08-09-2016, 11:39 PM | #1 |
Anyone else have fuel vapours coming.from filler neck ?
I completed my ls swap using a in tank fuel module from a 2003 truck. The system has a feed and return line. I am finding that there is now a excessive amount of fuel vapour coming from the vented gas gap. I have a 1/4" line from the intake thats capped down at the transmission and a 1/4" line from the fuel module. Has anyone run thoes lines into a charcoal can and used the factory valve in the intake to vent the system ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-10-2016, 03:47 AM | #2 |
Re: Anyone else have fuel vapours coming.from filler neck ?
The PCM wont Open the purge solenoid unless certain criteria are met, and in a swap you most likely dont have everything hooked up for that to happen. I just hook the vent line from the tank to the charcoal cannister and leave the other fittings on it open. I dont get any fuel smell that way.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-10-2016, 11:36 AM | #3 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-10-2016, 05:20 PM | #4 |
meowMEOWmeowMEOW
The S10/Jimmy charcoal "box" is cheap and at every junkyard if you really need it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-11-2016, 07:07 PM | #5 |
So I am thinking about adding the charcoal can....The smell of fuel vapors at stop lights in town is actually concerning me if someone threw the butt near my Suburban. I don't know what would happen.
Does anyone know if the newer say 71 72 trucks came with a Non-vented cap for the tank ?
09-12-2016, 10:48 AM | #6 |
meowMEOWmeowMEOW
Nothing would happen, you'd never achieve a functional a/f ratio. People smoke at gas stations all the time (not a good idea, but totally happens). They'd have to toss their butt on the trim of your filler neck, and even then, probably nothing.
