Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-30-2015, 04:30 PM   #176
DLTruck1973
Re: Parting 1986 Suburban K20 4x4
Originally Posted by Hart_Rod View Post
Do you have a good used chrome sport bumper and brackets for 86 SWB?
I will check and get back with you. Rear?
Thank you,
Thomas
DLTruck1973 is offline   Reply With Quote
Old 06-30-2015, 04:59 PM   #177
DLTruck1973
Originally Posted by aotte1 View Post
Thomas,
Dash bezel- Is it easy to post a photo please. Is it in good condition except for the missing chrome? Looking for a nice one to match the other dash insert piece I received from you.
Also need the two sway bar brackets that are riveted to the frame for my 86' truck, they are kind of odd/ angle shaped, non semetrical.
Anything on the outer floor seat belt cover- photo above?
Les
Hi Les,
Here are photos of the bezel. Not the greatest condition but no cracks anywhere.
I have the brackets you need for $50.00 for the pair. I will need to get them removed from a truck we have here. I do not have anything loose currently. These brackets are riveted to the cross member near the frame rails correct?
I believe they would be correct for an 81-87 K10 pick up or 81-91 suburban/blazer?
Nothing on the seat belt cover.
Let me know and I can figure out shipping for everything.
Thank you,
Thomas
Old 06-30-2015, 10:00 PM   #178
aotte1
Thomas,
sent PM
Les
aotte1 is offline   Reply With Quote
Old 06-30-2015, 10:49 PM   #179
Hart_Rod
Hart_Rod's Avatar
Thank you,
Thomas
Yes
Hart_Rod is offline   Reply With Quote
Old 07-01-2015, 04:49 PM   #180
billlopez
Item received. Thank you so very much!
billlopez is offline   Reply With Quote
Old 07-05-2015, 06:12 PM   #181
Littletony
Littletony's Avatar
Do you still have the axles?
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 07-06-2015, 11:21 AM   #182
DLTruck1973
What exactly do you need? Complete rear diff assemblies from rotor to rotor / drum to drum, or just axle shafts? What gear ratio are you looking for? I think the ones in this Suburban sold but we have others.
Let me know.
Thank you,
Thomas
Old 07-06-2015, 11:29 AM   #183
Littletony
Littletony's Avatar
I need complete assembly's, I would like to have 410 ratio front and rear with a full floater for the rear. I am going to put this under a 87 1/2 ton and would like for them to be bolt in.
Old 07-06-2015, 12:59 PM   #184
DLTruck1973
I have a rear with 86,000 miles, with posi and full float axles for $400.00 lug nut to lug nut.
I have a front (unknown mileage) for $500.00 lug nut to lug nut. Both 4:10 gears.
I have quoted shipping for these before to and it was $350.00 to ship the rear to NJ. My guess is you would be looking at at least $600.00 if not more for shipping alone.
Let me know.
Thank you for the interest,
Thomas
Old 07-06-2015, 01:00 PM   #185
Littletony
Littletony's Avatar
Would shipping still be that high if they are strapped to the same pallet?
Old 07-06-2015, 02:19 PM   #186
Littletony
Littletony's Avatar
Pm sent
Old 11-26-2016, 02:49 AM   #187
TKCR
TKCR's Avatar
Do you still have the suburban for parts? Looking for the parts that hold down the jack in the inner fender.
Old 01-04-2017, 12:53 AM   #188
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Is the trans tunnel a high hump? If so how much?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 01-24-2017, 08:16 PM   #189
tucsonjwt
Do you have a factory K20 bottle jack that works? Could you please post a pic if you do?
tucsonjwt is offline   Reply With Quote
Old 01-25-2017, 10:15 AM   #190
ztk123
Checking to see if you have two dent and rust free rear inner wheel housings,
is the grill from the red suburban pictured still available, bumper brackets for a rear sport sport bumper, core support for single headlight (same set up as pictured in the ad) and possibly an electronic speedo cluster. All this going on an 87 R10.
Thanks, Mike
ztk123 is offline   Reply With Quote
Old 03-01-2017, 11:35 AM   #191
tanman722001
tanman722001's Avatar
Hi do you have a vent window assemble that will fit my 84 C10 Silverado? I need the passenger side. Thanks
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 03-11-2017, 10:09 AM   #192
GonicGM
GonicGM's Avatar
Parts wanted for pickup from other trucks in your yard or other members here...
Catalytic converter heat shield and brackets, 1987 4x4 standard cab or any 1987-1991 one ton, standard cab.
87-90 454 TBI Dipstick Tube
87-91 V30/V3500 TBI Intermediate Fuel Feed Line from fuel filter to braided line.
Rear DRW Hubs.
73-91 Dually Bed harness, filler panels (inner to outer skin), wiring protectors, rear red fender light.
87 GMC service manual.
87 GMC wiring diagrams.
3.73 Dana 60 Front and Dana 70 HD Rear.
Tan manual window door panels (clean) (81-87 old style) Scottsdale, or better yet Silverado/Sierra Classic.
Tan and red/maroon OEM floor mats.
Clean LH rear brake drum backing plates for 84-87 1 ton GM, some 88-91 R/V may be the same. These have the snap in style ebrake cables. Can be from 14 bolt FF SRW, DRW or Dana 70.
OEM 30/3500 Series Tailgate, Lights and Harness
Camper Special stuff, Tie downs, dual battery harness and relay(73-91 old style)
85-89 factory dual exhaust, any pieces, from carbureted truck.
Silverado 30 fender emblems with studs in tact (81-91 old style).
Scottsdale 30 fender emblems with studs in tact (81-91 old style).
Factory Under bed exhaust heat shields.
Rear spring shackles from 1973 +/- (folded with two rivets).
Doug Thorley Tri-Y headers for small block or big block.
OEM Front bumper guard (bumperette) for 81-87, passenger side.
SRW K30 OEM front hubcaps.
Harness, dual tank, upper, 87-91, TBI.
Rear frame rail tips from one ton pickup
Factory split tailpipe, cat and brackets from 87-88 one ton VIN R OR V
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 04-19-2017, 01:00 PM   #193
Electricduane
Roof rack/rear air dam? thanks.
Electricduane is offline   Reply With Quote
Old 11-03-2017, 11:49 PM   #194
67see10
67see10's Avatar
engine crossmember?
67see10 is offline   Reply With Quote
Old 11-17-2017, 01:11 PM   #195
williamdale
Hello are you still selling parts looking for a transmission cross-member for a 4x4 with 400
turbo and a 208 transfer case my tuck is a 1984 ?
My name is Dale and i can be reached at 704-865-1616 or by email
williamdale is offline   Reply With Quote
Old 11-17-2017, 05:52 PM   #196
TKCR
TKCR's Avatar
This dude hasn't been on the forum in over a year.
