Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-02-2011, 06:22 PM   #1
RANDOMIZM
RANDOMIZM's Avatar
Frankenburb
Start a thread following the build of my 68 burb.
I bought it with a ton of cancer, a 350sb (out of a 69 cab) that ran like hell, and was lowered using blocks and coil springs. All 3 rows of seats.
With the exception of the visible rust in the typical areas, it didn't look to daunting. Then I started cutting, and found a previous patch panel, that had simply been overlapped, and filled with about a 1/4 inch of bondo.
It has been a long process, and I have quite a ways to go still. I work on it only random weekends when I'm home from college, and summer/winter breaks, with the exception of last fall, while I was studying Abroad.
RANDOMIZM is offline   Reply With Quote
Old 03-02-2011, 06:24 PM   #2
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
First thing to happen was cut out all the cancer.
Old 03-02-2011, 06:28 PM   #3
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Patched in the new pieces.
Old 03-02-2011, 06:30 PM   #4
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Then Shaved.
Old 03-02-2011, 06:32 PM   #5
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Gas Filler Relocated. Installed the Custom rolled upper quarter panel. Quick Prime.
Old 03-02-2011, 06:35 PM   #6
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
It still needs body work to be straightened back out (especially with the damage from previous owners). Tons of work still to come on it.
Old 03-02-2011, 10:28 PM   #7
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Frankenburb
very nice work....keep those pics coming
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-03-2011, 01:53 AM   #8
1sik7t2
dave
1sik7t2's Avatar
Re: Frankenburb
keep at it man....i know i have rust underneath but am afraid to REALLY know how bad.....
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 03-03-2011, 03:28 AM   #9
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Ya, the first chunk i started cutting out was when I came across the previous Hack Job of a patch. So every time I went to cut out another section of rust, I was afraid that my work load was going to double again.
Build Thread: Frankenburb
.._________
/____|__|__\___
l__(o)______(O)_l
Cruizin' Thru... Low N Slow
Old 03-03-2011, 10:03 AM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Frankenburb
not sure if you saw this thread, but I thought it might be good reference to your work....http://67-72chevytrucks.com/vboard/s...d.php?t=436486
Geoff with a G
Old 03-03-2011, 11:37 AM   #11
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
I hadn't seen that thread, but man, impressive. Can't wait till the day when my patch panels come out that smooth, with no need for body work. Granted, this is my first time doing anything like this (and I've got many years ahead of me to perfect the technique).
.._________
/____|__|__\___
l__(o)______(O)_l
Old 03-28-2011, 10:12 PM   #12
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
So, got bags, switches, gauges, and line in the mail today (at school, so many people are confused about the big rubber things sitting in my floor). The compressor is sitting at home, and I will be picking up a tank on my way home in a couple weeks. can't wait to start putting this all on. Until I can get home, I will be doing a lot of trips out to the burb to play with ideas for mounting the gauge and switches.
.._________
/____|__|__\___
l__(o)______(O)_l
Old 03-28-2011, 10:22 PM   #13
Newtz67
Newtz67's Avatar
Re: Frankenburb
Lovin it!
Newtz67 is offline   Reply With Quote
Old 03-30-2011, 06:36 PM   #14
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Frankenburb
very nice!!
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 03-30-2011, 10:49 PM   #15
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Thanks Guys.
Little Info:
4 D-2600 Bags
1/4" Lines
2 Manual Paddle Valves
Viair 380c
Dual needle 200psi Easystreet Gauge
Bought it all from way2low2
Great Price, Great Service
.._________
/____|__|__\___
l__(o)______(O)_l
Old 04-28-2011, 07:51 PM   #16
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Got the rear end bagged this past weekend. Unfortunately, the frame is holding it up, so there isn't alot of difference between aired up and aired out. =/
Gauge Location
Tank/Compressor Location
80PSI
10PSI
Bag on Truck Arm.
Unfortunately, the bag is nowhere near fully compressed when the axle hits the frame. Right now, I can ride at about 55psi, with just me in the burb, and have it riding about the same (clearance anyways) as it was with drop springs.
