05-24-2006, 12:57 AM | #1 |
1969 SuperBurb build-up (Bagged and Blown!)
*** 6/20/18 Hanging the body trim.....***
*** 4/24/18 Will this thing ever be done???*** *** 3/15/17 All front sheet metal bolted on for the last time.*** *** 10/23/16 FINALLY FIRED IT OFF!!! *** *** 10/5/16 On the home stretch!!! Finishing up some small details before trying to fire it up....*** *** 11/5/10 Still working on the wiring: fuel injection, body harness, electric fans, a/c and Magnacharger install.... *** *** 8/6/10 Currently working on the wiring: fuel injection, body harness, electric fans and air ride.... *** *** 4/2/10 AccuAir is installed!!! Time to start working on the SuperCharger, *** *** 1/1/10 Painting is complete!!! Time to reassemble, *** Paint code: red - WA9260; white - WA8624 I put this here because most of the modifications/upgrades apply to trucks as well. The first picture is of the truck when I bought it. It was an original California black plate truck. It had minimal rust, most do to a leaky windshield and the exhaust exiting out the sides. The next picture is a rendering of what I envision it looking like when I'm done (rendering by Zumo graphics). List of work completed: Front suspension: ART bags, ART StrongArms, CPP 13" drilled and slotted rotors with dual piston calipers and modular 2" dropped spindle. 1.25" sway bar. http://67-72chevytrucks.com/vboard/s...d.php?t=174330 Rear: ART bags, Porterbuilt 3" dropped tubular trailing arms, CPP C-Notch, ECE Super track bar, ECE upper shock relocation kit, 5 lug conversion axles, hidden hitch, and flip down tag. CPP 12" rear disc brake conversion with drilled and slotted rotors. http://67-72chevytrucks.com/vboard/s...d.php?t=162718 http://67-72chevytrucks.com/vboard/s...d.php?t=162641 Build sheet: Billet Specialties Vintec wheels/Toyo ProxyII tires, rear: 20 x 10 (5" BS) 295/45, front: 20 x 8.5 (5.0" BS) 245/45s Accuair E-level air management setup (3/8" lines, 3 gal tank, Viar compressor, remote control) ART StrongArms ART Bags CPP 2" modular dropped spindles CPP 5 lug conversion kit with 13" drilled/slotted rotors and dual piston calipers PorterBuilt tubular trailing arms with built in 3" drop ECE Super track bar ECE Shock Relocation Kit ECE 5 lug axles ECE hidden hitch and flip down tag PST sway bar & ECE lowered sway bar brackets Misc parts from board members (drag link, brake pedal....) CPP C-Notch New 3.73 Yukon Gears and bearings New Eaton posi unit Energy Suspension polyurethane body mount kit Body work: Replaced/repaired inner and outer rockers, lower inner kickpanel, partial floorborard, and doglegs on both sides (Goodmark parts from Ed at MotherTruckers) Welded holes in firewall including heater box Welded in new rear lower quarters Removed stock upper suburban trim and filled holes Welded in 5 1/2" remote gas filler lid from 80's Nissan Sentra car New sheetmetal - Doors, fenders, inner fenders, core support, cowl induction hood, 72 GM inner and outer grill, 72 bumpers Custom made Mar-K.com upper and lower trim Custom Billet Aluminum Emblems Chrome plated/stainless steel factory roof rack OEM truck cargo light converted to LED 3rd brake light All new glass, glass rubber, vent windows (RogerKoop), door seals (PrecisionReplacementParts) Converted manual liftgate extensions to gas struts http://67-72chevytrucks.com/vboard/s...d.php?t=220511 Removed tailgate scissors and replaced with cables. Welded in truck bed ends for truck tail lights. Bottom of body has been sprayed with SpeedyLiner undercoating Engine: 5.3/4L60E w/ DBW(only 10 miles, 2006 Tahoe) MP112 Magnacharger with 43LB marine injectors (BIGTEX) Speartech EFI harness Clayton Machine Works billet coil covers Painless body harness Entropy LSX radiator and dual cooling fan setup Doug Thorley Tri-Y 323 headers (JAMIE) http://www.truckinweb.com/tech/engin.../photo_01.html 2007 Cadillac CTsV oil pan and components ECE LS conversion motor & tranny mounts ECE 28 gallon Stainless Steel EFI fuel tank (Ricks Tanks) http://www.earlyclassic.com/catalog.aspx Custom fuel line setup using Corvette fuel/pressure regulator and Walbro in tank fuel pump (Thanks Shifty, BowTieOgre and PCMCobra!) Interior Dakota Digital HDX blue tooth programmable gauges (MCBMatt) Custom Front row Buddy Buckets with heated seats cup holders, 2nd row Buddy buckets, 3rd row bench. Tilt Steering column Custom woodgrain steering wheel Cruise Control 72 Cheyenne Super Front and rear door panels Intermittent wipers Vintage Air Gen IV with Dakota Digital controller Custom RetroSound 2 Bluetooth radio
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-21-2018 at 09:46 AM. |
05-24-2006, 01:00 AM | #2 |
Re: 1969 Burb build-up (Bags, 5.3/4L60E, repaint, interior....)
More pics of the tear-down... Made a nice mess on the floor also, forgot to put something in the end of the transmission, DOH!!!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-26-2006 at 09:37 AM. |
05-24-2006, 01:04 AM | #3 |
OK, the hard part is done (not!). While the engine is out of the way, I plan on smoothing the firewall, redoing the front brake lines, redoing the front airlines, clean and paint. Then on to the fun stuff......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-24-2006, 01:23 AM | #4 |
Chevy truck addict
lookin great man....keep up the good work
05-24-2006, 02:52 AM | #5 |
Gotta love that. Good thing mine's a daily driver or it would be in pieces too! Keep the progress pics rollin!!!
