Old 12-14-2018, 09:16 PM   #1
buffydores
buffydores's Avatar
Squarebody 73-87 Brake Upgrade
Just wanted to share my experience in brake upgrades. For the half tons there's a factory brake upgrade available to us. There's a big piston caliper (JB7/JD7 - 13" - 3-5/32" piston diameter) that increases the clamping force by 15% over the standard smaller piston caliper (JB6/JD6 - 11" - 2-15/16" piston diameter). The big caliper showed up in the mid 80s 3/4 ton trucks. It's a bolt on. Starting in 1979, they started using the 10mm banjo bolt. Earlier than that, the banjo bolt was like 7/16". So pre 79 trucks might require a new set of lines coming off the frame to the caliper.
As far as brake pads, I've started to run EBCs Ultimax 2 pads for the D50 GM calipers. These suckers are rated GG friction, which is top notch. They have the cold bite you need in a daily driver. They also have the break in coating that helps get the pads seated to the rotor real nice. I can stand my Blazer, running heavy 35s, on its toes.
If you're running a heavy setup, and you don't want to go hydroboost, this is the ticket.
And please, please follow the break in procedure. Probably the most important aspect of the upgrade.
Old 12-15-2018, 08:07 AM   #2
Hammered 77
Hammered 77's Avatar
Re: Squarebody 73-87 Brake Upgrade
Interested. So do these require 1" or 1 1/4" rotors and does your 15" wheels still fit?
Rick
Hammered 77 is offline   Reply With Quote
Old 12-15-2018, 08:11 AM   #3
buffydores
buffydores's Avatar
Rick
Everything works fine. Same rotors. Bolt on. Just need to consider the brake line change if your lines are pre 1979.
I'm assuming on the wheels though. I'm actually running 16" wheels, but the only difference I can see on the calipers is the larger piston.
Old 12-15-2018, 07:41 PM   #4
buffydores
buffydores's Avatar
Update: Checked the clearances. No difference. 15s are good to go.
Old 12-16-2018, 07:26 AM   #5
Hammered 77
Thanks for checking.
Old 12-18-2018, 07:45 AM   #6
Hammered 77
What brakes do you have on the rear axle? Are you still running shoes or did you add disc to the rear?
Old 12-18-2018, 07:48 AM   #7
buffydores
buffydores's Avatar
Still running drums. Most of the work is done on the front end. Not saying upgrades in the back aren't helpful. They just don't move the needle as much.
Old 12-18-2018, 10:45 AM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
Rick
The JB7/JD7 calipers require a 1 1/4" thick rotor.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-18-2018, 10:49 AM   #9
buffydores
buffydores's Avatar
Thanks Karl. I see that factory rotors are 1-1/4". Why would anyone run a 1" rotor?
Old 12-18-2018, 10:56 AM   #10
Hammered 77
I don't remember what year it started, but some of the light duty 1/2 tons came with 1" rotors.
Old 12-18-2018, 10:58 AM   #11
aggie91
aggie91's Avatar
At some point GM started putting 1" thick rotors on the trucks as a light duty brake system. I think it was around 1981, I had an '84 that came with a V6 & TH400 that had the light duty brake package. I upgraded to the JB5 system with the 1 1/4" rotors up front (for 2wd, you have to swap the spindles to do this, I did when I put on the dropped spindles) and went with the 2 3/4" wide drums in the rear. Not sure why GM did it, but they did.
SO, if you have the 1" rotors and don't want to replace the spindles (2wd guys) to use the 1 1/4" rotors, then this upgrade is not for you.
Karl
The LST Challenge:
Old 12-20-2018, 07:39 AM   #12
Hammered 77
aggie 91 what issues (if any) did you run into changing to 2 3/4 brakes in the rear? Any wheel fitment problems? Was it just a matter of changing the brake shoes, drums, and cylinders?
Rick
Old 12-20-2018, 11:59 AM   #13
aggie91
aggie91's Avatar
Rick
No wheel issues at all.