.._________
/____|__|__\___
l__(o)______(O)_l
Old 04-28-2011, 08:17 PM   #17
Newtz67
Newtz67's Avatar
Re: Frankenburb
Nice!
Old 05-11-2011, 01:57 PM   #18
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
So, Have been really busy as school lately. Luckily, I just finished finals, unfortunately I still have 5 weeks of summer courses so that I can graduate on time.
Anyways, Summer plans for the beast:
Laying Rockers
-Build Custom Cross Members, including Drop-Member up front
-Custom double wall 3x2 semi-stock frame
-Monster Notch (Lay eventual 33" tall tire-- thinking 22/20 combo)
-Triangulated 4 Link
-Finish Bagging up front
Engine Rebuild
-350 clean up... try for more power/milage
--Depending on parts I can get my hands on stroke it to 383.
-Headman Headers
-Be Cool Radiator
Random Stuff (Not vital to finish before end of summer)
-Custom Built Gas Tank
-Continue Body Work
-Track Down Mexi-Blankets for upholstry
-Track Down Junk Yard Sway-Bars
-Keep overall Cost Down
Luckily Most of what I need for this summer is already laying in my garage at home, just begging to be done.
.._________
/____|__|__\___
l__(o)______(O)_l
Old 06-15-2011, 05:57 PM   #19
1sik7t2
dave
1sik7t2's Avatar
Thumbs up Re: Frankenburb
my personal favorite is ur first item LAY ROCKERS...MEXI BLANKETS , TJ OF COURSE.....WOULD LOVE TO COME CHECK IT OUT SOMETIME...MINES FINALLY DRIVING and should be running correctly today, as we speak let me know i know theres a show at qualcomm july 10th....
Laying Rockers
Engine Rebuild
-Headman Headers
-Be Cool Radiator
-Continue Body Work
Old 06-15-2011, 08:05 PM   #20
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
1sik7t2:
Unfortunately, I won't be out at the show at Qualcomm, one, I'll be on my way home from Nor Cal late that day and two, the burb will most likely be in pieces in my garage up near Long Beach.
When I head back to school in the fall, I'd love to get a chance to meet up and see what you've got going on.
.._________
/____|__|__\___
l__(o)______(O)_l
Old 07-13-2011, 09:26 PM   #21
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Hey guys,
I'm working on removing the inner wheel wells from the rear, and I was wondering how you guys got the whole inner to come out? I'm struggling to get it out, and have already cut one side to pieces trying to get it out of the burb. Any help/pictures would be much appreciated.
Thanks!
.._________
/____|__|__\___
l__(o)______(O)_l
Old 08-11-2011, 01:20 AM   #22
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
So, plans change. I had some things come up, and wasn't able to get to work like I had planned. But, it has brought about some good (imo). Instead of just cutting up the stock frame, I have started to build a full custom frame. Some thick walled 2x3 frame rails. Designed to lay out on a 33x22-15 (going pro street). Went to pick-your-part last weekend and picked myself up a nice little Ford 9" for my rear end.
I have managed to get some work down on the burb while I drive it. I installed a new water pump, and Be Cool radiator. Also bolted in a couple Hedman Headers, flowing straight into a pair of glasspacks and dumped.
Unfortunately progress hasn't been as far as I'd like it to be for th summer, but tihs seems to be the story of my build. I'll have some pics to post later, possibly tomorrow when I'm back on my regular computer, and have access to them.
.._________
/____|__|__\___
l__(o)______(O)_l
Old 08-18-2011, 12:44 AM   #23
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
Pic Update. Building the frame & Junk yard F*rd 9"
Building it to lay on 33" tall tires (with room to spare)
.._________
/____|__|__\___
l__(o)______(O)_l
Old 08-18-2011, 12:47 AM   #24
RANDOMIZM
RANDOMIZM's Avatar
Re: Frankenburb
and here are the exhaust pics.
.._________
/____|__|__\___
l__(o)______(O)_l
Old 08-18-2011, 08:51 AM   #25
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Frankenburb
dang custom frame...that's awesome but I'm not sure you'll get to lay frame with that exhaust
Geoff with a G
