1966 lay frame build
I didn't want to start a thread until I had something decent to show off. I am building a 1966 C10 SWB BBW factory a/c cab that will lay frame and it will have a LQ4 with a performance LS3 top end. Started with rust repair. BTW, I hate the rust repair.
![]() Join Date: Feb 2015
Re: 1966 lay frame build
Lookin great so far!
After the cab was rust free and the chassis components from Choppin Block came in, I realized that I did not want to use the factory frame rails. I decided to fab rails from the back half to the front bumper. Started on the welding table.
Finally got it down on the ground and dropped the motor in. The stock exhaust manifolds do not fit. Does anyone know a good header for an LS3 that are compact?
Lookin good!
You can find me on Instagram @neveno_cten |
I'm just glad to be here!
Looks good so far. I used a Headman Header for LS swaps on my last one. They have gone up in price a bunch since I bought them.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Frame looks good!
Looks like a real good start.
Do a little layin' frame myself. I'm in. |
Been a lot of work since I last posted.
Any pictures for the "in between" period?
lookin good
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039 She may not be the prom queen but at least she puts out.. |
I always go long periods of time w/o posting. I was able to get my truck tore down and the frame reassembled.
Freshened the look of the motor and accessory drive. |
#13 |
Decided to try out the fuaxtina paint job. It tuned out fair. Wish I was handy with an airbrush to make it look more real with some detail work.
#14 |
A little more of the fauxtina coming together.
#15 |
A little more along the way in the reassembly process.
#16 |
For me, it was essential that I one pieced the windows. I don't mind the way the vent windows look, but I can't stand the whistling. I started this project when there was not a kit available. One Piece has since started producing a kit. I had custom glass cut and tempered to templates I made. I welded track around the inside of the window frame so that it would hold a proper rubber. I used sweep material I found on eBay. I also took out 3.5" of the stock style mirrors. I think they turned out nice.
#17 |
This post is a little out of chronological order, before I installed the interior. I had a trim carpenter buddy help me build a box for behind the seat. Gave me a place to mount a sub, an amp, my air ride computer, and (2) 6x9s. I have 6.5s and tweeters mounted in kick panels. I'll have to get a picture of those later.
#18 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Very nice work
#19 |
Yes very nice work. Cool truck
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
#20 |
Some great work.
#21 |
Truck is turning out very nice.
#22 |
The fauxtina looks good from my monitor.
#23 |
Great work. I love the full chassis build.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#24 |
![]() Join Date: Aug 2017
Looks really good; love the wing windows removed.
#25 |
Cool build .you are working hard at it. Will be a lot of fun.
The Snortin' Bull |
