Old 05-29-2008, 07:27 PM   #151
Hart_Rod
Hart_Rod's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
Where did you get the pan and the fuel pressure regulator setup?
R
Hart_Rod is offline   Reply With Quote
Old 05-29-2008, 11:09 PM   #152
pcmcobra
pcmcobra's Avatar
rob,
that's the vette filter/regulator, can buy it at any parts place. I got one on mine, think I paid $39@ oreillys
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 05-30-2008, 06:51 AM   #153
68 short step
Originally Posted by PipsC10 View Post
where did you get your lower kick panel patch panels? I love the way you mounted your front ride height sensors, awesome build!
lwr kickpnls came from LMC and kennys trucks (in tulsa OK)....the LMC dr. side lines were off so another one was bought at kennys trucks that fit...
68 short step is offline   Reply With Quote
Old 06-02-2008, 11:06 AM   #154
68 short step
this weekends progress report :
got the trans cleaned and painted, mated it back to the engine, and installed them in the frame....the trans mount is about 2.5" higher then the 4l60e, so the trans x-member had to be modded to move the mounting pad up...and a few pics of the headers installed ,,,,,here are a few pics
Old 06-02-2008, 12:32 PM   #155
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good Don....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-02-2008, 09:39 PM   #156
71Hulk
look ma no header clearence issues!
71Hulk is offline   Reply With Quote
Old 06-02-2008, 11:27 PM   #157
pcmcobra
pcmcobra's Avatar
what headers are those?
Old 06-02-2008, 11:38 PM   #158
Hart_Rod
Hart_Rod's Avatar
Dude, is that a new white carbon fiber drive shaft?!?!
Old 06-02-2008, 11:49 PM   #159
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
I'm liking this very much. Great build and great pictures. I'm really facinated by your frame cut and splice. Great way to do that.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 06-02-2008, 11:51 PM   #160
killer71
killer71's Avatar
and some beefed up u joints
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-03-2008, 02:18 AM   #161
Rokcrln
Rokcrln's Avatar
Originally Posted by 68 short step View Post
kevin,
dunno who you talked to at what company.... but how it works is the ECM sences the throttle position, and load. if its within the limits it'll shut off 4 cyl. indeffently to conserve fuel....
how it does this is through oil pressure to 'special' two piece lifters....when in the 4cyl, mode the outer part of the lifter moves with the cam, but the inner part does not move.. I E the pushrod nor valves move either...when the ECM sences a change in the load (going up a hill), or more gas (pedal position chages outside the limits) it switches back to 8cyl. mode... it does this in meer milliseconds and cant not be detected, other then the exhaust tone....as a matter of fact those DOD cylinders receive less ware do to this function....
Scoti,
welcome to the club.....you know we'll require a thread with pics
I talked with Howell feul injection as well as street and performance and both said it is not worth doing. So for my 05 5.3L who would you recomend getting a harness from so this function stays active? I am trying to get the best MPG I can out of this truck. It has 3.27RP with the 4L60E but the whole cylinder dropping has me at a loss at this point. Any imput would be great.
Also I missed it last time but nice job on slicing the rocker to fit the door/fender profile. Most poeple don't take the time to do this and it really pays off in the end.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-03-2008, 12:28 PM   #162
gringoloco
A guy with a truck
gringoloco's Avatar
Go with the stock harness/PCM. You are more than capable of re-routing some wires. It looks worse than it is...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-03-2008, 01:47 PM   #163
68 short step
yea, that would be my first choice (do it myself) but john at speartech is also another great option, he knows his stuff......
S&P is hit and miss on knowledge, enough so i dont base decisons on what they say...
Old 06-03-2008, 11:21 PM   #164
tk-mpl
tk-mpl's Avatar
Doing the harness is not that bad. Very scary looking and confusing at times with the mess of wires everywhere. Just do it one connector at a time and label everything... In the middle of doing mine and I quite enjoying it.... I do have one question for ya Don. Do you think it will affect the knock sensor reading if i route them inside the harness with the starter solenoid wire. They are a twisted pair of wires so I don't think induction should be a problem.
Thanx
Trevor
tk-mpl is offline   Reply With Quote
Old 06-03-2008, 11:34 PM   #165
68 short step
Thanx
Trevor
i dont think you'll have any interferance at all, you should be fine IMO
Old 06-04-2008, 02:51 AM   #166
Rokcrln
Rokcrln's Avatar
I will contack John and get his imput. I would like to keep the DOD feature even if it only give a few % in gain on the MPG. I called S&P today to ask about CC on a drive by wire system and was pleased to find out it is all in their and all they would need to do is add a few wires for me to hook to my colunm switch. That will make for a very cloean set up. I assume John can do the same. Thanks for the info and I am heading over to read the link you sent.
Kevin
LFD Inc.
Old 06-04-2008, 10:25 AM   #167
SCOTI
SCOTI's Avatar
Kevin
LFD Inc.
I tried finding the link someone posted about the 'clean' apprearing turn signal stalk w/the CC switch. Do you happen to know that source?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-04-2008, 10:52 AM   #168
killer71
killer71's Avatar
i believe it was in my build up awhile back.
R.I.P.
Killer 71
10/26/07
Old 06-04-2008, 11:01 AM   #169
gringoloco
A guy with a truck
gringoloco's Avatar
It's a Dakota Digital item...
-Chris
Old 06-04-2008, 12:16 PM   #170
Hart_Rod
Hart_Rod's Avatar
http://www.dakotadigital.com/index.c...prod/prd50.htm
Old 06-04-2008, 12:17 PM   #171
SCOTI
SCOTI's Avatar
I knew it was in one of these threads but couldn't remember which one. I just re-read through Don's SS build-up as well as LowBuks & didn't see it. The Killer build-up was next on my list.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2008, 01:13 PM   #172
Rokcrln
Rokcrln's Avatar
That is the same one I have in Low Buck but it came with my CC kit that I ordered from a supplier that the manufacture recommended. I think the kit is a Rostra design or something like that. It works great now that I have all the dip switches adjusted right. I think summit or Jegs also sells the kits.
Kevin
LFD Inc.
Old 06-04-2008, 02:39 PM   #173
tk-mpl
tk-mpl's Avatar
I was meaning to look into that CC switch. To make that functional all a guy has to do is add the CC input from that switch to the PCM, right?? I was shocked on how cheap it is!!
Old 06-04-2008, 04:06 PM   #174
68 short step
yes, the pcm controls the CC... just connect the on/off switch, resume/ accelerate, set....and you're done..
Old 06-04-2008, 06:54 PM   #175
tk-mpl
tk-mpl's Avatar
Cool, I gotta have one...
Thanx
Trevor.
