06-20-2018, 02:14 PM | #1 |
'51 GMC Restomod Finished!
I'm pretty much finished building a '51 GMC 100 for another local business. They had the truck restored around 20 years ago but it never was reliable so they didn't do much with it. They brought it to us to be updated underneath while keeping a fairly original look so they could finally get it out and enjoy it. I used Mustang II front suspension, TCI's Parabolic rear left spring/shock kit, an Explorer 8.8" disc/lsd axle redrilled for 5x4.75", a 5.3/4L60e from an '06 Avalanche with a PSI harness, Tanks Inc rear mount tank, Vintage Air Sure Fit kit with Kwik Performance compressor bracket, Ididit tilt column with a '54 wheel shrunk to 15", Lokar floor shifter and e-brake, and all new glass and weatherstripping. I kept the old paint and door lettering since it was in pretty good shape and only had to touch up a few areas. I did scuff the whole truck after fixing/blending base over the repaired areas and shot a couple coats of slightly flattened SPI Universal Clear.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
06-20-2018, 03:36 PM | #2 |
Re: '51 GMC Restomod Finished!
Oh wow, that is one fine truck!
06-20-2018, 06:02 PM | #3 |
Sunny beach, that is nice! I love the seamless blend of old and new.
1951 Chevy Panel Truck |
06-21-2018, 12:27 AM | #4 |
I'm so jealous, that looks amazing!
What color brown in the dash?
1950 Build |
06-21-2018, 12:52 AM | #5 |
very nice .....
06-21-2018, 01:45 AM | #6 |
That is a great truck! What are the wheel and tire specs? I've got the same suspension setup planned and am about at the point of ordering wheels.
Thanks! |
06-21-2018, 02:24 AM | #7 |
really beautiful! I really like the Cibie style euro lenses those are con2r gauges right? I thought about calling them to see if I could get a plug in set for the 03 donor I have right now.
06-21-2018, 04:37 AM | #8 |
Pretty cool.
Are you saying you shrunk the diameter of the steering wheel? got any info or pics of that process? Last edited by tmoble; 06-21-2018 at 04:43 AM. |
06-21-2018, 10:48 AM | #9 |
Curious about the rear-end re-drill: Since the rotor slip over the lugs, do you have to have rotors re-drilled when you replace them, or is there a better answer for this?
06-21-2018, 11:04 AM | #10 |
The axle was bought from a local street rod shop already rebuilt and drilled, ready to go into the chassis. I don't remember if they used rotors with the correct lug pattern or if they're also redrilled.
06-21-2018, 11:00 AM | #11 | ||||
Thanks for the comments!!
Here's a post with more info on that. http://67-72chevytrucks.com/vboard/s...12&postcount=7
06-21-2018, 04:27 PM | #12 |
Well done ! REALLY NICE !!!
06-22-2018, 12:23 AM | #13 |
that's nice....any chance we could see the under sides.?
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
06-22-2018, 09:22 AM | #14 |
Nice job. Looks like it would be a great cruiser.
I really like the steering wheel, great mix of old school looks and modern size. |
06-22-2018, 08:38 PM | #15 | |
I didn't take any pics while I was building it, and I don't have a lift to take pics now. Its nothing special underneath, I had the frame powdercoated but it's not really detailed well. Just meant to be a daily driver level refresh so I didn't spend much time making things look good underneath.
06-25-2018, 12:19 AM | #16 |
beautiful.
07-06-2018, 02:27 PM | #17 |
Very nice G M C and the right combination!
07-07-2018, 10:23 AM | #18 |
Beautiful truck. Nicely done!
07-08-2018, 03:58 PM | #19 |
Well done!
