Avatar
Re: ls turbo build
my turbo is not going to have any stress on the headers either..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 05-02-2015, 03:54 PM   #181
low69chevy
low69chevy's Avatar
Re: ls turbo build
Any updates my build is very similar to yours keep up the good work
low69chevy is offline   Reply With Quote
Old 05-04-2015, 01:50 PM   #182
69trk
69trk's Avatar
Re: ls turbo build
thanks... with a 18year old and her baby, and my 12 year old in baseball and my 2 year old, not much money at the end of the day.. daycare and everything else is making this slow...
1.58- 60'
11.37- 1/4 @115.81
Old 05-04-2015, 10:15 PM   #183
low69chevy
low69chevy's Avatar
Re: ls turbo build
I understand I've been ordering parts also for about 3 yrs so mine ain't that "quick build" either
Old 08-23-2015, 03:39 AM   #184
prostreet1967
prostreet1967's Avatar
Re: ls turbo build
Looking good I have same set. On3 makes set a lot more durable if mine break I will try them.
prostreet1967 is offline   Reply With Quote
Old 09-21-2015, 07:26 PM   #185
69trk
69trk's Avatar
Re: ls turbo build
Here we go..finally getting back on this thing
1.58- 60'
11.37- 1/4 @115.81
Old 09-21-2015, 07:27 PM   #186
prostreet1967
Re: ls turbo build
Nice I will be on my shortly
Old 09-24-2015, 06:30 PM   #187
69trk
69trk's Avatar
Re: ls turbo build
Stand is almost done
1.58- 60'
11.37- 1/4 @115.81
Old 09-24-2015, 07:07 PM   #188
joey8383
joey8383's Avatar
Re: ls turbo build
Very Cool. I have changed directions on my LS build and am about to pull the trigger on ordering a turbo set up. I'm following Denmah's sloppy type build from LS1tech. Most likely doing a VS Racing set up for now.
Like you, I want to keep the AC. What bracket did you have on the AC comp at first? And now you have a bracket from LSbrackets.com? Would you mind posting a link if you get time? Would you want to sell the C6 manifolds you started with since you're doing headers now? Keep up the nice work! Love the build.
joey8383 is offline   Reply With Quote
Old 09-24-2015, 09:32 PM   #189
69trk
69trk's Avatar
Re: ls turbo build
Thanks.. both ac brackets came from lsbrackets.com . They don't make the bracket that I had anymore.. but you can call them to make sure..I sold mine. I'm not using the c6 manifolds or the truck manifolds.. so I will let them go..
1.58- 60'
11.37- 1/4 @115.81
Old 10-03-2015, 11:02 PM   #190
69trk
69trk's Avatar
Re: ls turbo build
Hotside about done
1.58- 60'
11.37- 1/4 @115.81
Old 10-04-2015, 12:17 AM   #191
prostreet1967
Re: ls turbo build
U going with 3 inch hot side?
See the cone now. Nice work.
Is it fully divided?
Old 10-04-2015, 09:28 AM   #192
69trk
69trk's Avatar
Re: ls turbo build
2.5"
1.58- 60'
11.37- 1/4 @115.81
Old 10-04-2015, 08:14 PM   #193
69trk
69trk's Avatar
Re: ls turbo build
Wastegates mounted
1.58- 60'
11.37- 1/4 @115.81
Old 10-05-2015, 11:38 AM   #194
joey8383
joey8383's Avatar
Re: ls turbo build
What AC system are you running?
Old 10-05-2015, 12:35 PM   #195
tinydb84
tinydb84's Avatar
Re: ls turbo build
Looking good!
David
Instagram: myfabguy
Old 10-05-2015, 01:37 PM   #196
69trk
69trk's Avatar
Re: ls turbo build
It's a vintage air...
1.58- 60'
11.37- 1/4 @115.81
Old 10-05-2015, 03:53 PM   #197
mcbassin
Still Learning
mcbassin's Avatar
Re: ls turbo build
Very nice progress!
mcbassin is offline   Reply With Quote
Old 10-09-2015, 11:49 PM   #198
69trk
69trk's Avatar
Re: ls turbo build
Turbo in.. cold side left and downpipe
1.58- 60'
11.37- 1/4 @115.81
Old 10-10-2015, 12:13 AM   #199
prostreet1967
Re: ls turbo build
Any more of how u routed into turbo? Assuming u ran divided hotside all the way to turbo
Old 10-12-2015, 10:21 AM   #200
boostedc10
boostedc10's Avatar
Re: ls turbo build
Just a question, if you are fix mounting your turbo to the frame and have no flex joints in your hot side what are you going to do to stop the pipe from breaking due to engine movement?
The only time I have ever seen a turbo fix mounted to the chassis was on a car with engine plates.
Maybe I am missing something on your setup but if I am not you might want to consider this.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
