02-21-2015, 02:41 AM | #1 |
Lets see your gauges setups
Hey everybody ive been lurking around here for awhile and am getting close to driving my baby again. Trying to get some ideas for gauges specifically from the 60-62 GMC guys. any pictures are appreciated.
02-21-2015, 04:01 AM | #2 |
Senior Enthusiast
Re: Lets see your gauges setups
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-21-2015, 07:59 AM | #3 |
02-21-2015, 10:41 AM | #4 |
02-22-2015, 03:53 AM | #5 |
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
02-22-2015, 08:58 AM | #6 |
02-22-2015, 09:12 AM | #7 |
"Where were you in '62?"
So far.... more to come
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
02-22-2015, 11:45 AM | #8 |
It's Better With Nitro
I was able to keep the original speedo (the only thing that worked on my original instrument cluster). Clear anodized the face to match some left over Autometer gauges I had, and used Adobe Illustrator to recreate the speedo numbers and hash marks in reverse and in the correct arch.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
03-16-2015, 10:06 PM | #9 |
Mark..I haven't seen your cab/dash for awhile...really over the top!!
In other words..I like it Bob |
03-17-2015, 09:41 AM | #10 |
Astronaut, really like that clean look. What all is involved in re-numbering/recalibrating the speedo?
Lee |
03-17-2015, 09:52 AM | #11 |
one more...
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
03-17-2015, 10:08 AM | #12 | |
The speedometer may end up being driven by an Abbot cable-x box or Dakota Digital's newer version. That will take car of the speedometer calibration. Jason handles the tach calibration.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
02-21-2015, 06:55 AM | #13 |
This
With these type gauges (Tach, Speedo, Volt, Water temp, Oil pressure, Fuel level) |
02-21-2015, 10:33 AM | #14 |
Here's a couple of my '62 dash taken during re assembly a couple years back. I went with VDO Cockpit Royale gauges, which I opened up & modified (not an easy thing to do with crimped on bezels I'll tell you I repainted the stock pointer colour from black to red, also added the GMC logo on the speedometer & covered over the VDO name with "Murphy's" (my nickname) since I modified them anyway I also went with a painted diamond plate as the gauge support panel and repeated that theme making up a filler panel insert for the glove box. Think it turned out pretty cool!
Welcome to the forum, I'm sure you will find tons of cool ideas here! |
02-22-2015, 04:34 PM | #15 | |
1964 BBC 402 4x4 |
02-21-2015, 11:42 AM | #16 |
Here's the '62 before removing tach on the column.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-21-2015, 04:55 PM | #17 |
Here are my ugly gauges. I will probably change them someday.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
02-21-2015, 06:31 PM | #18 |
These are my gauges that will go back in once the cab repairs and wiring are complete. They are AutoMeter with No Limit face plate. I plan to fill in the switch holes on the bezel. My new to me tilt column has a key & wiper. I'll hide the light switch under edge of the dash.
02-21-2015, 09:04 PM | #19 |
this is my low budget set up
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
02-21-2015, 11:38 PM | #20 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
This is a fairly poor pic of mine...finger printed & dusty from putting it in & taking it out several times during the wiring process...but it is all that I have on hand!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
02-22-2015, 12:02 AM | #21 |
Here is mine but it not in the truck yet
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
02-22-2015, 01:15 AM | #22 |
Speedhuts....
Their simply awesome....
02-22-2015, 02:16 AM | #23 |
60-66 Nut
You do realize that the GMC and Chevy dash clusters are not the same, correct?
Here is a very nice set of gauges that sdwolff98 is installing in his GMC. You'll have to scroll down the page a ways. http://67-72chevytrucks.com/vboard/s...438342&page=11
02-22-2015, 08:19 PM | #24 |
You know, I've been leaning towards Dakota Digital but lately, these are lookikng better and better; with red lighting of course...
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
03-08-2015, 10:35 PM | #25 |
