Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-16-2009, 05:26 PM   #1
Sir Fisher
Sir Fisher's Avatar
Project: 1970 4x4 underway...
here are some photos of the truck before everything got underway...
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 01-16-2009, 05:29 PM   #2
Sir Fisher
Sir Fisher's Avatar
Re: Project: 1970 4x4 underway...
more pics...
Old 01-16-2009, 05:35 PM   #3
Sir Fisher
Sir Fisher's Avatar
the project started last oct or so and i've been taking thing out and apart... just been too lazy to post pics. now, here's some pics the body work that's been done to date... the driver side is done, put in the a/c deletes and moved the gas fill to the back. starting on the passenger side next week and doing some more work in the engine bay.
Old 01-16-2009, 05:42 PM   #4
Sir Fisher
Sir Fisher's Avatar
in the future, i will be installing a LQ4 mated with a 4L60E and NP241. changing the closed nuckle 8 lug front and rear ends with 6 lug axles w/disk brakes all the way around from a 1972 blazer, 3.73 gears. gas tank from fuelcell guy... more info and pics to come later.
thanks to all the other build threads that i've been getting great ideas from!!
Old 01-17-2009, 12:35 AM   #5
Fubar
Fubar's Avatar
I love seeing these 4x4 build threads, especialy with cool drivetrain upgrades. Are you using a driver's side front axle or switching out the t-case? keep the updates coming!
Fubar is offline   Reply With Quote
Old 01-17-2009, 11:09 AM   #6
Sir Fisher
Sir Fisher's Avatar
i'm using a passenger side front axle and a np241... when i bought it, i remember i made sure everything fits... but now that you ask... i'm second guessing myself... my axles are at my buddy's place getting rebuilt... just new bearings and seals.
Old 01-17-2009, 11:44 AM   #7
Grapdawg
Driven a 72
Grapdawg's Avatar
This should be a great build, wish i had those parts to start with. I will be watching this build for sure. Solid truck!!!
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
Old 01-19-2009, 01:56 PM   #8
95chevymutt
just wondering why your changing the 8 lug or to 6
95chevymutt is offline   Reply With Quote
Old 01-20-2009, 12:35 AM   #9
Sir Fisher
Sir Fisher's Avatar
i wanted to go with the open knuckles, the closed knuckles had horrible turning radius... i also had a good deal on my 6 lug axles, and the rims that i want were also 6 lug rims. i know it's heavier duty, but i'm not doing anything that'll require the heavy duty needs.
Old 01-20-2009, 01:09 AM   #10
TwoFiftyShifter
I liked that truck before the tear down!
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 02-05-2009, 12:13 AM   #11
Sir Fisher
Sir Fisher's Avatar
just got the axles back from my buddy's place today... new bearings, seals, u-joints, brakes (4 wheel disks) and fresh paint.
Old 03-23-2009, 12:51 AM   #12
Travis K
Travis K's Avatar
Any updates? I have the same engine/tranny/t-case combo coming this week. How are you planning on running the passenger side front end, when the t-case output is on the driver's side? Keep us posted on the engine swap.
Travis K is offline   Reply With Quote
Old 03-23-2009, 09:31 PM   #13
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Sweet truck, cant wait to see the pics of the tank installed, I wanna do the same thing.
Eturnit3 is offline   Reply With Quote
Old 04-02-2009, 04:24 PM   #14
drtwhls
*bump*
I'm working on a 3/4 ton 4x4 similar gameplan (6.0l, 4L80E, NP205)... I went with a JB conversions 3-1 205 case to bolt up to the adapter on the 4l80e to retain the passenger drop and use the stock axles (44 front and eaton rear, disks all around). Curious to see where you are headed.
drtwhls is offline   Reply With Quote
Old 04-02-2009, 10:27 PM   #15
Sir Fisher
Sir Fisher's Avatar
the transfer case you see in the pic with the motor is a Borg-Warner 4484, i'm not going to be using it. i have a np241 that i'm putting in and it has a passenger side drop.
i'm finishing up on the passenger side body right now. i'll take some new pics soon.