05-24-2006, 01:47 PM | #6 |
I have been wanting to see your burb for a while (since the PS thread) and didn't know where to look. It looks sweet! NICE WORK! I love those burbs!!!
1959 GMC project |
05-24-2006, 02:29 PM | #7 |
C10 Club Tennessee
Looks good, hope my new one will look half as good one day.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
05-24-2006, 04:46 PM | #8 |
Are you going to use the stock exhaust manifolds or headers? I have been trying to get my stock manifolds to work but both sides are hitting the frame. I have heard that big block headers will work if you use LS1 flanges on them. I will be trying that soon.
05-24-2006, 05:10 PM | #9 | |
I wanted to use the stock ones, however if you're having problems, I may have to try something else. I think I remember Shifty of GenIII say something about the camaro/corvette stock manifolds would work. I'll try to do some research on that one. Rob
05-24-2006, 05:26 PM | #10 |
SKINNY TIRES RULE!
You can drop it off at my house when your done
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-24-2006, 05:36 PM | #11 |
The LuvShack Garage
Sweeeeeeeeeeeeeeeeeeeeet
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-24-2006, 06:05 PM | #12 |
Questionable
can i drive down there in the fall so we can bag my truck next?!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-24-2006, 06:23 PM | #13 |
www.73-87chevytrucks.com
What are you using for motor mounts?
I ran into this problem on my 73 pickup when I was using ECE's motor mounts on my 6.0L/4L80E documented here: http://67-72chevytrucks.com/vboard/s...d.php?t=193657 This is with ECE mounts on my '73 frame: I am selling those now... This past weekend I replaced the ECE mounts (which posistions the SBC about 3" forward of a normal SBC) and put S&P motor plates on it (which mounts it back in the same position that a SBC would mount. I expected grinding on the port above to clearance it and was told 00-02 F-body manifolds would work, but I believe I have it to where I can use the factory Truck manifolds. I
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
05-24-2006, 06:39 PM | #14 |
Looks great, keep it up!
05-24-2006, 06:45 PM | #15 |
Keep Building! Looks good! I have a very similar swap I'm working on, a 2003 Avalanche 4wd running chassis with a 71 burb on top. yikes! good luck
] : - 71' burb,5.3,4wd 02' f350.7.3 00' F250-powerstroke 00' Roadstar 84' Eagle model 10 72' GMC 18' camery 12' ZX14R- |
05-24-2006, 08:10 PM | #16 | |
Thats the same problem I am having and I am using the S&P plates also. Summit has big block headers for $99 and the flanges are $16 I am going to try that route and maybe I can help us all. Sorry to hijack your thread. |
05-24-2006, 10:35 PM | #17 |
Shifty - come on down!!!
I'm using the ECE motor mounts. I was hoping to be able to use the stock manifolds, but looks like that might not work. A buddy of mine has an 02 LS1, I'll borrow his and see how it works. Oh, well not quite there yet. Spent half the day cleaning (still not done) and started working on fill the holes in the firewall. I also have some rust repair to do, but pretty minimal. After that I will be moving to the rockers and and a small amount of rust on the floors/kickpanels. Here are some more pics, the old burb is definitely at parade rest now.
05-24-2006, 10:42 PM | #18 |
I also gutted all the engine & dash wiring. I enjoyed this quite a bit, since PO had cut and spliced into every wire on the truck. I found many melted or burnt wires as I was doing this. Also, cut the firewall to accept a new painless wiring harness.
05-24-2006, 10:58 PM | #19 |
Chris (CaptKaos),
Just read your build post, nice job BTW. I know ECE designed their motor mount kit for the 67-72. Could this be the problem with the exhaust in your truck? I don't know what the differences are in the frames. Also, do you have some pics and descriptions of your fuel system. What tank, fuel pump, type of lines.....????
05-24-2006, 11:57 PM | #20 |
pictures and links to the gauge build by Putter and the one in FAQ by Ron Woodgeard.
http://67-72chevytrucks.com/vboard/s...d.php?t=200387 http://67-72chevytrucks.com/vboard/s...d.php?t=110613
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-08-2007 at 11:40 PM. |
05-25-2006, 12:16 AM | #21 |
Man you are getting that thing going. I'll be plugging those same firewall holes here very soon. It is really looking nice.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-25-2006 at 12:18 AM. |
05-25-2006, 03:59 AM | #22 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looking Great! Keep up the Sweet Progress
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
05-25-2006, 04:10 AM | #23 |
MY EX DRIVES A BROOM
looking good
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
05-25-2006, 05:32 AM | #24 |
MEMBER
Lookin great. And perfect timing for me I just started on my sub yesterday and you have already saved me some grief. Thank-you and keep the pics comin....PLEAZE....
86 sub 4wd, 1 ton, duallie, big block th475 72 c10 short fleet, pro street 72 K/5 blazer,2x4 almost stock 72 3/4 ton sub 4x4 61 morris minor pickup, chevy 4.3 v6 03 escalade, 24" momo's wifes 96 2wd 2door tahoe 67 2wd suburban 72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo. |
05-25-2006, 08:36 AM | #25 |
More Cowbell....
Holy crap...that gauge cluster is AWESOME. Where did you ever find something like that???? (**wink**)
Hey, if you are running 2700 rpm and have 0 oil pressure, you better shut'er down (see gauges) Rob, glad to see you got all the parts home safe & sound. We had a great time at the cook out and really enjoyed meeting you and your family. Oh, I just remembered you wanted the door hinges. You still need them? Shoot me a PM with address if you do...it's pretty dry out there for a change!! Maybe after we get this house done I will come over and you can help me do MY bags!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 05-25-2006 at 08:36 AM. |
