04-20-2021, 10:22 AM | #27 | |
Re: Daves new 68 chevy swb
2. I had things mounted in a way that they were not easy to get to. For instance the main fuse for the ride controller/compressors, I think its a 70 amp maxi fuse was mounted clear down on the frame rail and I am here to tell you it was not easy to get to. When I reworked the raised bed structure I built in rear mounted battery mounts so i could move all critical electrical connections right at the back of the truck where things are easy to get to. im 6'5" and not on a diet so squeezing myself clear up into the truck to replace/troubleshoot a fuse or electrical connection was not fun at all. I will try to get some good photos gathered up of some of this stuff this evening. If there is anything specifically someone wants to see just ask and ill try my best.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
