Old 03-17-2012, 10:49 AM   #201
shawno72
C/10 junkie
shawno72's Avatar
Re: lets see your trick mods and custom touches!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-17-2012, 10:12 PM   #202
BFRO$TY
Originally Posted by N2TRUX View Post
Since I didn't want to distract from the restored look of my interior, I had a custom panel built to mount my air ride controls. The sitches are monuted in this cool stalk that fits flush against seat. The digital gauge is hidden in the ashtray...
awesome!!!!
BFRO$TY is offline   Reply With Quote
Old 03-19-2012, 01:25 AM   #203
wild4wheels
wild4wheels's Avatar
Originally Posted by _Ogre View Post
trex plastic decking for bed ''wood''
mini tubs were cut out with a jigsaw and welded back in with a 3 inch spacer
plain old 1.25x1.25x.125 angle iron for bed angle
WOW, interesting idea... how was it to work with? That stuff is SO heavy! Hmm... cheap lowering job!?!
Dave aka "Wild"
Current truck
"Ida Mae" 71 K5 Blazer
Former Trucks
"Loretta" 71 Longbed (AZ)
"Tanya" 69 Stepside (AZ)
"Ferdinand" 71 Longhorn (SD)
"Patches" 67 Panel (IA/ KY)
"Rosita" 68 C30 (KY)
Instagram @Wildforwheels @k5_klub @c10university
Profile pic provided by Jeff Sundance
wild4wheels is offline   Reply With Quote
Old 04-11-2012, 01:18 AM   #204
Fatkid1983
Fatkid1983's Avatar
Ttt
1971 chevy c10 cheyenne. Bagged. New paint and some other mods.
1999 ford f350 superduty 7.3 powerstroke everything banks
1975 c10 swb "parts runner" <----SOLD
NorthWest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Fatkid1983 is offline   Reply With Quote
Old 04-11-2012, 02:07 AM   #205
smoknbarrels
Registered Mail
smoknbarrels's Avatar
[QUOTE=Ackattack;4873678]removed the turn signals from the grill
How is this achieved? sweet!..I want!
does this still function with the headlights on?
smoknbarrels is offline   Reply With Quote
Old 04-11-2012, 09:08 AM   #206
Indyuke
^^^ That is indeed very nice. I've always thought the stock blinkers break up the smooth lines of the 67-68's. This makes it very feng shui.
Indyuke is offline   Reply With Quote
Old 04-11-2012, 12:37 PM   #207
Ackattack
Ackattack's Avatar
[quote=smoknbarrels;5306579]
I got these
http://www.chevsofthe40s.com/detail/...GHTS_TURN.html
you have to do a little modification to the core support to get them to fit in there. The blinkers are wired just like the stock blinkers. Although you need an LED flasher.
For the grill you just need an extra upper insert and rivet it into the lower opening.
Ackattack is offline   Reply With Quote
Old 04-11-2012, 12:52 PM   #208
67cheby
67cheby
67cheby's Avatar
my wiring/radiator trim panels
67cheby is offline   Reply With Quote
Old 04-11-2012, 09:13 PM   #209
schurg
Originally Posted by dave3156 View Post
One of my mods is a wood bed I made myself. The wood is poplar. I cut the boards to size (specs from GMC Pauls website), ran them thru a planer, cut the grooves for the strips with a table saw, put three coats of spar polyurethane on both sides, bought the unfinished strips form Mar K and painted them with 2 coats of Blue and one coat clear. I attached them over a one piece welded in steel bed. I first coated the bed with POR15 and then mounted the boards over closed cell pipe insulation (boards are on top of foam insulation so they have air under them). I drilled holes through the steel bed and used stainless steel bolts and self tighening nuts to secure it to the steel plate. It was alot of work but I'm happy with the results.
I love the floor...well done...but what really caught my eye is the bedsides...is there a story on those?
schurg is offline   Reply With Quote
Old 06-11-2012, 09:19 AM   #210
Towstrap
Towstrap's Avatar
very good mods going to work on some myself
Towstrap is offline   Reply With Quote
Old 06-18-2012, 11:27 PM   #211
GuyO
GuyO's Avatar
[QUOTE=Ackattack;5307126][quote=smoknbarrels;5306579]
I got these
This is the coolest mod I think I have ever seen. I agree with the comment that the bumper lights break up the smooth look of the Chevy bumper, I think this is one reason why I prefer GMC's. Very very cool. Did you also do the headlight relay upgrade mod at the same time? That is our next one to do, we bought the relays yesterday and have the installation details from this forum.
