Bear Claw latches
I saw many of these at the Pleasanton swap meet. I guess I need to buy some.
What should I look for? What should I pay? Does anyone have a how to? They sound like a must have!
51 3100 build thread http://67-72chevytrucks.com/vboard/s...light=stevehsd 77 FLH |
![]() Join Date: Apr 2005
Re: Bear Claw latches
http://www.chuckthetruck.com/page23.html
http://www.southernrods.com/categori...duct-1304.html You can probably google some more stuff.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: Mar 2007
I installed some bear claw latches last summer. I followed the how to from H.A.M.B. It was prety straight forward.
The link to the how to is the following: http://www.jalopyjournal.com/forum/s...ad.php?t=77555 Good luck Marc |
If you don't mind your door popping open when you hit a bump in the road, it's a waste of time and money.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
I installed the small autoloc units on my 54 last year. Very happy with them.
Here is how I did it. http://www.picturetrail.com/gallery/...64&uid=2902753 |
I'd pay a good penny for a setup that would bolt into the stock locations. Mine is already painted and I haven't got aggravated enough to do the install,
Hollister Road Co.
One thing to think about is the latch doesn't have to be in the door. It can be on the jam if you use power actuators and poppers. Its a cleaner look when the door is open but only works if you are using power actuators. You can get the latch with that built in or as a seperate mechanism connected by a rod.
#8 | |
![]() only reason for doing this is its cleaner, and I dont want any wires in my doors... |
Hollister Road Co.
Take some pictures! Are you using the installation kit with the claws? It covers up some of the works when you put it in the door sile.
I made 2 panels with the same exact shape as the original latches plates for the 55' with bear claw latches instead of the old latch system. I wanted to be able to remove the panels. It works really well and had no welding involved although I did have to cut out a bit of the door to make room for the bear claw latches. Im going to chrome the plates when I send in the rest of my stuff to get chromed.
