06-29-2022, 01:42 PM | #1 |
New Qa1 crossmember
Coming soon :
https://www.qa1.net/c10?fbclid=IwAR1...6kG6300eqL8GuA They make some nice stuff. Wonder how the engineering will work out on this one compared to other companies attempts.
81 short step. |
06-29-2022, 04:37 PM | #2 | |
Re: New Qa1 crossmember
06-30-2022, 08:10 PM | #3 |
They say its compatible with their existing a-arms, which are designed to mount to stock locations. So not sure how they would change things? (much).
I have a set of their lower arms and they are nicely made.
81 short step. |
07-01-2022, 08:06 AM | #4 | |
If you look @ the lower a-arm attachment points, there are 2 slots on each side for the lowers. Using the inner slots would reduce track width. Using the outers would increase it. Not saying it's a significant amount but some of the aftermarket lower arms are available 'narrowed' to help put things where you want. I see the 2 position options as a decent idea to help dial in track width & also for tweaking alignment:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-01-2022 at 08:12 AM. |
07-01-2022, 10:04 PM | #5 |
Ah, Yer right. Good eye.
I'd really like to see how the column shaft works out. That always seems to be a crutch on these conversions; The U-joints all operating at max angles. They have an install vid up : https://www.youtube.com/watch?v=33kIV3Ap25E
81 short step. Last edited by StorminNorman; 07-01-2022 at 10:13 PM. |
07-05-2022, 06:56 AM | #6 |
Hopefully they hit a decent price point. There are a lot of good and proven options out there.
1984 K5 Blazer 4x4. Because my daily driver needs to be a project too... 1971 C10. Auto Cross/Pro Touring Build. Project : I am gonna go broke with this one. 1970 Chevy LWB 4x4. 355, 4spd, Dana 44 front, Dana 60 rear, 35x12.50 tires... STOLEN I will put a Turbo on anything with an engine if the $$$ is right. Once upon a time.... |
07-07-2022, 02:19 PM | #7 |
Around 2200 for the cross member and rack
Around 4000 for complete front setup |
07-07-2022, 05:38 PM | #8 |
Just noticed I cant see any bump stops on it. And they are using those cable straps on the shock as down stops I am guessing.
81 short step. |
07-11-2022, 04:27 PM | #9 |
Looks like the bump stops are on the coilover shaft, just under the spring hat. It would be nice if the cable was adjustable to limit droop travel for autocross/track use for more control over body roll and to keep more weight on the inner rear tire when coming out of corners under power. Then adjust it back to a longer length for better ride quality on the street.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
09-07-2022, 04:38 AM | #10 |
Someone needs to buy one of these and let me know how the rack and pinion connection works out! I have the QA1 front kit sitting in boxes in my basement and this would be a nice add on, but want to see someone install one with the rack hooked up first. I don't know if its just how they have it mocked up, but in that video the angle of the rack shaft looks very wonky and I don't see how it would connect.
10-28-2022, 09:32 AM | #11 |
Here are a couple photos of the steering shaft installed. A two piece shaft is recommended for clearance around the shock mount and to reduce the angles on the joints. The steering support bracket and rod end are included with the system. Sweet Mfg. u-joints do have a little more operating angle than some of the other brands.
The install instructions include the photos below and part number recommendations for steering joints and fittings to connect the rack. https://www.qa1.net/assets/uploads/d...ssmember_4.pdf '73-'87 '67-'72
I can still count my vehicles on two... wait three hands. |
11-26-2022, 08:26 PM | #12 |
That new QA1 crossmember is a top notch for sure, speaking with their product manager at SEMA this year in my booth at our Monday night kickoff party, he convinced me not to frame swap my 62 to a 69. That there are other options, like this new crossmember. It’s a piece of jewelry as well.
01-01-2023, 02:02 PM | #13 |
Just getting mine installed. I got the retrofit kit. I had the previous kit still in boxes so I added the crossmember kit. It’s a little bit of a pain figuring out the changes to things with hardware etc being that it wasn’t previously installed. Probably much easier to start with the complete kit or start with an installed older kit. Going together smoothly.
Installing the rack today I believe and working on the rear. I need to powdercoat the rear end housing and spindles to keep going |
02-10-2023, 05:53 PM | #14 | |
Posted via Mobile Device |
02-10-2023, 09:57 PM | #15 |
Header p/n?
02-14-2023, 12:50 PM | #16 | |
And pictures of said headers installed if you have them?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
02-25-2023, 06:07 PM | #17 |
I used these headers linked below- and, oddly enough, they are pictures of them installed on a 68 C10 in the reviews and you can see how far the #1 tube comes out, which has me concerned about running the steering shaft for the rack on this QA1 piece. They fit great and have no interference issues with the Z bar in my current configuration.
https://www.summitracing.com/parts/hed-69026/reviews Posted via Mobile Device |
02-25-2023, 07:36 PM | #18 |
Cool to see a 1.75" primary 'mid-length' option available.
09-26-2023, 12:29 PM | #19 |
On the road
I know I'm late to the party on this one. I have the QA-1 already and would love to use this crossmember to drop mine a bit more but like everyone else I'm worried about the steering hookup. I have a big block with 2" headers and don't want to give them up. I talked with Dave Kass with QA-1 on HRPT 2022 and he said they made it work, but after reading the installation instructions I see they used small tube headers.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
10-15-2023, 12:26 PM | #20 |
On the road
My Buddy is mocking his up with a Big Block now, paving the road for me. Steering is tight but everything else clears. He is likely going to use a Flaming River VDOG to get around the header with the steering. He is toying with the Borgeson double U-Joint and hasn't made up his mind yet. These are 2" headers so if he were to use smaller tube headers it would clear fine.
