03-28-2023, 11:40 AM | #1 |
Bed Wood Guys: Painted Wood Question/s
Looking for some guys that have done a wood floor bed or two for some guidance regarding coverage of 'paint' as a coating vs. the type of wood used.
My specific question is regarding Oak... There are two common variations it seems for truck beds that can also be purchased through online sources from my recent browsing escapades. I noticed 'Oak' & 'Red Oak' listed frequently. If a guy is painting the wood (Black or Aged/Ashy Gray if you need to know exact color possibilities), how drastic would the color shade difference be if you painted these two different types of Oak? And for reference, the paint would be over a sealer (POR or something similar). My specific reasoning is in the event something needs replacement or repair & one is easier to obtain in a certain size vs the other would the Red-Oak yield a darker or different finish vs the regular Oak if placed side by side? I can see Stains or Clears being impacted but not sure how an actual paint color w/solids over sealed would fare. Looking for some hopeful been-there/done-that sort of input/experience please. Thanks in advance!
03-28-2023, 04:20 PM | #2 |
Re: Bed Wood Guys: Painted Wood Question/s
Not directly answering your question, but...
Red Oak is porous and will hold moisture - not sure you want that in a bed. White Oak is not porous, it is/was used in ship building. White Oak is more expensive than Red.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
03-28-2023, 04:37 PM | #3 | |
It seems the Oak fairs weather better & is 'harder' vs other options. It's just a truck bed so Pine would work to for that matter but multiple online/vendor/sources had kits listing Oak as the material. It won't be a show queen. It's a 20-footer.
03-28-2023, 09:06 PM | #4 |
I went Trex, after pricing out a decent wood and a decent coating, and the probability of having to do it again some time. I'll never have to redo composite decking. But that still doesn't answer your question (grin).
03-28-2023, 10:12 PM | #5 |
I was looking for the 'easy' button on the wood floor. Pre-cut/drilled kit. My floor base sub frames were done utilizing the OG hardware location, dimensions, & placement.
03-28-2023, 10:28 PM | #6 |
I just put a bed together for friend, trust me “easy” is not in the equation……
03-28-2023, 10:28 PM | #7 |
I was looking for the 'easy' button on the wood floor. Pre-cut/drilled kit. My floor base was done utilizing the OG hardware, dimensions, & placement in the name of simplicity (albeit w/a raised floor).
03-29-2023, 07:01 AM | #8 |
I've done mine a couple of times and had issues with both, but I was using a clear coat. You need to make sure you use white oak and really make sure the underneath side and edges are sealed also. Mine are in need of being redone again and I talked to Dino 63, haven't seen him on here for some time, He uses Thompson black water seal, said it'e killer!
Rick |
03-29-2023, 08:53 AM | #9 | |
The statement is in comparison to sourcing the deck surface from whatever material, cutting things to whatever widths/lengths, machining the bed strip grooves, drilling holes etc while keeping visible hardware in crisp alignment.
03-29-2023, 08:56 AM | #10 | |
03-29-2023, 09:28 AM | #11 |
If I understand your question, are you asking if the paint will have a different shade depending on the type of oak you use as bed wood? Lets say white oak vs red oak? I do a little woodworking on the side and this would be just my opinion. The difference in white oak and red oak would show if you were doing a clear stain/finish on the wood. Red oak, well, has a red tone to it and white oak has a more light brown look to it. So those colors would show through the clear finish. I am not sure yo would see much of a difference if you painted them black and then cleared over top. If you are painting, I think the grain would show more of a difference then actually the color of the wood itself. For instance and no matter if it is white or red, if you have a bunch of tight grained pieces and then one piece that has a wider grain, I think you would see that in the paint because the grain absorbs the paint differently. It would also show in the grain the way the board was originally sawn ie quarter sawn or rift sawn. So I think the decision would depend a little on how you would like it to look and how particular you want to be.
I am redoing the bed in my truck and I pulled whatever oak boards I could find from my stock to make into the bed wood. I have one that is white oak and the rest are red. Some have knots and checks and one I had to fill a couple checks and knots with epoxy. But, I had everything in stock and only need to buy two full sets of planner knives to get that hard oak milled to thickness. I agree that white oak would be better. But, I didn't have enough in stock to do the entire bed in white oak. I am clearing mine, so someone will definitely be able to see that one board is white oak. But is a driver, I had the material, and it is ok with me. Rob |
03-29-2023, 10:06 AM | #12 | |
I'm no carpenter nor 'wood' guy. Def no tools for it. I know a couple of guys w/limited equipment but I like to minimize others involvement because I invest WAY MORE time/effort in detail stuff & don't want to subject them to that. I'll likely move forward since it seems the 'grain' will be my biggest visual issue vs color/tone variance if something ever comes to that.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-29-2023 at 10:23 AM. |
03-29-2023, 03:19 PM | #13 |
03-29-2023, 05:15 PM | #14 |
About a quarter of the way down this page
03-31-2023, 01:15 PM | #15 |
I've done a few bed woods painted black, both in pine and oak but I'm not sure which variant of oak. If you don't a kit yet, check with Trucks USA in Abbeville SC, we get all of our floor kits from them and they fit great. All three of the bed floors in the pics were from there, they come pre-cut to size and sanded, you only have to drill the perimeter bolt holes once it's all installed. The middle mounting holes are pre-drilled.
Oak has deeper/more porous grain. Using a pore filler first would lessen this look and is necessary when staining and clearing, or you'll get air bubbles in the clear from the air in the pores expanding as the clear dries. I haven't had that issue with primer/paint. Another with oak. The grain still shows through paint with pine, but it's smoother than oak. This one was shot using a lower gloss paint than the other two. Seems to be more variation of grain pattern with pine than with oak. Another in pine showing the differing grain patterns within the same kit.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 03-31-2023 at 01:20 PM. |
03-31-2023, 01:51 PM | #16 | |
03-31-2023, 01:56 PM | #17 |
...just another truck junkie..
Great info, astronaut. Thanks for that!
Mike "Bear" Shea |
03-31-2023, 08:30 PM | #18 |
I like the Oak over the Pine. Pine doesn't usually take a stain nicely, and while I know that's paint, the grain variation in the Pine does not look as nice (to me) as the Oak.
04-01-2023, 11:50 AM | #19 |
What are you guys using for the finish?
