05-15-2022, 06:20 PM | #1 |
Clear Coat Repair
Hello Everyone,
I recently picked up a 1997 GMC Sonoma, it runs great but the clear coat is falling off!! has anyone ever tried to or did fix this? If you did how did you do it ad how'd it come out? Thanks
Take Care Troy |
05-15-2022, 09:38 PM | #2 |
Post Whore
Re: Clear Coat Repair
Never done it myself, but when I've seen it done, the clear needs to be removed
05-16-2022, 04:37 PM | #3 |
The clear will have to be stripped. The exposed base coat will be UV damaged so it needs to be thoroughly sanded to remove the damaged base. Then shoot it with sealer, base, and clear. Be sure to use a good quality clear and spray at least the minimum amount of coats required to provide adequate UV protection or the new base will fail and the clear will peel again.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
05-16-2022, 07:28 PM | #4 |
Thanks for the help! I may just let it go for now!!!
Take Care Troy |
05-17-2022, 09:02 PM | #5 |
If you do tackle this try a single edge razor blade before anything when the clear and or base fail you can remove big amounts pretty fast with a razor blade held and a angle. You will need to sand the base as stated above, inspect it well as sometimes the exposed base will have so much damage that it will need to be removed as well. In that case I take all the base then spray 2 to 3 coats of epoxy then 2 to 3 coats of high build primer then go with base and clear. if you strip it down and do the epoxy and high build you really dont need the sealer