Headlight relays,
10 guage hot wire 2 5 prong bosch relays big ground wire connectors
1 Read the article
2 Parts list 2 Bosch relays, spade connecters, wire, and inline fuse.
3 Look at wiring sheet
4 Decide that you can do this
5 Start by finding the 14LG and the 18LT wire on the back of the left headlamp.
6 Disconnect the (- Neg) battery cable. Mount the relays to the core support above the horn. You may have to make room for them.
7 Follow the 14LG wire towards the fuse block. Mark it. This is the one to cut.
8 Follow the 18LT wire towards the fuse block. Mark it 1st. Cut this one also.
9 Do the wiring:
cut 18LT (or low beam) and run the wire from the fuse block to Terminal 86 on the relay.
run the other end and that comes from the headlamp plug to Terminal 87 on the relay.
cut 14LG (or hi beam) and run the wire from the fuse block to the Terminal 86 on the 2nd relay. run the other end to Terminal 87 of the 2nd relay.
10 Terminal 85 goes to ground.
11 Run a heavy wire (12ga.) from + Battery Post to Terminal 30 of both relays. Just run it through the stock wiring across the radiator. Add a inline fuse on this one.
12 make sure every thing is connected, secure wires, replace (- battery cable )
13 Enjoy Brighter Head Lights
GuyO is offline   Reply With Quote
Old 06-19-2012, 12:25 PM   #212
cjohnson6772
cjohnson6772's Avatar
I can't understand why no one has commented on this. I think those panels looks awesome. Now tell us what you used to make the flared holes. I am guessing that you have a die set but I am hoping you've come up with a simple tool we can all make for ~$10 Seriously nice work though.
cjohnson6772 is offline   Reply With Quote
Old 06-19-2012, 01:11 PM   #213
fishingjred73
fishingjred73's Avatar
They have, it's just been in his build thread. He has alot more pics there too!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 06-19-2012, 01:15 PM   #214
67cheby
67cheby
67cheby's Avatar
Thank you, they are called Dimple dies, you can buy a set on ebay of several different sizes for around $300, i borrowed mine from a friend ! LOL, my other friend lets me use his bead roller ! ITS ALL ABOUT HAVING THE RIGHT FRIENDS !!
Old 09-23-2012, 12:01 PM   #215
UNEASYRIDER
UNEASYRIDER's Avatar
Covered the shifter hole and added cup holders
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline   Reply With Quote
Old 09-23-2012, 12:59 PM   #216
Sideways
Sideways's Avatar
Here is my hidden hitch,also acts as amount for the step when the camper is mounted.
Sideways is offline   Reply With Quote
Old 09-23-2012, 02:33 PM   #217
74baggedbug
I didn't want a stereo in the dash or in my glovebox so I got a Bluetooth reciever and I just use my iPhone as my radio or pandora, the thing I like the most is that it's all wireless and don't have a cord attached to my phone
74baggedbug is offline   Reply With Quote
Old 09-23-2012, 07:44 PM   #218
bonnieclyde100
uneasyrider that was an awsome idea. i wish i had thought of it
bonnieclyde100 is offline   Reply With Quote
Old 09-23-2012, 09:00 PM   #219
Tinkermc
some very nicely done and very good ideas have been expressed here, thank you 1 and all
Tinkermc is offline   Reply With Quote
Old 09-23-2012, 09:18 PM   #220
74baggedbug
Did you run into any clearance problems with hitting the transmission then you installed it? I think I'm gonna have to borrow this idea
Old 09-23-2012, 09:50 PM   #221
speedfreak369
speedfreak369's Avatar
I'd like to have some of those
1965 c10 short stepside (dad's project)
1967 c10 fleetside 350/350 trans (my baby)
speedfreak369 is offline   Reply With Quote
Old 09-24-2012, 12:20 AM   #222
zacthrasher
zacthrasher's Avatar
Here the door handles that are still in progress.
My 67 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=473825
zacthrasher is offline   Reply With Quote
Old 09-24-2012, 01:07 AM   #223
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by Putter View Post
MInor stuff, but it's all my doing...
Suburban seat
adjustable height seatbelts
AutoMeter gauges
Compas/Temp mirror
You have no excuse to ever overheat your engine!
WIDESIDE72 is offline   Reply With Quote
Old 09-24-2012, 01:44 AM   #224
woodwright
Enjoying left field
woodwright's Avatar
Can you expand on that a little? Whats the bluetooth receiver?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 09-24-2012, 10:53 AM   #225
muscletrucks
muscletrucks's Avatar
Cool Beans
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
