03-20-2014, 04:52 AM | #476 |
Re: How about some pics of Static Dropped C-10's
Well what I did to get that was went to my machine shop an Drew up a basic spring/axle perch but the only difference was that I had him cut it I had him make it up where the perch was also the 2" block as well, so it was a 2in1 piece
03-20-2014, 02:35 PM | #477 |
U got any pics of it?...i got just flip brackets with gabriel air shocks in the back and 2 cut coils in front. Would like to go with 3 inch springs and spindles and 2 inch shackles
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
03-21-2014, 10:33 AM | #478 |
This is the best I got of my "custom" perches with 2" block "built-in"
03-21-2014, 02:20 PM | #479 |
That looks a bit scary to me. Is it fully welded? It doesn't look like the rearend was cleaned prior to welding.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-21-2014, 03:37 PM | #480 |
You may want to take that axle out and reweld the perches without the rust. I've had bad experience with Welds+rust, they dont mix
69 c10, mild 350, TH400, LWB......Starting build 3/14 |
03-24-2014, 02:27 AM | #481 |
what rims are those?
Every new beginning comes from some other beginnings end |
03-24-2014, 08:20 PM | #482 |
No they are not fully welded there... But the rust in the area of weld was cleaned up with die grinder prior to the weld being put there.
The drop specs are approximately 5" front and 8"+ in the rear. And unfortunately I don't know what rims they are they were on the truck when I bought it they are 15" though |
04-12-2014, 02:18 PM | #483 | |
04-14-2014, 11:53 AM | #484 |
'70/C10/402/TH400. |
04-22-2014, 09:34 PM | #485 |
here is mine and its gonna have to have new front tires. its to low for comfort!!! these are 225/50/15 im fixing to put 255/60/15 so we will see what it looks like. its kinda a balancing act caus Im pretty sure after the tire swap im going to have to trim fenders and maybe relocate hood hinges
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
04-23-2014, 10:17 AM | #486 | |
04-23-2014, 12:07 PM | #487 | |
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
04-24-2014, 06:16 PM | #488 |
Lol my problem is not width its hight. I have a 235/70/15 rollers on there now and I have 1 inch from the top of the tire to the inner fender lip where the hinge bolts on. It may not appear so in the pics but it rides about where a truck would sit if it was bagged out with stock spindles. If I put bags on it I could lay my fenders on the ground.
05-06-2014, 01:55 PM | #489 |
ok here is an update! the fronts are now 255/60/15
05-06-2014, 03:54 PM | #490 |
That looks much better!
05-06-2014, 11:06 PM | #491 |
My measurements are 24" top of front wheel opening to ground, 27" on the rear, top of wheel opening to ground.
05-07-2014, 08:43 PM | #492 |
Not sure if this is right forum
I have P295/50R15 on rear of my 71 C10 and P255/60R15 on the front I've looked everywhere and can't seem to find the idealistic drop? Does anyone have this setup or know of the best or most common drop. Thanks in advance for your input. zibs71 |
05-07-2014, 10:57 PM | #493 |
4/6 is good for ride , thats what I have with an additional 3" of body drop, my tires are close in size to yours. So what you see in my pics is 7/9 drop. If you don't have deep bs win the rear Rims your tires will rub you need 6.5 bs atleast for a 12 wide rear and that is on an early(narrow rear) you need 7.5 bs for a 70+ rear. With a 10 rim just subtract 2" bs =)
05-08-2014, 09:47 PM | #494 |
Thanks Robznob11,
As I said I'm really a noob with all this suspension stuff so in saying that is 4/6 mean 4 inch drop in front 6 in rear¿ sorry for my ignorance on this. Would it be best to use lowering coils ? What is the best recommended coils or drop spindles¿ Can someone please explain this to me.thank you for all feedback . zibs71 |
05-09-2014, 02:05 PM | #495 | |
If you want sports car handling then go with the Hotchkis TVS kit, but for a driver/cruiser, ECE all the way.
05-18-2014, 12:38 AM | #496 |
05-18-2014, 08:39 AM | #497 |
link?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-19-2014, 01:10 AM | #498 |
No link but I will see if I can find one. There is another black and white C10 on there in Vegas for $72,000...
05-19-2014, 01:22 AM | #499 |
gets board easy.......
Yo rob, nice stance and wheel combo.
06-01-2014, 09:48 PM | #500 |
1.5 coils cut in the front and 2 " blocks plus jeep springs in the rear
Thread Tools | |
Display Modes | |
