10-14-2011, 11:08 PM | #1 |
Inexpensive air driers?
Is there such a thing? I need to find something, I'm tired of my sandblaster getting wet, and I should start painting one of these days. The guy at the compressor store wants way more $ than I have for what he calls bottom-of-the-line unit.
All I have right now is one of those 40 dollar inline thing that's about 2" diameter and 4 or 5 long. It does next to nothing, in my opinion.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
10-15-2011, 12:38 AM | #2 |
Re: Inexpensive air driers?
Describe your air line setup.
If you only have a rubber air hose connected at the compressor, there's going to be a lot of water vapor coming out then other end. its not easy to get water out of hot air. You meed to cool it a bit before it flows through the dryer. There are plenty of writeups about air line systems. Try tptools.com if you want to see one example. Drain the water out of the tank every time you use it. More often if possible. This is just for the health of the tank... |
10-15-2011, 02:23 AM | #3 | |
Hollister Road Co.
10-15-2011, 12:42 PM | #4 | |
I do need to do some hard line plumbing. That is what I have-hose coming right out of the reg. I'm real tired of dragging an air hose around. And I need to be better about draining the tank.
10-15-2011, 01:15 PM | #5 |
Get a few nipples, elbow and a ball valve to move the drain valve out to the side of the tank. Then you can reach it easier and the nipples make a small holding area for water. You don't have to drain the tank, just open the valve for a second to let the water out. Do this every few hours til no water comes out.
I'll bet less than 1 in 1000 home users have a nice refrigerated dryer but if you have the money... |
10-15-2011, 01:50 PM | #6 |
i use an inexpensive (less than $50) drier from harbor frieght then i have a length of hose40' that goes into an old 30gallon compressor tank and another drier coming out of that tank that my work hose ic connected to// i live about 1/8mile from ocean in florida and have had zore moisture problems with my pressurized sand blaster pot ,my blast cabinet, or spraying paint either
10-15-2011, 05:10 PM | #7 | |
Hollister Road Co.
10-15-2011, 02:16 PM | #8 |
10-15-2011, 02:54 PM | #9 |
nobody has asked the question so i will// what type of sand are you using? are you using "play sand"(loaded with moisture from home depot) or bagged graded sandblasating sand?
10-15-2011, 11:04 PM | #10 |
In my cabinet I use 40/30 garnet and in my pot I use 70 grit silica. And yes, I take the necessary precautions.
10-15-2011, 11:33 PM | #11 |
Here are some ideas ....http://www.hotrodders.com/kb/air-compressors
"I feel the need for speed!"... as soon as I am done with my nap. |
10-15-2011, 05:07 PM | #12 | |
Hollister Road Co.
10-16-2011, 08:48 AM | #13 |
I am a Referee of life.
I actually installed an "inverted bucket steam trap" on a work compressor once.As the water fills the trap it raises the bucket and lets the water pass out a female pipe fitting.as the water level drops the bucket drops and closes the orifice.It kept the water drained from the tank so that a smaller air dryer worked instead of having to buy a larger dryer.You might also try that on drip leg to help lower the moisture content even more.The less wet there is the better a dryer works.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-18-2011, 09:05 PM | #14 |
Funny how things work out. Over the weekend, I finally decided to start running some hard line properly, but didn't know how to pay for some pipe. Then on Monday, the plumber at my work said he was gonna throw some away, because it was pre-painted and he didn't have any use for it. I asked him if I could have it and he said heck yeah, keeps him from having to mess with it. 3 sticks of 1" and 2 of 3/4". Painted off-white.
Now I think I have some swearing-er, plumbing in my future.
11-09-2011, 11:34 PM | #15 |
I built my own refridgerated air drier for our shop very cheaply. I'll post pics tomorrow. Works great, pulls all the moisture out and I've had zero problems with contamination while painting. You'll wonder why you never though of this
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-09-2011, 11:42 PM | #16 |
11-09-2011, 11:51 PM | #17 |
Here's a hint: It involves a 5 gallon bucket and something you might find in a dorm room.
