Old 06-22-2010, 05:36 PM   #1
67Dad
7" vs. 9" vacuum booster for brakes...which is better?
67-c10...we are adding power brakes. Apparently the conversion can be either 7" or 9". Do any of you have experience with which is best? 7" presumably leaves more engine access room, but we have a straight 6 292. Does 9" give much more "boost"? Thanks in advance!
Mark
Mark
57 Austin Healey 3000 (sold many moons ago, unfortunately)
67 C10 (in progress, son's) w/ 1993 350 SBC, '96 Vortec heads (custom polished ports), EPS Performer intake, Holley carb, cam, MSD ignition
93 C4 Corvette (mostly done, son's)
67Dad is offline   Reply With Quote
Old 06-22-2010, 05:50 PM   #2
umwtnt
umwtnt's Avatar
Re: 7" vs. 9" vacuum booster for brakes...which is better?
A 9inch booster is better. Its simple physics, the 9 inch has more sq in for the vacuum to act upon the the 7 inch. This helps apply more force with less pedal pressure. You have the room you can go to a bigger booster if their available.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 06-22-2010, 07:22 PM   #3
mbgmike
Mark
Actually the unit that came on it was 11" in dia.
You have more boost. Sometimes they use a dual diaphragm booster in the smaller sizes to gain more room. If you have any questions feel free to call or drop buy we have done a lot of conversions.
Mike
mbgmike is offline   Reply With Quote
Old 06-22-2010, 11:27 PM   #4
Musclerodz
Either run a factory 11" or dual 9". Don't bother with single diaphragm boosters less than 11".
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 06-30-2011, 12:23 PM   #5
67Dad
OK...we are back on the brake project after many diversions. Any opinions out there as to the best all around solution to adding power brakes (w/ new master cylinder in the process) to what was a manual brake 67 C10?
Thanks.
Mark
Old 06-30-2011, 02:48 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Ummm, just do it.
Member Nr. 2770
Old 06-30-2011, 09:36 PM   #7
68gmsee
Active Member
68gmsee's Avatar
OK.... Any opinions out there as to the best all around solution to adding power brakes (w/ new master cylinder in the process) to what was a manual brake 67 C10? Thanks.
Go to Webster and talk to mbgmike. He'll set you up or give you good advice on what you need.
Otherwise if you have a salvage yard that has some 67-72 trucks find one with the power brakes and take everything off that pertains to the p.brakes: mounting bracket, master cylinder, prop valve and include the brake pushrod inside the cab. The rubber hose and check valve you can get at local parts stores and if the booster is defective you'll have the core.
68gmsee is offline   Reply With Quote
Old 07-01-2011, 09:46 PM   #8
1969stepside
1969stepside's Avatar
what i would do is to take a power booster off a 3/4 ton and put it on a half ton because the 3/4 ton booster is desgined to stop a heavier truck and the half ton is lighter and then u can have alot of brakes lol that is what i would do just go to autozone and order u a 3/4 power booster and use ur 1/2 ton booster as a core
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 07-02-2011, 05:41 AM   #9
sick69
sick69's Avatar
Or to throw another twist,,,,convert to hydroboost and skip the vac booster
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 07-02-2011, 06:19 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
Either way get a booster bracket from CaptainFab... it allows you to use the late model 1988-1998 full size truck/Tahoe/Burb booster (smaller, less expensive, can be found at any parts store) unless your going for stock resto... The only thing to check is column shift clearance. Click HERE
You can also use this for hydroboost if you want to upgrade (now or later)...
Rich
1972 K5 Blazer CST Click HERE
Old 07-02-2011, 10:43 PM   #11
1969stepside
i like how that bracket is smaller and does not stick out as much as the stock one
Members i Have met
Earl Slick68
Old 07-03-2011, 08:48 AM   #12
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
X2, I love my hydroboost!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-03-2011, 10:28 AM   #13
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I like to see how the hydroboost looks and works on your truck. Could you post or send me some pics
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 07-03-2011, 04:42 PM   #14
usmcchevy
usmcchevy's Avatar
PM replied, Pics and some info are on pages 9, 10 and 13 of my build thread. Link in sig
Build thread
LSx Swap FAQ index
brake booster, power brakes
