Old 07-31-2020, 12:42 PM   #1
Wizit247
Wizit247's Avatar
Wizit's bagged 60 GMC build V2.0
Sooooo... years ago I started this thread (http://67-72chevytrucks.com/vboard/member.php?u=156411) which is now defunct thanks to photobucket.
Well, life got in the way and I have now built a new house with a shop and am back to working on this truck. Plans have changed along the way from a fairly budget build to something a little wild.
Welcome to the show!
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901
Wizit247 is offline   Reply With Quote
Old 07-31-2020, 12:48 PM   #2
Wizit247
Wizit247's Avatar
Re: Wizit's bagged 60 GMC build V2.0
The day I brought the truck home in May 2015
I built a pretty run of the mill bagged setup. pancaked crossmember, trailing arms, etc.
And heres how shes sitting now. Just a cab in the shop patiently waiting for whats to come.
Old 07-31-2020, 01:08 PM   #3
Wizit247
Wizit247's Avatar
Every aspect of the truck from here on out will be designed in Solidworks in my free time(which unfortunately theres not much of!)
I have a lot of preliminary models of components complete. The only design actually complete is the front suspension and crossmember design.
I spent months dialing in the suspension geometry based on my knowledge from the off-road world and a ton of reading i have done over the past couple years.
The final design ended up with 2 degrees of camber change and zero toe change throughout the suspensions travel.
I utilized off the shelf Joes Racing upper a-arms. they are very affordable units available in basically any length you may need and utilize k772 balljoints.
The lower arms utilize Rydman Ranch balljoint cups and Speedway bushings.
The steering rack is a Mustang II unit.
Old 07-31-2020, 01:13 PM   #4
Grizz1963
Grizz1963's Avatar
Just how low can you go?
Photophukit really screwed it up for many of us.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-31-2020, 01:31 PM   #5
Wizit247
Wizit247's Avatar
I began to gather parts and build components to mock up the front suspension to verify everything cycles as it should.
I sent the crossmember files to the plasma to be cut and got to work on the other parts.
Designed and cut a jig to build the lower arms.
I assembled one side of the suspension with a mockup steering rack/tie rods and was happy to find that everything cycles as it should.
Both sides assembled. Note that the crossmember is missing a few pieces that cannot be tack welded in place until some internal welding is completed.
Old 07-31-2020, 02:03 PM   #6
Android04
Android04's Avatar
Looks good. What lower arms are you using? From your image above looks to be a turbo LS going in?
Android04 is offline   Reply With Quote
Old 07-31-2020, 11:13 PM   #7
Captainfab
60-66 Nut
Nice work Are you still at Rocky Mountain?
Old 08-01-2020, 10:05 AM   #8
88Stanger
88Stanger's Avatar
Damn fine job so far!!! love this....
88Stanger is offline   Reply With Quote
Old 08-01-2020, 10:11 PM   #9
Wizit247
Wizit247's Avatar
I designed and built the lower arms. 1.25" Dom tube, Rydman Ranch balljoint cups and speedway bushings and tube inserts.
It will be LS powered and current plan is twin hx35 turbos that I have but that may change. I'm undecided at this point.
Old 08-01-2020, 10:14 PM   #10
Wizit247
Wizit247's Avatar
Thanks Captain! Yep I'm still at RMC. Busy as ever!
Thanks!
Old 08-01-2020, 10:22 PM   #11
SkinnyG
SkinnyG's Avatar
I love it!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-03-2020, 02:21 PM   #12
tinydb84
tinydb84's Avatar
Awesome. I'm following along.
David
Instagram: myfabguy
Old 08-03-2020, 05:30 PM   #13
Wizit247
Wizit247's Avatar
Originally Posted by SkinnyG View Post
I love it!
Thanks guys!
Old 08-03-2020, 05:35 PM   #14
Wizit247
Wizit247's Avatar
Ive been spending some time chatting with the guys over at SS Chassis Worx getting the frame rails dialed in to a design I like and that will work with their tooling.
Heres a look at a few of the iterations that have come about. The bottom one is the latest and Im pretty happy with it!
Old 08-04-2020, 08:59 AM   #15
88Stanger
88Stanger's Avatar
Awesome build so far!!!! Watching for updates.
Old 08-07-2020, 11:49 AM   #16
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work so far! I would really like to learn how to use Solidworks, but don't want to spend the money on a new computer..
Tuned in for the rest of journey!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-10-2020, 11:48 AM   #17
Wizit247
Wizit247's Avatar
I paid the invoice to SS Chassis Worx for the framerails on Thursday, they sent me this pic of the completed rails Friday, and they shipped out Monday. Thats an impressive turnaround!
Old 08-10-2020, 12:44 PM   #18
tinydb84
tinydb84's Avatar
Man that is quick! If you don't mind me asking, how much did the rails set you back?
David
Instagram: myfabguy
Old 08-10-2020, 05:56 PM   #19
Wizit247
Wizit247's Avatar
Their base price on frame rails is $900 shipped. Mine were $975 shipped due to being a little longer than the base price ones.
I got quotes from every where that was willing to build them for me and they were all in the 950-1300 price range not including shipping which was another 200-300 in most cases.
the the SS Chassis Worx guys were ~200 cheaper than the next closest competitor.
Old 08-11-2020, 07:23 PM   #20
Wizit247
Wizit247's Avatar
I found some time last night to work on the rear suspension. The geometry is good and locked in.
Im not completely happy with the crossmember yet. I will continue to work on it.
Old 08-12-2020, 01:00 PM   #21
Wizit247
Wizit247's Avatar
For my birthday my wife paid Rendered Rides to do some renderings of my vision of the finished truck.
It was really fun working with the artist and picking out every little detail!
I have a 3'x4' print of the first one on the way to hang in the shop.
Old 08-13-2020, 03:13 AM   #22
Grizz1963
Grizz1963's Avatar
Perfect gift that rendering.
And you have one of my favourite colours/colors
My ex wife (still a good friend) did me a 4x5 foot canvas print of my truck in black and white in an industrial setting with just the red picked out. It lives in my study on the wall.
Old 08-19-2020, 12:08 PM   #23
Wizit247
Wizit247's Avatar
I received my 36x48 print and built a quick frame for it. just need to find a spot in the shop to hang it now!
Old 08-19-2020, 12:11 PM   #24
Wizit247
Wizit247's Avatar
While waiting for the frame rails to arrive I have spent my evenings designing and building a frame jig and associated jigs to help locate and hold the frame rails and rear axle.
The frame rails should hopefully be here by the end of the week!
Old 08-19-2020, 12:44 PM   #25
tinydb84
tinydb84's Avatar
Your jig is nicer than many of the trucks Ive seen built.
David
Instagram: myfabguy
