09-22-2021, 08:03 PM | #1 |
painting over 5 year old epoxy
5 years ago did the bodywork on my Suburban doors and painted them with Nason epoxy primer. For finishing it off all it should need is a coat of 2K primer and some blocking. How should the Nason epoxy be prepped for recoating. It's been 5 years since these were last worked on. I know the 5 year old epoxy has to be sanded or scuffed but with what grit? Also should it get a fresh coat of epoxy before applying the 2K? Lately I've been using SPI epoxy and 2K.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
09-22-2021, 08:09 PM | #2 |
Re: painting over 5 year old epoxy
i had some parts that were done over a yr before with epoxy..i just hit it with 180 and then sprayed the highbuild on...my cabs been in epoxy for over 2yrs..getting ready to hit it as well
09-22-2021, 08:15 PM | #3 |
Thanks!
09-23-2021, 08:28 AM | #4 |
I would block the Nason with 180 and then a coat of SPI epoxy. Wait 48 hours and then spray your 2K.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
09-23-2021, 10:43 PM | #5 |
SPI recommends sanding then recoating with epoxy if it's been on there that long.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
09-25-2021, 04:04 PM | #6 |
Thanks Jimmy!
10-04-2021, 04:29 PM | #7 |
Epoxy has a recoat window . After that time you have to sand no matter what you put on over it.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
10-04-2021, 05:20 PM | #8 |
Sinces your epoxy primer is 5 years old it's possible there may be rust under it
Epoxy primers that use zinc phosphate as an anti-corrosion device are sacrificial. Knock it down with 180, you'll probably go down to bare metal in certain spots, apply at least two coats of your anti-corrosive epoxy and follow it up with your surfacing epoxy and you should be good to go |
