69fatmotor
ojoe's crewcab shortbed build
i figured it was time to start build thread on joe's (ojoe) shortbed crewcab 1/2 ton. here's a few pics to get things started , i'll let joe fill in the blanks.
69fatmotor
Re: ojoe's crewcab shortbed build
more pics
69fatmotor
more pics
67-72 parts collector,…
![]() Join Date: Nov 2002
I'm subscribing to this one.
I like it shortbed crew cabs are very cool. Lifted or lowered you can't go wrong. I will be keeping my eyes on this one also.
Tot Roddin'
![]() Looks like we need to get crackin lolife99! ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 01-01-2008 at 02:58 PM. |
To clarify, the black cab'd truck with the gold bed was a different truck than this one, right?
I have an '87 swb 2wd and an '85 swb 4x4. I would like to do a 4x4 swb crew. Just need the crew???
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Truck Nut
![]() Join Date: Jun 2007
Count me in on the subscription list. It gives me inspiration to cut my truck up!
Tony Kee Texas Square Bodies |
is that a 1/2 ton back half grafted to the 1 ton frame?
Are you retired too? Nonsense! I'm in my prime |
glamoros piece o' lowlife
Some constructive criticism - what size are those bolts holding the two frames together? Look kinda small to me, I wouldn't trust anything smaller than what holds the rear springs in their hangers. Also if it was my truck I'd weld up the rear vertical edges of the 3/4-ton frame to the outside of the halfton frame, and also the front vertical edges of the halfton frame to the inside of the 3/4-ton frame, wouldn't rely on just the bolts to keep things from shifting in case of an accident.
Other than that I think it looks pretty darn good, only thing it needs is a stepper bed and it'll be just perfect ![]()
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
I think bolts are for alignment purposes. This makes is a fool proof method. I'm sure full welding will come next.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-02-2008 at 02:55 AM. |
Crew Cut
thats correct. truck goes back on lift today for steam clean frame, rear disk brakes,frame weld (maybe boxed) dont want overkill. and frame paint. next will be the fuell system
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
Loving it !!! please keep us updated with the build. keeping my eye on this one.
#15 |
Very cool truck, good luck with it.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
#16 |
69fatmotor
here's couple pics of some of the latest progress.got the frame cleaned up and painted also installed the rear disc brakes and replaced everything else on the front brakes. also installed new 3.73 gear set with all new bearing. i myself had surgery friday to repair a double henior, so i want be around to help joe on this project for about a month or so.
#17 |
![]() Join Date: Apr 2005
It's about time you started a thread on this............
![]() R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#18 |
What was the final length difference?
John |
#19 |
Crew Cut
went from a 8ft bed to a 6ft should be 2ft shorter. i have not measured the wheel base.
#20 |
The truck looks real good.
You guys turn out some real nice work. |
#21 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Going from LWB to SWB is a 14" reduction in wheelbase and you would have to lop off about 6" off the back, so technically it should be 150.5" wheelbase now. and should be about 2 feet shorter.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#22 |
Live fast, die young
Looking great. Love it.
#23 |
was just looking at a lwb crew like this today. yours looks much better though..
and updates? what are the future plans for this thing? |
#24 |
Crew Cut
will install a LT 1 /4L60E dailey driver
#25 |
