Old 09-29-2013, 11:59 AM   #1
Midgets50
Midgets50's Avatar
front axle shock mounts
ive seen shock mounts that come of of the plate that is used with the u bolts. im not sure if these can be fabbed onto stock pieces because im not sure if these are cast. i dont have a picture currently but to help identify what im talking about. it is on 79 axles and they are also where my torque bar mounts
Midgets50 is offline   Reply With Quote
Old 09-30-2013, 06:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: front axle shock mounts
Anyone on here that can help?
Keith
Convert to disc brakes.
Old 10-01-2013, 03:26 AM   #3
andrewmp6
Are we talking about the front axle on a 4x4 truck right ?
andrewmp6 is offline   Reply With Quote
Old 10-01-2013, 07:14 AM   #4
Midgets50
Midgets50's Avatar
yes sir
Old 10-01-2013, 07:47 AM   #5
andrewmp6
Older truck but same idea http://67-72chevytrucks.com/vboard/s...d.php?t=384624
Old 10-01-2013, 11:57 AM   #6
Midgets50
Midgets50's Avatar
Thanks for the link andrewmp6, my only problem with this option is that my sway bar mounts are part of my top leaf springs plate that are bolted down. If i can weld onto that plate i can modify it to work but im not sure it is cast metal or not. http://67-72chevytrucks.com/vboard/s...d.php?t=140216 its similar to this users
Old 10-02-2013, 01:19 AM   #7
andrewmp6
I have no idea if its cast or not,Maybe ask in the 4x4 part of the forum they might know better then me.But worse case you could make your own out of plate steel and weld on the shock and sway bar mounts you need.