11-10-2011, 11:33 AM | #18 |
Here it is guys. Its a dorm fridge with a 5 gallon bucket of water inside, and 20 feet of copper tubing coiled inside of the bucket of water. The cold water cools the air line so that the water vapor can condense and be caught by the water trap on the outside of the fridge. I've got it connected with quick disconects so I can move it if I need to. Works great! I haven't had any problems with contamination since I started using it.
11-11-2011, 01:17 PM | #19 |
Hollister Road Co.
True redneck engineering would be a kegerator and wrapped the hose around a full keg but I have to say its a great idea.
11-11-2011, 05:10 PM | #20 |
I think there is something that has been overlooked. Is the compressor really up to the task of all that blasting? If you are running the snot out of the compressor, it is going to make HOT-WET air. Fixing the wet part can be done but you may find yourself still with other problems (burnt valves, worn rings). A properly sized compressor with a factory aftercooler will deliver near ambient dew point air all day long.
The most effective band-aid (outside of a refridgerated unit bought or home-brewed) would be described below. 1 flex line out of the compressor. 2 to a copper line as far down the wall as you can at a slight downward incline. 3 mount your current moisture trap filter down at the end of the run in step 2. 4 option Motorguard M-60 or Wix aquacheck both less that $100 5 your current regulator and what ever piping or hoses you want. That's just my .02 |
11-11-2011, 07:08 PM | #21 |
Our compressor at the shop is outside in it's own shed. There's about 30 feet of pipe to bring air inside the shop with a water seperator/drain inside the shop at the lowest point- this is all before air is routed to the rest of the shop. This first drain will catch some water, but not much since the air hasn't had time to cool off enough to condense the vapor out of it. I've got the fridge drier in my stall and it catches about four times more water than the first trap, and that's after its been though the first trap! The air line coming out of the fridge will actually be cold to the touch all the way up to the air reel mounted near the ceiling, cold enough for water to condense on the outside of the lines! Unless the air is cooled enough, the vapor can't be condensed and drained out, no matter how many water traps you have or where they are arranged.
11-18-2011, 12:54 PM | #22 | |
11-18-2011, 02:00 PM | #23 | |
I'm big into high performance aircooled VW's and many guys running turbo's (350-400+ hp) are welding water jackets around the cylinder head fins to help cool the heads off better than air alone could. The air cooled heads are fine for normal driving and low loads, but the air can't absorb the heat from the heads well enough to keep them from overheating when making big hp over an extended amount of time. It's the same principle where aluminum cylinder heads are able to run more compression without detonation vs using cast iron cylinder heads; the aluminum transfers heat away from the chambers more readily so the chamber surface doesn't get hot enought to cause detonation.
11-11-2011, 08:23 PM | #24 |
Newbee
^^^^ Exactly ^^^^^
11-12-2011, 04:29 PM | #25 |
I agree refrigerated air driers are nice and certainly work. Astronaut my hat is off for having the best home brewed refrigerated drier I have seen. The arrangement I suggested is listed as an inexpensive (under $100) band-aid not a cure. I still stand by that a properly sized compressor with a factory aftercooler will solve alot of problems. I have personally installed a full package Gardner Denver R30 pump, spinning 700 rpm, through the factory aftercooler, to the tank and then to a Wix Aquachek as suggested above. That unit when new provided 0 degree dewpoint air as tested by a Beko DPM.
A machine with a big pump turning slow is my day in day out recommendation. That pump turning 700 rpm puts way less heat into the air to begin with, compared to say a marginally sized pump running 2500rpm (IR Standard Package from sears or Tractor Supply). My current machine at home is an IR model 2340 but I changed the drive shieve to get the pump speed down. That is into an Toolguard filter. If you would like I can ask the Beko rep if I can borrow a demo Dewpoint monitor, and test it. I would wager it is less than the 32 that any refrigerated drier is capable of. |