Old 04-04-2009, 09:47 PM   #16
115-K10
115-K10's Avatar
I was actually thinking about using a modern 4x4 engine tranny and transfer case too. However, the transfer case on the newer trucks have drive shafts on the driver side. I was thinking that the front axel would have to be modified to move the pumpkin. What do you plan to do?
The chum Bucket - SWB K10 Restoration - http://67-72chevytrucks.com/vboard/s...d.php?t=329775
1971 SS454 Monte http://www.hemmings.com/mus/stories/...feature14.html
1970 - Monte Carlo Convertible, LS6, L89, M22 Build
http://www.firstgenmc.com/ubbthreads...=360236&page=1
1970-SS454 Tripe Black - Barn Find
http://www.firstgenerationmontecarlo...=421201&page=1
115-K10 is offline   Reply With Quote
Old 04-04-2009, 10:10 PM   #17
Sir Fisher
Sir Fisher's Avatar
drtwhls is going with a np205 and i'm going with a np241... was going to go with the np208, but don't remember why i chose the 241 instead. both of these are passenger side drop t-cases. there are probably others out there with a passenger side drop that you can choose from. on the 205 i think you'll need an adaptor plate to connect it to a 4l60e or 4l80e... but the 241 can bolt right up. you'll need to do some homework if you wanna see how others will bolt on. then you won't have to do anything to the front axle. or i suppose you can find a front axle with a driver side drop instead of a t-case.
Old 04-05-2009, 10:38 PM   #18
drtwhls
115-K10
When I started I had the same question. I wanted to maintain the 3/4 ton drivetrain which is why I was dead set on the 205. The 205 passenger side drop is extremely rare. I rsearched and purchased a 3-1 conversion kit for my 205 from JP conversions and it let me retain the 205 passenger drop. The JB conversions kit comes with a new case that will bolt up to the stock adapter same as the 241 would bolt to or to the old style figure 8. My front end is open knuckle and didn't want to mess with changing axles. The 4L80E combo is only 2.25" longer than the stock SM465 and NP205. The largest obstacle to getting my LQ4 in was the motor mounting, the 2wd guys can get bolt in mounts, but us 4wd guys don't have the same type of crossmember set up to be able to od the same.
Old 05-19-2009, 09:45 PM   #19
Sir Fisher
Sir Fisher's Avatar
progress has been slow... that's cause fishing is really good right now... but we're working on it every chance we get!! everytime i take something apart, i always end up finding something i really don't want to find... maybe i should stop tearing things apart and just pretend it's o.k.
Old 05-20-2009, 09:45 AM   #20
renegade6
I've tried that method and there is no quicker way than that to drive you to madness...You always wonder if you should have fixed this or that.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 05-20-2009, 09:53 AM   #21
dammitmitchell
the pollock
dammitmitchell's Avatar
hey dud am i the only one hrer to notice that your porportioning vaulve is in a weird spot?
just my 2 cents..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-05-2009, 01:19 AM   #22
Sir Fisher
Sir Fisher's Avatar
closed off the manual shifter hole and sealed off the air vent. almost done with the passenger side vent; will update with more pics soon.
Old 02-14-2010, 06:33 PM   #23
Sir Fisher
Sir Fisher's Avatar
progress has been slowed due to the snow storms up north... i don't know what the snow storms have to do with me down here in florida, but it's a good excuse... last months update, took the bed off to clean up behind the cab, here are some pics; going to paint the cab soon; hope i'll stick to my goals this time.
Old 02-15-2010, 12:54 PM   #24
dammitmitchell
the pollock
lookin good!
Army vet 02-08
Old 02-15-2010, 01:00 PM   #25
msgross
msgross's Avatar
nice project, nice work so far too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
