Old 07-18-2021, 03:40 PM   #1
eighteenninetytwo
Engine issue - vacuum related?
Blazer (350 sbc) starts fine, but stalls as soon as I take foot off the gas irrespective of choke position - it will keep running if i rev it but I don't want to do that. Could be vacuum related? I have (what I think is ) an old vacuum canister with two ports, it has one line from the front left side of the Edelbrock carb but the other port on it isn't connected? Should that be connected to something and a tube came off maybe?
I'm pretty new at the engine stuff, just getting into it bit by bit so please excuse me if this is a retarded question. Google tells me this is supposed to hold a vacuum for brakes etc but wondering how it does that with an open port - hence my question.
eighteenninetytwo is offline   Reply With Quote
Old 07-18-2021, 05:24 PM   #2
eighteenninetytwo
Re: Engine issue - vacuum related?
$16 fix for new vacuum canister and cap for the open port. The open port SHOULD go to actuate vents for the heater etc but as I only drive in the spring, fall and summer, and in California the heating isn't an issue. That can re attached next time the dash comes off.
Old 07-18-2021, 05:37 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
That is a vacuum accumulator. For now just put a plug on it and see if your problem goes away. Double check your PCV and brake booster don't have a major leak.
Old 07-19-2021, 01:12 PM   #4
eighteenninetytwo
Bought a replacement and put a cap on that = all good. A $20 fix including the can of seafoam I got to help clean up any deposits I accumulated driving the thing home with no vacuum. Wish all fixes were this cheap.
Old 07-19-2021, 03:08 PM   #5
Hart_Rod
Hart_Rod's Avatar
Nice. Did you put the seafoam in your gas or down the carb?
Hart_Rod is offline   Reply With Quote
Old 07-19-2021, 03:32 PM   #6
eighteenninetytwo
Both in the Oil and the Gas. Not in the carb - that didn't occur to me actually.
Old 07-19-2021, 08:58 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
Be sure to change that oil out. I wouldn't drive it long at all with the oil thinned out with that stuff.
