Old 02-24-2015, 10:11 PM   #1
Firstgenfan
'53 duramax
Figured I'd start a build thread for my truck. Long story short, I've been working on this thing for alost 4 years as time and money allowed me to. I picked up an lb7 duramax for dirt cheap and after a lot of measuring I thought it would fit fairly easily. I also picked up a ginormous allison to back the lb7. Hopefully the pics will post, it's been a while since I posted pics on here.
[/IMG]
Firstgenfan is offline   Reply With Quote
Old 02-24-2015, 10:15 PM   #2
Firstgenfan
Re: '53 duramax
Had to cut the new firewall back out to clear everything. Floors also had to be cut to clear the trans.
Old 02-24-2015, 10:15 PM   #3
Chris.
Re: '53 duramax
Awesome! Keep us posted
Chris. is offline   Reply With Quote
Old 02-24-2015, 10:16 PM   #4
Firstgenfan
Re: '53 duramax
Firewall moved back and tacked in...
[IMG][/IMG]
Old 02-24-2015, 10:16 PM   #5
ol'blazer
ol'blazer's Avatar
Re: '53 duramax
this is a awesome!
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 02-24-2015, 10:19 PM   #6
Firstgenfan
Re: '53 duramax
New trans tunnel made. I'm not really a good fabricator, but I do what I can. We made the motor and trans mounts pretty much from scratch tho.
[IMG][/IMG]
Old 02-24-2015, 10:21 PM   #7
Firstgenfan
Re: '53 duramax
Trans mount and motor mounts
[IMG][/IMG]
[IMG][/IMG]
Old 02-24-2015, 10:40 PM   #8
MIKESAD50
Re: '53 duramax
cool build! wish I had your skill
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-24-2015, 10:40 PM   #9
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: '53 duramax
Project is looking awesome. I am working on a similar build. Are you able to run the factory oil pan?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-24-2015, 10:41 PM   #10
Firstgenfan
Re: '53 duramax
Everything actually fit pretty good as far as just dropping it in the frame. We had to notch out a lil bit to clear the oil filter and I have to rework the down pipe a lil bit.
[IMG]
[IMG][/IMG]
Old 02-24-2015, 10:49 PM   #11
Firstgenfan
Re: '53 duramax
Yeah the motor sits high enough. The trans pan is actually lower because we set the motor at -3 degrees to help get clearance at the yoke. Nothing hangs below the running boards tho. I wish I had a pic to show but I don't. I made my own floorboards and re braced everything to help with the structural integrity of the cab. This pic is of all the brace work on the floor, it's now skinned and smooth. This is also with the old trans tunnel I made.
[IMG]
[IMG][/IMG]
Old 02-24-2015, 10:53 PM   #12
CHIZZLER
CHIZZLER's Avatar
Re: '53 duramax
Very nice work. Gonna be a amazing truck. Good luck with the build. I will be a lurker.
61-crew cab D-max
Old 02-24-2015, 10:55 PM   #13
fisherman420
Re: '53 duramax
really digging this build! Lots of easy ways to add power to that LB7 too, with that torque curve that truck is going to be a rocket!
fisherman420 is offline   Reply With Quote
Old 02-24-2015, 10:59 PM   #14
Hawkerdriver
Hawkerdriver's Avatar
Re: '53 duramax
I want to follow this keep up the good work.
Hawkerdriver is offline   Reply With Quote
Old 02-25-2015, 08:43 PM   #15
Iceburgh
Iceburgh's Avatar
Re: '53 duramax
That much torque...are you boxing the frame?
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 02-25-2015, 09:11 PM   #16
Advanced Design
Advanced Design's Avatar
Re: '53 duramax
Cool fabrication work. The floor is solid looking.
Advanced Design is offline   Reply With Quote
Old 02-25-2015, 09:31 PM   #17
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: '53 duramax
Sweet project and great work on it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-25-2015, 09:31 PM   #18
Dieselwrencher
Re: '53 duramax
From the pics of the trans cross member, it looks like he has.
Ryan
Old 02-25-2015, 09:38 PM   #19
Firstgenfan
Re: '53 duramax
Yeah the frame is boxed from the rad support to the rear crossmember.
Old 02-25-2015, 09:39 PM   #20
Firstgenfan
Re: '53 duramax
Iceburgh, I've seen your truck down at the fall cruise last year, good lookin ride man, I should have mine down there this fall
Old 02-25-2015, 10:20 PM   #21
crestronwizard
Re: '53 duramax
I love this!
crestronwizard is offline   Reply With Quote
Old 02-25-2015, 10:43 PM   #22
Coach529
Coach529's Avatar
Re: '53 duramax
Subscribed......looks like fun!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-26-2015, 03:00 AM   #23
ghettoluxury
ghettoluxury's Avatar
Re: '53 duramax
And Ryan from Trucks thought putting a D-Max in a square body was cool. This is going to be a monster.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-26-2015, 08:45 AM   #24
Firstgenfan
Re: '53 duramax
That's easy, there's twice as much room!
Old 02-26-2015, 09:33 AM   #25
solidaxel
solidaxel's Avatar
Re: '53 duramax
All that weight on coil overs and Mll IFS will that be enough spring for a Duramax?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