The brake upgrade requires changing the backing plates. Those are what sets the width of the wider shoes to the inside. The axle placement and the face of the drum (wheel mounting surface) does not change.
Change the backing plates, new shoes, new hardware, new wheel cylinders, and new drums. That's it.
Check out this thread...Title is 12 bolt Drum Brake Upgrade, but same goes for the 10 bolt in these trucks...same parts are used...
http://67-72chevytrucks.com/vboard/s...d.php?t=692672
Karl
The LST Challenge:
Old 12-20-2018, 12:45 PM   #14
Hammered 77
Thanks, so before I go any further i'll need to find some backing plates.
Old 12-21-2018, 08:12 AM   #15
Low Elco
This is a cool idea and all, but how would you spec that out at say, O'Reilly's or AZ? Just ask for '77 3/4 ton calipers?
Low Elco is offline   Reply With Quote
Old 12-21-2018, 10:23 AM   #16
aggie91
aggie91's Avatar
Here is what you need to tell AZ or O'Reilly:
1985 Chevrolet C20 (3/4 Ton), 2wd, 5.7 engine
Front Calipers for Heavy Duty brake system, 13" rear drums
For reference:
Front Right Caliper is a ACDELCO #18FR649
Front Left Caliper is a ACDELCO #18FR650
These require the 10mm banjo bolt and hose
Ask for the front hoses for a 1985 C10 with the heavy duty brakes.
Karl
The LST Challenge:
Old 12-26-2018, 01:43 PM   #17
buffydores
buffydores's Avatar
Such great info. This is gonna be helpful for a lot of folks.
Old 12-27-2018, 04:32 PM   #18
SCOTI
SCOTI's Avatar
Also..... The 1/2 ton HD drum set-ups are more common under Burbs & Blazers if anyone is searching for the backing plates.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-03-2019, 01:54 PM   #19
SBTork
Garage wrench
SBTork's Avatar
Great info, thanks for the heads up!!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 01-03-2019, 03:01 PM   #20
Low Elco
Right on, thanks! Dig this- so I go over to a friend of my kid's shop who is a big 4x guy. We start talking trucks, and I mention this idea. He says, oh yeah, I have a pair on the shelf over there- used them once. You want them? 20 ea, with pads. not only that, but we tore our new truck down, and danged if it doesn't have the big back drums on it! Ha-HA! Gonna be stoppin' good now, fellas! imagine with the Hydroboost!
Old 08-01-2019, 01:14 PM   #21
bondobob
bondobob's Avatar
OK I get that bigger thicker discs and bigger and wider drums give you more stopping power for hard braking but do I really NEED to do this on my 84 short bed? It will add unsprung weight don't forget. My 82 K10 stops great with the big brake set up (locks the rear under heavy braking) but that's quite a bit heavier. If you guys feel it's definitely worth it on all street trucks I'll do it. I need to buy the correct dropped spindles and all new parts anyways. Looks like the proportioning valve and booster/master all gets changed. Small point: the single booster is better looking than the dual. I'm sure this has been hammered on before so thanks for your patience.
bondobob is offline   Reply With Quote
Old 08-01-2019, 01:23 PM   #22
Keith Seymore
Keith Seymore's Avatar
I don't think so.
My '87 was a daily driver for 30 years and was picture perfect in terms of pedal feel/travel/decel, even with all of my commuting, parts chasing, light hauling and trailering.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-01-2019, 03:39 PM   #23
buffydores
buffydores's Avatar
I only did it because I'm running 35" tires and needed more clamping force to get full lockup.
Old 10-10-2019, 03:23 PM   #24
Ski-me
Ski-me's Avatar
Nice info and thread. Are you saying a nice improvement over the original? I'm also running 35's and would be nice to slow it down a bit better.
Thanks for the great info!!
For reference:
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-10-2019, 04:13 PM   #25
1968k20
1968k20's Avatar
Did you ever find a low-miles Suburban?
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
